Results 1 to 25 of 28
Thread: Worlds quickest 1/4 mile E39
    Sep 2013
    Denmark
    1998 540i
    https://www.youtube.com/watch?v=GTRkc9tdcyA
    I did 4 runs this day at Action Meet - Mantorp Park - Sweden.
    The first run a ran 10.99 then I gave a little more on the launch control and ran 10.52 & 10.51
    I decided to give at a little more again & ran 10.44 :-)
    This is a full weight car with everything in it (even the orig. toolbox is full)
    As far as I can find documented, this is the quickest E39 in the world.
    The previous E39 record was 11.28 in the 1/4 mile. http://www.bimmerforums.com/forum/showthread.php?2108270-Worlds-quickest-and-fasted-1-4-mile-E39
    So the first E39 to break into the 10's
    Hopefully I can get it into the 9's with some more adjustments & seat time :-)
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Automatic. How much power you making ?
    Sep 2013
    Denmark
    1998 540i
    Yes auto
    I haven't got it dynoed yet sorry
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Quote Originally Posted by Happy D View Post
    Yes auto
    Good work
    Sep 2013
    Denmark
    1998 540i
    Missouri
    '02 540i/6
    Congrats. Mods?
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
    Sep 2013
    Denmark
    1998 540i
    It's a crossbreed :-)
    2JZGTE build engine
    Mercedes Amg transmission 722.6 (NAG1)
    M5 rear
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Sweet! That is a fantastic 60 ft for that type of a setup. Have you done anything to your rear suspension or M5 diff to set it up for drag racing?
    Sep 2013
    Denmark
    1998 540i
    I think the 60 ft can be done a little faster with some more tuning on the launch control. But I'm very pleased with this 60 ft no doubt.
    The rear is stock m5, some oem dampers with aftermarket lowering springs. The camper is set to 1.5 (it couldn't get closer to zero)
    / Danny
    DeWitt, Michigan
    How did you choose to go with that transmission?
    Miami,FL
    Turbo E39/06 525i
    Nice work.
    Sep 2013
    Denmark
    1998 540i
    Quote Originally Posted by tptrsn View Post
    Because they are really strong stock and I'm living in Europe so they are easy to get here.
    DeWitt, Michigan
    How do you have your trans controller setup? Is it getting some information from your engine controller?
    Sep 2013
    Denmark
    1998 540i
    Yes my tmc get a few information from the ems
    They are both stand alone units.
    / Danny
    DeWitt, Michigan
    That's sweet! I'm interested in reading all of the details you are willing to type!!
    Sep 2013
    Denmark
    1998 540i
    It was the plan to make a build thread. But haven't had the time to make one yet.
    Somethings specific you wanna know?
    Always willing to help out if I can
    / Danny
    DeWitt, Michigan
    Just general curiosity about pretty much everything having to do with your powertrain and how you control it. So, engine to transmission adaptation method, ECU, TCU, and communication between them. Plus anything else you would like to tell!
    Sep 2013
    Denmark
    1998 540i
    The engine is controlled by Ecumaster's EMU stand alone EMS, it's really a good and user friendly unit, I have nothing bad to say about it & there's a lot of support on them (Have tried HKS f-con pro, AEM, ProEfi on my previous cars. So not my first ems)
    The transmission is controlled by a plug and play unit for the 722.6 / NAG1
    Purchased here ofgear.dk
    It only need tps, map, rpm, speed signals (rpm & speed are optional because you can settle with the info from internal speeds)
    This unit will make the 722.6 / NAG1 tranny shift really really fast and firm & because it have a map sensor you can set it up to only shift hard when the car is on boost (how hard on what boost is up to you) and there is also a manual function witch is also really good and fast. I have the stock Bmw auto shifter with the manual shifting to the left and paddles in the steering wheel, with both working.
    In the video I shift gear manually because I haven't set the auto on full throttle up yet.
    I made an adapter plate between the engine and gearbox & modified the Toyota flexplate to fit the Mercedes converter ( so it's easier to order a custom stall converter )
    Any 722.6 / NAG1 transmission is useable and really strong, the MB's should be better than the US ones, because the clutches are made in Germany & the US ones are from China from what I can read. But if it's from a turbo diesel or a srt8 it should be fine I guess. Those diesels are torque monsters.
    / Danny
    DeWitt, Michigan
    Thanks Danny, that is great info, and now I have some reading to do about that trans and ofgear.
    Do you happen to have any pics of your adapter plate or flexplate modifications?
    Danny, it seems there are lots of those 722.6 transmissions over here too. Which version are you running (722.6xx)?
    Apr 2006
    Minnesota eh?
    86 325es
    That's the trans used in the newer chargers/challengers and jeeps. I have talked to someone at the track with one in a jeep SRT8 that was running mid 10's. From what I have read on them they are pretty stout in stock form but they are extremely expensive to upgrade once that limit is reached. If your looking for more power than what a stock unit can handle a 4L80e might be a more ecconomical choice.
    To the OP, I love the car! Would like to see some more details and pictures if you have them.
    Sep 2013
    Denmark
    1998 540i
    Yes there's a lot of models
    Mine is a 722.636 if remember correctly:-)
    But a 320cdi is making over 800Nm when chip/ecu tuned and have no problem holding the power.
    But how much can the stock handle before it needs an upgrade?
    The jeep srt8 is a really heavy car so it's harder for the tranny.
    But so is a SL, S, CL AMG & they are producing 8-1000 Nm stock
    If they need to get upgraded it can be done fairly easy.
    The 4L80e from what a can read supposed to be extremely strong, but haven't had any experience with it because I'm living in Denmark/Europe they are not so common here.
    Regarding pictures
    Let me se what I have, or else I can take some when I have the opportunity.
    Apr 2006
    Minnesota eh?
    86 325es
    I completely understand using locally available parts! I just meant that tptrsn might be better off with something that is more available in the states. I really like this build. It looks like the 722.6 is pretty compact as well. It must fit in the tunnel pretty well? What kind of car did yours come out of? Was your trans controller plug and play or did you have to reverse engineer the valve body?
    In stock form a 4l80e will handle about 700 ft lbs, which is about 950 nm. They are extremely common here and cost about $300 in used condition, and can be rebuilt with about $250 in parts. With about $1000 in upgraded parts that you can install at home they will handle 1000 ft lbs, which is about 1350 nm. For a few thousand dollars you can buy one that will handle 2000 HP with a transbrake. A 4l80e is a overdrive version of a TH400 which is a non electronic 3 speed which dates from the 60's. The TH400 is the most popular drag race transmission here. They are so popular you can build a brand new one with 100% aftermarket components. I am working on making an adapter to install one in my car now.
    Sep 2013
    Denmark
    1998 540i
    It fit perfect in the tunnel no mods needed.
    My tranny is from a clk 55
    The controller is plug and play only a few signals needed. The engineer behind this controller build his own because he wasn't full satisfied with the PCS TMC 2000 he installed in his car at first.
    Paramount upgrades the nag1 over there.
    We have a guy here turbobandit.com upgrades them here, but haven't been a issue yet.
    The 4l80e sounds like a good and safe choice over there.
    Apr 2006
    Minnesota eh?
    86 325es
    Thats a pretty good deal for a 1200 hp capable trans!
    http://turbobandit.com/Mercedes-Tran...ission-722dot6
    The controller is pretty fairly priced to
    http://turbobandit.com/Mercedes-Tran...7226controller
    I think this would be pretty popular here if somebody made adapters for these to bolt to a S50.
    DeWitt, Michigan
    Good info in here, thank you both!
    The 80e has always been my wishlist trans if I wanted an overdrive auto that can handle a lot of abuse, and it probably still is because of how cheap and available they are here, PLUS they can be controlled nicely and very cheaply by MegaSquirt2. However, I am very intrigued by the 722.6 now, and I've been reading up on it.
  1. Fastest & quickest 1/4 mile e39 body?
    By Happy D in forum Drag Racing
    Last Post: 07-20-2016, 06:16 AM
  2. Worlds quickest and fasted 1/4 mile E39?
    By M5Hunter in forum Drag Racing
    Last Post: 07-17-2016, 08:03 PM
  3. Replies: 0
    Last Post: 09-04-2012, 05:46 PM
  4. E39 Getrag 6spd S6S 420G *Very Low Miles* E39
    By rcrad6653 in forum Drivetrain & Transmission Parts
    Last Post: 08-22-2009, 08:15 AM
  5. E39 Complete 120k mile e39 M5 exhaust cats, resonator, mufflers.
    By gt40mki in forum Engines, Performance Parts & Software
    Last Post: 10-15-2008, 10:59 PM
