So after trying 2 different SRS scan tools, my 2002 Z3M still have the air bag on. I even tried clearing the system to see what it would do but the light is still on.
As background, the airbag light just came on one day. No work had been done to the car, nobody had been in the passenger seat, etc.
Any ideas?
Can you read the data stream?
/.randy
Okay. Sounds like you used a code reader rather than a scanner. Sometimes a code reader can't tell the difference between a computer that isn't responding and one that has no codes to send. That's why a scanner is helpful, you can look at the data stream and if it appears rational you can assume the computer is at least partially alive.
/.randy
