Results 1 to 11 of 11
Thread: Drag Racing: Wheels or Differential?
    Jul 2011
    Ma/Nh
    95 325is m52 obd1 swap
    So I finally got my 95 m52b28 swapped e36 down to 14.220 @97mph!!
    it's taken some practice and some more modifications but I got it!
    Here's my question:
    I recently put in a 14.5lb flywheel and I believe that is one of the major improvements to my new ET, 60ft and Trap (Along with my s50 cams, tune and tms shorties)
    My question is, I have some funds and figured I'd love a 3.38lsd but they're pretty hard to come by, I know this would probably get me into the high 13's. So being that a 3.38 is hard to come by, would some lighter wheels, Kosei K1s to be specific help my times? My wheels now are 16x7.5 miglia mm2 which are about 20-21lbs, the kosie k1s are 15-16lbs at 16x7. I would likely run my current tires so lets say an ever 4-5lb weight reduction off of each wheel. How much will this help my 1/4?
    I recall seeing in the 1/4 N/A archives a 325 running k1s with a pretty good trap and et and alot of folks said the k1's were a great help!
    Any info or input?
    Thanks!
    95 328is: Obd1 M52B28, M50 Manifold, 21.5# Injectors, TMS Shorty Headers, S50 Cams, Obd2 m3 Mid Pipe, SS Rep Catback, Afe Magnum Force Intake, Spal Fan Conversion, TRM Chip, Full A/C Delete, ASC Delete, Cruise Delete, 3.15LSD, 16x7 Kosei K1, 225/50/16 Potenza Re760, 10mm Spacers up front, Billstein HD, Eibach Pro, F1 14.5# flywheel, F1 Stage 2 Clutch, Sick Speed Fixed buckets, Gutted, Miata Battery, CSL Trunk Lip, Dodge Viper Red. Car Weighed 2935# With me in it.
    1/4 Mile 14.220 @ 97.45MPH!!!!
    May 2016
    Canada
    Are Slower than yours.
    I'd get the diff.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Buy the wheels now and be ready to buy a 3.38 when one comes up cheap. After selling your 3.15 LSD, you might have only $150 in the 3.38.
    Jul 2011
    Ma/Nh
    Quote Originally Posted by MassiveWalrus View Post
    I'd get the diff.
    Problem is finding one. I have a lead on some 16x7 k1s
    That's what I figured
    Manchester, N.H.
    96 332IS 6466 turbo
    Your best bet, honestly..... More seat time. More practice.
    With a 14.2 now and a 2.0 or 2.1 60' , you could technically get into the 13's the way you sit. You learn to be consistent with your launches and use that hand brake you got there and wham, your at your goal. If you can shave that down to a 1.8 60', that should shave off 3-4/10ths. You'd be sitting at 13.8-13.9 right there.
    Sometimes , all the power in the world, all the best mods don't mean crap if you cant get that 60'-330' down. Also, make sure your running out 1st gear. Lots of guys nail it out the hole, get a good 60' but short shift 2nd and bog. This crushes your 330' which is just as important.
    My $0.02 is if you only have $XX dollars to spend, I would spend them on more track time. Wednesday and Friday nights.
    Are you spinning 1st gear ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Nov 2009
    I'm over here now!
    S52, 4g63, LS1
    you won't see any difference going from a 3.15 to a 3.38. with a 225/45/17 tire that will reduce your theoretical top speed from ~130mph to ~121 mph. with your 97mph trap that wouldn't make a lick of difference since either way you're shifting into 4th for only a short time before you cross the finish line.
    if you're going to switch your R&P, and this will be a drag car, you should consider something shorter like a 3.73 or a 3.91. both are pretty common.
    what size, compound and width rear tires are you running?
    Jul 2011
    Ma/Nh
    I am not spinning first, my fastest run was on saturday so it was mid 90s with a DA of 2200 IIRC, Cooler Temps should help. My Tire PSI was 29. I am currently running a 225/50/16 Toyo Extensa HP All Season they are a 91v and a 360aa UTQG if that matters.
    The Kosei k1's I am picking up have Bridgestone Potenza Re760 Sport tires, W Speed Rating and 340aa UTQG. Depending on which tire is lighter I'll likely swap the lighter onto the new wheels on my machine.
    May 2016
    Canada
    Quote Originally Posted by Matt325e View Post
    I just got the gears for about $150 at Diffs online.
    Jul 2011
    Ma/Nh
    Oh wow, so i'll grab the wheels, sell my other set of wheels and order a ring and pinion and some seals! Won't be my first ring and pinion swap so should be pretty straight forward! Thanks for the tip
    Manchester, N.H.
    96 332IS 6466 turbo
    If you really want to do good at the drags, I have a full slick setup for sale ; )
    1996 332IS
    Built 3.2
    Jun 2005
    New England
    O
    Find out the 188mm diffs that had the gears you want and search junkyards. Diffsonline is not cheap.
  1. Question on drag racing wheel package
    By 97mreaper in forum Drag Racing
    Last Post: 04-11-2013, 04:39 PM
  2. Drag Race Wheel/Tire Setup
    By Samir in forum Wheels and Tires
    Last Post: 06-29-2010, 05:30 PM
  3. Drag racing wheel setup
    By kobe 8 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-16-2007, 01:05 PM
  4. Replies: 4
    Last Post: 05-03-2004, 04:33 PM
  5. MOMO GT2 Racing WHEELS Silver or White GP! NEW!
    By timers-88-325i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-27-2001, 03:41 PM
