Results 1 to 12 of 12
Thread: More 330I woes...HELP?
    Jan 2016
    knoxville, TN
    02 m-spt 540. 04 330i
    just did a upper rad hose replacement, used hidden menu to access other temp readings and they are getting way hot. i read that somewhere between 90-95 is normal.... mine hit 105c before i switched it off. not getting heat either. even with the car all the way on 91
    the upper rad hose is way hot whereas the lower really isnt.
    could this be a water pump issue? what are signs of bad waterpumps? could i be losing coolant from there? could it be the thermostat? should i just replace both?
    i put more coolant in but it seems to be disappearing with no signs of a visible leak....
    Please help
    Mar 2015
    Texas
    2004 BMW E46 325xi
    Sounds like you didnt bleed it right. Its super easy. Let car fully cool down(overnight),Open hood, undo expansion tank cap, set aside, take out bleeder screw, set aside, put key in ignition, turn key all the way to position right before starting, Do not start car!, turn on climate control and set temp to highest degree, turn knob above it all the way to the red dot, now start filling the expansion tank with proper coolant/antifreeze mix until it starts coming out of the bleed screw with no bubbles, massage/gently squeeze upper and lower hose to help push out bubbles, put bleed screw back, put expansion cap on, go to test 7 on obc and test drive it. The car shouldnt get hotter than 103C. I live in one of the hottest cities in the country (110F daily) and my car never goes above 102C. Good luck. Also as a guide my car usually stays anywhere between 91-102C in city,freeway and stand still traffic/driving.
    Jan 2016
    knoxville, TN
    Quote Originally Posted by Pro325ie46 View Post
    what kind of coolant/antifreeze mix should i use?
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    BMW coolant, mixed 50/50 with distilled water
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Mar 2014
    Concord, CA
    1996 328i vert
    Once the car is cold the next day, just pop the cap of the overflow to burp any trapped air in the expansion tank, and then put any remainder of coolant required to the kalt line.
    Mar 2015
    Texas
    2004 BMW E46 325xi
    Quote Originally Posted by machinegundrew View Post
    most would say go with BMW genuine coolant mixed with distlled water(50/50) but i use prestone concentrate and i mix that with distilled water for a 50/50 mix.
    Mar 2015
    Texas
    2004 BMW E46 325xi
    just did a upper rad hose replacement, used hidden menu to access other temp readings and they are getting way hot. i read that somewhere between 90-95 is normal.... mine hit 105c before i switched it off. not getting heat either. even with the car all the way on 91 the upper rad hose is way hot whereas the lower really isnt. could this be a water pump issue? what are signs of bad waterpumps? could i be losing coolant from there? could it be the thermostat? should i just replace both? i put more coolant in but it seems to be disappearing with no signs of a visible leak.... Please help
    i just realized your the same guy who overheated your ride and blew your hose from your other post. I hate to say it man but your engine is probably done if its still overheating after fixing it and bleeding it correctly. You can test your thermostat and check the WP but its not sounding too good at the moment
    Dec 2013
    Chicagoland area
    EXOTICS
    Have a radiator/cooling system pressure test done, that should help answer most of your questions. Now, can you answer some of mine-What is the mileage on this car?, any sign of sweet smelling exhaust?, white smoke out of exhaust ?
    Apr 2009
    your cooling system will be full of corrosion in a few years.
    Current:
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Quote Originally Posted by legoman67 View Post
    Not if it was Preston Extended Life concentrate. It has the same anti corrosion inhibitors as the BMW coolant. Its virtually the same product. Preston green, yes it will corrode.
    Jan 2016
    knoxville, TN
    did cooling system overhaul. ran into some money and figured it was time. car runs great now with temps neutralizing in the mid 90 C highest at 100 in dead traffic with a.c on blast
    no disapperaing coolant and no dash lights. guess that m54 is a lil more durable than everyone thinks.
    current mileage at 139412
    Dec 2013
    Chicagoland area
    EXOTICS
    Good job! At 139k, it was long overdue.
  1. More ABS woes - Please HELP!!!
    By purEnergy in forum 1988 - 1996 (E34)
    Last Post: 10-01-2005, 11:42 AM
  2. more power... need help
    By djyoungz in forum Forced Induction
    Last Post: 01-13-2003, 11:11 PM
  3. handling woes, help plz
    By wewu in forum 1992 - 1999 M3 (E36)
    Last Post: 09-04-2002, 06:40 PM
  4. Replies: 6
    Last Post: 08-30-2002, 10:12 PM
  5. Oxygen Sensor Woes, help please
    By Phaedrus in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-31-2001, 09:49 AM
