Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 21 of 21
Thread: ► APEX | ARC-8 Light Weight Track Wheels
    California BAY AREA
    e30 M3, 335d
    APEX ARC-8 Wheels
    We are proud to continue offering our timeless ARC-8 wheel. This new wheel addresses the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. With the increase of faster and heavier cars being used in racing, HPDEs, and spirited driving, the ARC-8 was designed and engineered to handle extreme abuse on track and street, offer a wide range of direct fitments, while still producing a lightweight wheel.
    Visit our website to order
    The Good Stuff
    1. They Fit Everything
    The ARC-8's wide range of widths, diameters, offsets and face profiles result in 26 unique BMW fitments ranging from 8.5" to 10.5" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model.
    2. Factory Support
    Like all our APEX wheels, The ARC-8 supports all OEM hardware like OEM Roundel center caps, wheel lugs, valve stems, and TPMS sensors. No centering rings are needed either, as all of our 5x120 BMW wheels use a 72.56mm center bore.
    3. Brake Clearance
    ARC-8 wheels properly clear all OEM brake calipers. Our wheels are targeted at the serious performance-minded owner. The spokes of the flatter faced ARC-8 were designed to clear big brake kits, making it a better choice for BBK equipped cars. The concave version of the wheel is the best option for cars with factory brake calipers.
    4. Concavity
    The ARC-8 wheel is available in two unique face profiles. The shallower face provides increased caliper clearance on narrow applications, while the deeper concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. These two face profiles are available in all 17", 18" and 19" diameters.
    Designed for the Performance Enthusiast
    Light-weight
    Flow-forming allows for a significant reduction in rotational mass by reducing barrel weight. This manufacturing technique allows our wheels to be almost as light as a traditional forged wheel, but without the significant increase in price.
    Strength
    Track duty requires a wheel that can handle the punishment of high lateral G's, hitting berms, and every once in a while, a small off track excursion. Spoke and barrel design are a major factor in wheel strength. The flow-forming technique uses high pressure disks/rollers to roll the wheel's barrel into its final shape. This gives the barrel the same strength properties as a forged wheel, since monoblock wheels go through a similar step to form their barrels. We design our spoke dimensions to help evenly distribute loads from the barrel to the center of the wheel. The lack of a front lip, and spokes directly connecting to the edge of the wheel, also add increased strength to the outer lip of the wheel.
    Chassis-Specific Fitments
    Stretched rubber, narrow tires, and fender rubbing are not elements to look for in a competitive wheel/tire setup. All of our wheels were designed with offsets that allow for proper fitment of extreme summer, and r-compound tires without the need for spacers or fender rolling. This means keeping the tire under the fender, and away from suspension components. Track oriented wheel widths are also important as they provide proper sidewall support under hard cornering. Too much rubber for a wheel results in excessive sidewall deflection, which translates into sloppy and delayed turning response.
    Multiple Fitment Options
    Most BMWs come with a staggered setup from the factory. Some choose to keep their car this way, while others like to switch out for an easy-to-rotate, square/neutral setup. This is generally based on driver's preference and consideration of tire costs. Most BMW chassis benefit from being able to fit both square and staggered setups with relative ease. 9.5" or 10"-wide square setups are great for budget minded enthusiasts who want to extend their tires life by rotating between events, in addition to preferring the feel of a square setup. Square setups are popular on all models for track use due to the significant increase in front grip and turn-in response. Some owners comment that due to the extra power of their cars, a square setup will lean towards oversteer. For those who prefer more rubber in the rear, a staggered setup is the way to go. Wheels up to 10.5" wide are available for rear fitment. These can be combined with 9" or 9.5" fronts for a bolt-on spacer-free staggered setup.
    Open-Hub Center
    Race wheels can't just be light, they need to function in a high performance environment. Unlike the narrow lug recesses of most other wheels, the ARC-8 wheel boasts a completely wide-open design that easily fits over-sized race lugs and beefy impact sockets. This allows for quick and easy wheel changes at the track, and as a bonus prevents chips and scratches from tools for those just running these wheels on the street.
    The APEX Standard
    1. FEA Optimization
    Various design features were implemented to ensure that the ARC-8 wheel design was as light and durable as possible. We began with a strong one-piece design featuring an open hub center and reliefs in the mounting pad to remove weight between lug holes. The design was then run through Finite Element Analysis (FEA) to further optimize the spoke and barrel design. The result is a light weight wheel with extra strength in all the right places, while keeping weight to a minimum.
    2. Always Flow Formed
    All APEX wheels feature Flow-Formed construction tha utilizes rotary forging to produce a strong and lightweight barrel. The ARC-8 is no exception.
    3. True JWL & VIA Certification
    Strength needs to be certified. Our wheels were not simply FEA tested in a computer simulation, or in-house tested to an unregulated standard. We conduct real-world crush-testing and all of our wheels conform to Japan's JWL standard, as well as being 3rd-party tested by the VIA. All of our wheels carry a 690KG load rating.
    Available Finishes
    Note: Not all sizes are available in all finishes.
    Face Profiles
    Sizes, Weights, and Pricing
    17" Sizes
    18" Sizes
    19" Sizes
    Questions about tires, fenders, brakes, spacers, or suspension clearances?
    Click here to get a personalized fitment recommendation from one of our experts.
    On-Car Photos
    Shown above: E46 M3 with 18x9.5 ET35 and 18x10.5 ET27 with 245/40/18 and 275/35/18 tires.
    Shown above: E90 M3 with 17x10 ET25 with 275/40/17 tires all around.
    Shown above: E92 M3 with 18x10.5 ET27 with 285/30/18 tires all around.
    Check out our extensive collection of photos on our Flickr page. See more ARC-8 photos >>>
    Tire Mounting and Balancing Service
    Popular street and track tires are now available when you order APEX wheels. Add tires with your wheel order and get free tire mounting and balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. With our competitive tire pricing bundled with the savings of free mounting and balancing and convenience, it’s the ultimate wheel & tire package.
    *Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be cancelled and refunded.
    Available Tire Brands:
    Ordering and Contact Information
    • Hours: Monday - Friday, 9AM to 6PM PST
    • Shipping: All orders are shipped directly from us via UPS. Local pickup also available at our Livermore, CA Warehouse. (Map It)
    California BAY AREA
    e30 M3, 335d
    Feel free to give us a call with any questions regarding fitment or availability.
    California BAY AREA
    e30 M3, 335d
    Need help deciding on wheel and tire sizes? Use our Fitment Recommendation form and we'll help you find the perfect setup based on your needs!
    California BAY AREA
    e30 M3, 335d
    Check out this E92 M3 with 19x10 ET25 ARC-8 wheels all around.
    California BAY AREA
    e30 M3, 335d
    Here are some 17x10" ET25 ARC-8 wheels all around with meaty 275/40/17 tires.
    Give us a call or PM if you have any questions about what fits your car.
    California BAY AREA
    e30 M3, 335d
    Check out the concavity of these 18x9.5" ET35 ARC-8 wheels with 255/35/18 tires on a 330i sedan. A heavy fender roll in the rear was required to fit this setup.
    California BAY AREA
    e30 M3, 335d
    Here are some 17x9.5" ET35 ARC-8 wheels doing their thing.
    California BAY AREA
    e30 M3, 335d
    Concave ARC-8 wheels on an M roadster are a real treat. This setup consists of 18x9.5" ET35 up front and 18x10" ET25 in the rear.
    California BAY AREA
    e30 M3, 335d
    We love the functional look of these 18x9.5" ET35 ARC-8 wheels.
    California BAY AREA
    e30 M3, 335d
    TIRES NOW AVAILABLE
    • Michelin Pilot Super Sport
    • Michelin Pilot Sport 4S
    • BF Goodrich g-Force Rival S
    • BF Goodrich g-Force Rival S 1.5
    • BF Goodrich g-Force R1S
    View Complete Tire Selection
    Add tires to your ARC-8 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
    California BAY AREA
    e30 M3, 335d
    Strong, light, affordable. Choose three.
    California BAY AREA
    e30 M3, 335d
    Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
    Jun 2015
    Ontario, Canada
    1998 M3 5-Spd Coupe
    Hey, what are the specs on this setup? Looks amazing IMO.
    '92 325is 5-Spd, Mauritius Blue, 135k - R.I.P.
    '94 325is 5-Spd, Jet Black, 224k - Sold
    '98 M3 5-Spd, Estoril Blue, 235k - Current
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by Remer77 View Post
    Which setup are you referring to?
    - Max
    Jun 2015
    Ontario, Canada
    1998 M3 5-Spd Coupe
    Quote Originally Posted by Eddy@ApexRaceParts View Post
    - Max
    Hey Max, sorry I was referring to the Estoril E36 M3. Didn't realize the initial post didn't get attached.
    Aug 2013
    1999 BMW M3 Coupe
    It looks like those are the 17x9 ET30 concave wheels. I have the ET42 versions because it's easier to get them to fit on an E36, and you can fit wider tires on them. The ET30's require a fender roll (and likely some ride height adjustment) to fit in the rear with a 245 tire. They do look nice though.
    1999 M3/2/5 - Titanium Silver - Daily Driver and Track Toy
    California BAY AREA
    e30 M3, 335d
    No worries! That car was actually featured on our blog which I will link to below if you are interested in specifics on this build.
    CHANDLERíS ESTORIL BLUE E36 M3 WITH ARC-8 WHEELS
    The car is running our 17x9 ET30 ARC-8 wheels with a 245/40-17 on all four corners. No spacers required for this fitment, but you will need to roll your rear fenders in order to clear this fitment.
    I hope this helps!
    - Max
    California BAY AREA
    e30 M3, 335d
    Check out this solid staggered fitment:
    Front:
    APEX 18x9.5" ET22 ARC-8 Wheels
    265/35/18 Yokohama AD08R Tires
    Rear:
    APEX 18x10.5" ET27 ARC-8 Wheels
    295/30/18 Yokohama AD08R Tires
    Owner: @jezz33 on IG
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    can you fit 17*9 Et30's on a stockish bodied e36 with 245 hoosiers?
    Fenders are rolled pretty hard. Can't pull them too much per class rules.
    Pelase advise.
    99 M3 STU/ GTS3 Project
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by NotoriousJJE View Post
    Pelase advise.
    Thanks for the post! With 245 Hoosiers on the 17x9" ET30, you'll very likely need to pull the rears a bit. The 17x9" ET42 can fit them however with a pretty standard fender roll, although this fitment requires 12mm front spacers for suspension clearance.
    Check out our thread here for tons of information on fitting these tires: https://www.bimmerforums.com/forum/s...-Fitment-Guide
    --Dylan on behalf of Eddy
    California BAY AREA
    e30 M3, 335d
    19" ARC-8 wheels on E46 M3
    Front: 19x9" ET28 with 255/35-19 tires
    Rear: 19x10" ET25 with 275/30-19 tires
    Spacers: None
  1. 17x9", 17x8.5" light weight track wheels APEX ARC-8
    By paintpro21 in forum Wheels and Tires
    Last Post: 12-18-2016, 02:51 AM
  2. ► APEX | ARC-8 Light Weight Track Wheels
    By Eddy@ApexRaceParts in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-06-2014, 05:25 PM
  3. APEX ARC-8 light weight Track wheels (1000+ wheels in stock ready to ship)
    By paintpro21 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 08-14-2012, 08:22 PM
  4. New 17x8, 17x8.5, 17x9" light weight track wheel: APEX ARC-8
    By paintpro21 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-17-2010, 08:02 PM
  5. NEW 17x8" et20 light weight track wheel APEX ARC-8
    By paintpro21 in forum 1982 - 1988 (E28)
    Last Post: 01-30-2009, 10:33 PM
