Results 1 to 13 of 13
Thread: Need help can brake signal BMW 323i e46
    Aug 2016
    Brasil
    Bmw 323i e46 sallon 2000
    Friends , Need for help my bmw e46 323i 2000 AT
    going to work appeared transmission error on the panel (!) Exclamation , transmission continues to operate normally , did not enter emergency mode, the gears go perfectly , the problems are now autopilot stopped working, I do not need transmission step brake to unlock transmission, checked the error by obd
    Transmission 151 CAN: Brake Signal
    something is sending the message to the transmission module that I'm always tight brake, bought a new brake pedal sensor , tested transmission module that I took the e46 friend to do the test did not solve , I tested all rear lamps , rear lamps function normally when flooring the brakes, checked plugs, put new battery, alternator carrying perfectly , I do not know what to do, someone could help with this problem ?
    Dec 2013
    Chicagoland area
    EXOTICS
    Research this, it may solve your problem:http://www.pelicanparts.com/BMW/tech...eplacement.htm
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the MAF. If the MAF is operating improperly it can prevent the cruise control from operating. The pins in the connector at the MAF can become loose over time. Also, the "cog of death" means the tranny computer needs to be scanned.
    Jun 2018
    Hellas
    Bmw 320 e46
    Hello guys i am new here and i have the same problem with AndreArgenta ...anyone with this problem or a way to fix it?because the most car mechanics said transmission failure but the a/t works fine
    Sep 2017
    California
    E39b54 e21b18 e39b25
    Hello I have the same issue with my e39 m73tu anyone find a solution to this??
    Aug 2019
    Espaņa
    328CI E46
    Good afternoon, I have the same problem, did you solve it?
    Aug 2019
    Espaņa
    328CI E46
    Nobody knows? I need help please
    Aug 2019
    Espaņa
    328CI E46
    Nothing?
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    What codes are you getting in which modules? What are your exact symptoms? Which model/year/transmission car do you have?
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Aug 2019
    Espaņa
    328CI E46
    In DME: 27[39] plausibility, signal, brake-light switch/brake-ligth switch test.
    In EGS: 97[151] CAN brake signal
    328CI E46 1999 automatic (ZF)
    cruise control doesnt work
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    You have a faulty brake light switch. The brake test switch side is faulty, common problem. Change the switch and your cruise control will work again.
    To remove the brake switch:
    - pull the white plunger out about 20 to 25 mm. The brake peddle will need to be pushed down and held down
    - pull the red collar out. This will release the black plastic tabs to be pushed in to remove the switch
    Aug 2019
    Espaņa
    328CI E46
    Hi, that's not the solution, I've already tried with 4 different new switches. One of them is the one that carries my X5 e53.
    Australia
    e46 323
    Hi Andre did you ever find the cause of the problem? I have exactly the same issue. If you found the solution id love to know.
  1. 2000 BMW 323i e46 help wit front end
    By Beamerfast in forum 1999 - 2006 (E46)
    Last Post: 07-11-2016, 05:12 PM
  2. E46 2002 BMW 323i E46 - - - Parting Out Entire Vehicle!!
    By MechTek in forum Whole Parts Cars
    Last Post: 03-25-2015, 07:47 PM
  3. E46 FS: 1999 BMW 323i, e46 Sedan, 5-Speed, Sport Package
    By lmbluke in forum 3 series & Z Series
    Last Post: 01-04-2014, 11:22 PM
  4. Replies: 7
    Last Post: 09-18-2013, 01:12 PM
  5. Replies: 14
    Last Post: 07-20-2007, 03:19 PM
