RK TUNES OBD2 E36 TURBO TUNE
For sale is an OBD2 Siemens ECU with RK Tunes Turbo tune. This should work with any M/S52 engine that has an OBD2 harness/sensors.
Tune specs:
Fuel: 93 octane + meth
80lb injectors
HPX MAF
Injectors, MAF, gasoline, methanol are not included, just the ECU with the tune loaded on it.
$300 shipped OBO
NOTE: I do not accept payment through panjo, PM me on bimmerforums if interested, thanks.
List Date: 7/26/2016
For more info, click here to view the original listing: RK TUNES OBD2 E36 TURBO TUNE
This item is no longer available.
How many psi?
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Hey CJ I have your ECU now and if you don't mind I have few questions about it .... it's already in the car and running but some how I'm pretty lean on 16-17psi and maybe I did something wrong and you can help
Will be appreciated
Thx
I m not running meth yet , I was planing to do that when I'm in 20psi range
Soon I start going over 10psi it's getting lean 12.5 to even 13...
I didn't expect that with 80lb injectors
Is the Tune made to run meth over 10 psi?
Did You purchased new from RK tunes ?
Jordan he's asking from who I got it from , I guess to check the file ....
Can you please text me at 819 230 7575 ?
