Results 1 to 3 of 3
Thread: Changing battery on 2003 745li
    Jul 2016
    Lakeland, Florida
    2003 745li
    I can perform the battery change out without a problem. However, the local dealer says the electronics would have to be re-callibrated once the new battery is installed. The dealer wants $750 (including the new battery) to perform the change out. Is reprogramming the electronics absolutely necessary?
    Also, the high fan mode on the a/c does not function. Medium fan does. I read that there is a function on the A/C system that prevents the HIGH FAN mode from operating if the battery is low so the high fan mode doesn't drain the battery thus indicating a need to relace the battery.
    Does anyone have suggestions: A) replace the battery, B) may need to re-program electronic, and C) how to test the high fan mode, if possible, prior to changing battery or change battery and see if high fan mode works.
    Live in FLA and battery is 8 years old. Appreciate any input. Thanks.
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    8 years out of a battery is pretty good... most I have ever gotten down here is 3. It's like clockwork.
    $750 to change a battery seems a bit steep. You probably can buy the battery and swap it in/out on your own and have them reset the computer calibration for you for significantly less.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Find a reputable indie shop that specializes in BMWs. Try www.bimrs.org. Also, contact the local chapter of the BMWCCA for recommendations. There are a ton of BMWs in south Florida and I bet there are many great indie shops. $750? Ridiculous.
  1. Need info on 2003 745Li before I pull the trigger
    By LoMile745Li in forum 2002 - 2008 (E65, E66)
    Last Post: 07-11-2011, 10:12 AM
  2. Need info on 2003 745Li before I pull the trigger
    By LoMile745Li in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-19-2011, 07:06 PM
  3. Changing batteries on the key
    By bimmerfreak187 in forum 1995 - 2001 (E38)
    Last Post: 05-25-2011, 12:17 PM
  4. how do you change battery on key remote ?
    By BMW M7 in forum 1995 - 2001 (E38)
    Last Post: 10-02-2008, 10:51 AM
  5. Changed ATF on 2003 / 530
    By Doru in forum 1996 - 2003 (E39)
    Last Post: 10-21-2007, 07:41 PM
