Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 9 of 9
Thread: Paint correction
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Paint correction
    I have a Porter 7474 and I'm using a kit from Autogeek that I bought years ago. Came with an orange, blue, white pads. I don't remember the actual brand, but this is the process I used:
    1) Wash - 2 bucket method
    2) Clay with detailer (cut the clay in multiple pieces and use once)
    3) Orange to cut
    4) white for polish
    5) blue for finishing
    I'm a complete amateur at this, but I noticed I didn't do that great of a job on the swirl marks because they are still there. Here are my questions:
    1) Do I need to go with a more abrasive pad and/or agent? I've read the links above and will can give those a whirl
    2) When I'm at the polishing step, should all the swirls be gone already?
    3) How often should I replace the pads? Should I even try to clean them after use or just put them back in a plastic bag til next time? What is the proper way to clean the pads?
    4) Should I mask off all the black trim because it contaminates my pads?
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    You did not list any chemicals corresponding to pads you have used.
    Feb 2002
    Orlando, FL
    Quote Originally Posted by Mless5 View Post
    Sorry!
    3) Orange to cut - Pinnacle natural brilliance Advanced Swirl Remover
    4) white for polish - Pinnacle natural brilliance advanced finishing polish
    5) blue for finishing - Pinnacle natural brilliance liquid souveran
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    I'm an amateur also and have only used Meguiar's M105 and M205 compounds. My experience with those compounds has been that it takes much more time than you think to remove the swirls with the first compound. For me it would be the M105 and for you it would be the Swirl Remover. 1-2 passes just doesn't get it done, at least with my Harbor Freight DA polisher. Suggest you spend a little more time with your swirl remover and be patient. You should consider placing some tape across the panel to make it easier to compare to an un-corrected section to see if you are making progress. Don't move on to the next compound/pad combination until you are sure the swirls have been removed. Just my $0.02.
    Feb 2002
    Orlando, FL
    Quote Originally Posted by crazy4trains View Post
    Agreed, it is tough to see progress in the garage. I'm thinking of getting one of those light stands because i see the swirls clear as day direct sunlight. The entire process takes so long, I usually just do one pass, but if I want the right results, I don't move on until its fixed!
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    One pass won't get it done.
    Nov 2011
    Ft Lauderdale
    11 E90 M3, 01 740i Sport
    Im not familiar with that polisher but what speed are you using? A slow steady pass with medium speed should do the job. As mentioned, take your time, be patient and post your before/after shots!!!
    Feb 2002
    Orlando, FL
    Quote Originally Posted by EnVe46 View Post
    6 for swirl remover
    4 for polish
    3 for wax
    Peoria, AZ
    Quote Originally Posted by BMWManiac View Post
    6 for swirl remover
    4 for polish
    3 for wax
    Hmm, I usually do inverse of that: slower for more cut, faster for polishing/final LSP application. I stop at 4.5/5 though.
  1. Set-Up ok for Paint Correction......
    By M0nK3y in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 06-07-2008, 03:12 PM
  2. looking for a reputable detailer (paint correction) in the bay area
    By RidgeBack in forum California sponsored by Avus Autosport
    Last Post: 04-11-2008, 10:31 AM
  3. Surfside Detailing: Full Paint Correction 2006 IS350
    By stereooptions in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 04-06-2008, 02:07 AM
  4. Massive Paint Correction on a P-Car
    By pyiu2 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 01-06-2008, 10:24 PM
  5. Paint Correction Question
    By LUV4my5 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 08-14-2007, 08:39 AM
