Results 1 to 11 of 11
Thread: RK TUNES OBD2 E36 TURBO TUNE - No Longer Available
    Upstate
    E28
    For sale is an OBD2 Siemens ECU with RK Tunes Turbo tune. This should work with any M/S52 engine that has an OBD2 harness/sensors.
    Tune specs:
    Fuel: 93 octane + meth
    80lb injectors
    HPX MAF
    Injectors, MAF, gasoline, methanol are not included, just the ECU with the tune loaded on it.
    $300 shipped OBO
    NOTE: I do not accept payment through panjo, PM me on bimmerforums if interested, thanks.
    List Date: 7/26/2016
    For more info, click here to view the original listing: RK TUNES OBD2 E36 TURBO TUNE
    This item is no longer available.
    Nov 2003
    MIAMI
    E92 JB M3
    How many psi?
    Upstate
    E28
    Quote Originally Posted by blown330 View Post
    How many psi?
    Lots of them.
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by cj.surr View Post
    Lots of them.
    And all of them.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Mar 2013
    gatineau
    1998 bmw 328is
    Hey CJ I have your ECU now and if you don't mind I have few questions about it .... it's already in the car and running but some how I'm pretty lean on 16-17psi and maybe I did something wrong and you can help
    Will be appreciated
    Thx
    Upstate
    E28
    Make sure you are running water/meth - 50/50 will help richen it up compared to just washer fluid. Also monitor your fuel pressure under load.
    Mar 2013
    gatineau
    1998 bmw 328is
    I m not running meth yet , I was planing to do that when I'm in 20psi range
    Soon I start going over 10psi it's getting lean 12.5 to even 13...
    I didn't expect that with 80lb injectors
    Mar 2013
    gatineau
    1998 bmw 328is
    Is the Tune made to run meth over 10 psi?
    Mar 2013
    gatineau
    1998 bmw 328is
    Did You purchased new from RK tunes ?
    Jordan he's asking from who I got it from , I guess to check the file ....
    Can you please text me at 819 230 7575 ?
    Mar 2013
    gatineau
    1998 bmw 328is
    Upstate
    E28
    Yes, meth over 10psi. It will change your AFR. If you still have issues then monitor your fuel pressure under load. If you still have issues after that, call Jordan.
  1. OBD1 RK TUNES m/s5x TURBO TUNES - 93 and E85 - No Longer Available
    By cj.surr in forum Forced & Chemical Induction Parts
    Last Post: 08-02-2016, 10:34 AM
  2. obd2 m52 turbo tuning?
    By LoudLowNslow in forum Forced Induction
    Last Post: 01-23-2015, 01:28 PM
  3. Replies: 6
    Last Post: 07-14-2014, 01:50 PM
  4. OBD2 E36 Turbo 3.0l tune on 3.2l motor?
    By m3mods in forum Forced Induction
    Last Post: 01-28-2014, 08:26 PM
  5. Replies: 1
    Last Post: 12-01-2009, 12:31 PM
