Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 103
Thread: Affordable angle kits for the E30/36/46
  1. #76
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I take it the problem with your tig welder is that it only runs on 220V? I can vouch for the fact that you don't need any significant amperage to tig up exhaust. I have blown my 110V breaker a few times when floorboarding my tig welder while welding my diff, but other than that I have been able to continue to be completely lazy about getting a proper 220V circuit installed out to my garage. And if I can be lazy, I will. Haha
    Those lego kits are cool AF as the kids say, but damn, kind of pricey...
  2. #77
    Jan 2014
    San Antonio
    98 328is
    i may be interested in this in a few months when you get all the little pieces together.
  3. #78
    Jun 2005
    Lincoln, NE
    E34, E36, E36/7
    can confirm. kits work and kept me from spinning out. the name fits.
    13 Grand Cherokee Limited V8 - Daily Driver - Wife
    97 Z3 2.8 Roadster
    95 325i Sedan - Project #ebayE36
    90 BMW 535i/5 - i should probably work on this again...
  4. #79
    BALTIMORE
    Quote Originally Posted by tptrsn View Post
    Yeah, it runs on 220, plus the gas tank I use is humongous, I believe it holds 300 cubic feet of Argon. The deal was too good to pass up on it, but the downside is it's not exactly easy to move around, definitely too much of a PITA to get to my house
    Quote Originally Posted by RandomHero27 View Post
    What specifically do you mean by little things? Like a bolt-on tie rod solution or something? I don't think I'm missing anything else, though sometimes it's hard to see the forest for the trees
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
  5. #80
    Jan 2014
    San Antonio
    98 328is
    Quote Originally Posted by jalopi View Post
    and you mentioned a bolt on spacer for caster angle.
  6. #81
    BALTIMORE
    Aah, I meant a specifically cut piece of metal to use in a DIY extended control arm scenario
    The idea is that if you want to weld your arms up yourself, these will save you the hassle of cutting and beveling 3/4" steel. The edges were beveled at a 45* angle on a mill, which gives you plenty of room to get a good root weld in. Let me assure you that grinding steel this thick by hand is not a pleasant experience. Pretty sure pricing will be half a C note, shipped
    LS,
  7. #82
    DeWitt, Michigan
  8. #83
    BALTIMORE
    Whelp, I've got all the low ackerman blocks powdercoated
    I left the stock ackerman blocks in their sandblasted form as roadrace guys didn't seem too keen on the drifty color scheme. People will have the option of getting the blocks powdercoated in their color of choice or leaving them as-is at an adjusted price
    This week I'll be working on taking pictures and making a website, then I'll officially be in business!
    LS,
  9. #84
    Jun 2005
    Lincoln, NE
    E34, E36, E36/7
    Looks awesome. nice work.
    97 Z3 2.8 Roadster
  10. #85
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Hey Dave,
    have you considered making steering rack travel limiters for the roadrace guys/gals? we don't need 400* of steering angle. just the bumpsteer/rollcenter correction and the quicker ratio. it's just a thought since you're on the path to cover all bases.
    ~Chris
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  11. #86
    Jan 2017
    Chicago
    06 325ci
    These look awesome! New to the site here so very unfamiliar nn how to work things usually I'm just a ghost and read posts. But, I'm very interested in a set!
  12. #87
    BALTIMORE
    Quote Originally Posted by doktor b View Post
    Hey Dave,
    ~Chris
    I sure have Chris, but I'm a bit undecided as to how to go about it. I did prototype some clamp-on rack stops for ultimate adjustability, but they can be moved with enough steering effort. I'm also not too keen on the idea of simply cranking out generic stops, as depending on peoples' wheel/tire/offset setups the amount of travel that needs to be limited can vary greatly. Or are wheel/tire/offset combos more generic in the roadrace scene? If so, I could probably have limiters ready within the next month or two
    Quote Originally Posted by Stewzilla View Post
    Glad to hear it man! I just bought a website domain and am currently working on getting it up and running. Keep an eye on this thread, I'll let everyone know when I'm ready to start accepting orders!
    http://www.bimmerperformance.com/
    LS,
  13. #88
    Arvada, CO
    LS6 E36 drifter, 18 f350
    Ok, I read the post. my goals: Build a super low budget set of drift missiles (3 or 4) for us to practice on. Im not looking for competition setup here. With that said,
    Can someone answer this question: How do you account for the loss of caster?
    -This looks like it moves the bottom of the strut backwards therefore removing caster. From my experience caster and ackerman are what determine the "self steer" effect. How do these feel? Has anyone ran these vs a cut knuckle or just a real kit (wisefab or SLR)? Just checking.
  14. #89
    BALTIMORE
    Good question - yes, the blocks do reduce caster by nature. Caster is recovered with my control arms + off-the-shelf offset control arm bushings
    Caster is near stock with my blocks/arms plus bushings
    LS,
  15. #90
    May 2017
    Barstow
    E30 318
    Can I pick up a set of these from you?
  16. #91
    BALTIMORE
    Sure thing, just sent you a PM with more details
    LS,
  17. #92
    Dec 2013
    Redmond, OR
    96 328IS, 08 IB E92 M3
    Quote Originally Posted by jeepster View Post
    I don't want to thread jack or get off topic here, BUT... I would steer clear of Wisefab products, IMO. Their arms fold like pretzels in even minor collisions/off road happenings. It is a product of poor structural engineering in my eyes! That is all.
    Anthony Bartolini
    Loki Motorsports
    -2008 A30 E92 M3 6MT-
    -1996 328is Drift Car-
    Stock Internal M52
    M50 Manifold
    PTE 6262, ARP's, .140 MLS
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  18. #93
    fairfax,va, usa
    2 E30s and a maxima
    I'd rather the suspension bits break/bend than my car. I consider that a pro and not a con.
  19. #94
    Dec 2013
    Redmond, OR
    To each their own I guess. I'd rather nothing breaks, because it was engineered correctly. The SLR arms really are a great structural design. It would just suck to cough up X amount of money for an angle kit, just to have it break the next time you run over a grain of sand.
    All jokes aside, I have just had/seen bad experiences with their products. I'm sure it works amazing for some people! I do not however, like their ackerman/caster configuration. That's personal preference I guess though!
    Anthony Bartolini
    Loki Motorsports
    Stock Internal M52
    M50 Manifold
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  20. #95
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Are you still selling these? I’m doing coil overs in the next month and quicker steering would be great for autocross.
  21. #96
    BALTIMORE
    I sure am. I'm not sure if they'll work with your setup though, do you have enough clearance to lose (with offset CABs) .45" of rearward wheel well clearance?
    LS,
  22. #97
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    I'm not really sure at this point. I have centered delrin CABs yet to be installed, but could probably swap those for offset.
    What are the effects on ackerman, caster, and bump steer if I keep the stock control arms and just do offset CABs?
  23. #98
    BALTIMORE
    It's the same as if you had offset CABs and extended control arms, only with less caster and less wheel clearance. I really don't recommend centered CABs with these blocks, with those you lose about .9" of rearward wheel clearance
    LS,
  24. #99
    Sep 2012
    Are these still available? I’m not new to drifting but new to drifting with an e30 and would like more info
  25. #100
    BALTIMORE
    Yeah, but I won't be ready to sell any parts until the first/second-ish week of July. Currently homeless and living out of a box truck. Once I get my parts in a few weeks I'll be running a fire sale to free up some space. Estimated pricing will be $150 for the angle blocks, $20 for DIY control arm extensions, and something in the ballpark of $200 for the pre-extended control arms. Final price on the control arms will depend on how far away you live, as shipping those can get expensive. We'll see. I'll post a thread about it once I'm ready to sell
    LS,
  1. Is Vorshlag E30/36/46/Z3 RSM reinforcement kit worth it?
    By gorillajin in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2013, 07:09 AM
  2. E30 FS- Fab 666 S/M50/2 top manifold for the E30
    By new guy in forum Forced & Chemical Induction Parts
    Last Post: 05-22-2011, 02:26 AM
  3. Rogue Engineering RSM set for E30/36/46/Z34
    By atropine in forum Suspensions, Springs & Shocks
    Last Post: 12-04-2010, 08:58 PM
  4. where to buy suspension kit for my E30 just to lower the car
    By M3isgod in forum 1983 - 1991 (E30)
    Last Post: 10-16-2007, 05:02 PM
  5. H&R cup kit for the e30, what do you guys think?
    By Flip_Side_the_Pint in forum 1983 - 1991 (E30)
    Last Post: 06-18-2003, 03:30 PM
