Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 58
Thread: Turbo M3 vs 2015 C7 Vette vs CTS-V vs BoltOns 335
  1. #26
    NY/FL
    '08 G35S, '98 M3/4/5
    Quote Originally Posted by rajicase View Post
    With 500whp you'll be faster than 99% of cars out there. I pull hard on modded c6 vettes. With your goals of 800 or whatever nothing will be able to keep up with you unless you go to 1/2 mile events or somewhere like that.
    Having 500+ whp is nice... but I find it extremely difficult to find a car to race that is worth my gas lol...
    Lol I'm not going for 800 straight away, my clutch and tranny won't be able to handle it haha.
    But like I always say, the atmosphere is different down here. 500whp is only mid tier. So eventually, yes, I'll need 700+ to hang with the big boys. Maybe after I get used to 450 ish progressively like you did lol.
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  2. #27
    NY/FL
    Quote Originally Posted by Jkpgt96 View Post
    As long as I can put new corvette owners in their place I am happy lol.
    It is hard to get people to play once they hear that s366 whistling, lol.
    Absolutely agree on both points lol. I'd be reluctant to run you also if I heard it!
  3. #28
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Honestly I think having 7-800whp is pretty entry level anymore. Regardless of where you are. I don't really care either way..if I wanted the fastest car around I wouldn't be building an e36 lol.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  4. #29
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Quote Originally Posted by Da Infammus 1 View Post
    Haha..it sounds intimidating but the bark is bigger than the bite for now..after some corn in the tank that will change
  5. #30
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I wouldn't agree. Maybe if you are talking half mile events and stuff.. but for the street, 500whp will still walk away from 99% of cars you come across. I think 550-600 is perfect for an e36 dd. It'll be 500# lighter than most of your competitors so factor that in as well.
  6. #31
    Feb 2012
    1995 BMW M3
    Just for reference I hung with a 650whp 5.0 recently. I'm making maybe 525-550. E36 is relatively light compared to a lot of big power cars you come across..
  7. #32
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Oh I agree it is plenty for 99%+ of the cars out on the road..but the turbo LS cars and Coyote cars will still be a handful. It is comical how heavy cars are nowadays.
  8. #33
    NY/FL
    For daily driving, yea, you'll kill 99% of the cars you meet on the road with a 500whp e36. That ratio drops to a 50/50 chance when you roll up to the car meets I go to for the most part lol.
  9. #34
    Hawaii to Las Vegas, NV
    '06 4Runner| 77 930| E36
    nice kill OP. I wish you were closer. would love to try my 3.0L with an s366 vs yours PSI VS PSI
    my car was mirror to mirror with a 684whp GT500 too. but i have some weight reduction. I estimated 530-550whp too. the power to weight ratio was spot on. 91 octane about 16psi base tune
    Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
    Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
    Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
  10. #35
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    If you make 530-550 on 16 psi then it wouldn't be much of a race as I sit right now. I'm full weight, ~3150, and on crappy stock na cams that made much less than you on 16psi
  11. #36
    are you planning on running at the track in the spring? maybe we can compare trap speeds? haha. Im full weight with gutted trunk. should be about 3100lbs but havent been to track to confirm. completely stock head and motor just 8.5:1 Carillo pistons and eagle rods. btw do you have your dyno sheet by chance? would love to see the curve and compare BMW 3.0L with same turbo
  12. #37
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Here are the second and third pulls.
    Couple notes on the above. These are the baseline pulls we did before we finished ramping in all of the timing and finishing up the tune for pump gas. The best pull we the first one that did 465/401. 17psi, flat 14 degrees of timing across the board in boost. I literally drove the car off the highway and onto the dyno. I'd estimate on 16-17psi we were just shy of 500 when it was all said and done on pump 93.
  13. #38
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    And yes I plan to have a 16" dr on the back and to make some passes this spring. My expectations are low. I have never made a pass in this car..let alone, launched it.
  14. #39
    ^^ wow that powerband looks healthy. definitely more under the curve than most 2jz with 72mm+ turbos. im jealous you can rev to 7500 stock! yeah i suck at launching and these chassis break stuff so ill be going for trap speed really. thatll tell who wins in a roll race anyway. haha good luck to you, hope to see more kill vids
  15. #40
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Thanks! Yeah it was surprising to see the power band with the stock na cams. Guys are typically seeing 50-60whp in this power range from getting 268/268 cams, but we shall see what I decide to do once we get a high boost curve.
    The car just got a large case 4 clutch setup so hopefully that helps. The last stock bit in the driveline are the axles.
  16. #41
    NJ/NYC
    C6 Z51 Vert', Acura NSX
    Don't forget C6 Vette's are pretty light (and aerodynamic). Generally takes another ~150whp on a GT500 to pull the equivalent C6. But yes, the E36 and E30's do better than their numbers indicate from what I seen as well. How much do swapped E36's and E30's weigh in at?
    Good to see you on here too DI ;-)
    Would love to run into a boosted E36 or E30 for fun. Only recent Bimmer run I had was an older "full bolt on" M5 (V10) at the toys for tots event. Even though I spun all 2nd, I quickly reeled him in and freight trained him.
    -Victory Red Built, Cammed, Supercharged with Alky/Meth Control C6 Corvette Z51 Convertible 6-speed--720whp on a BAP--900+capable-3LT, Paxton, Forged MAHLE FI Pistons, ECS Big Blower Cam, Brian Tooley Spr/Titanium Ret., A-Pil Gauges/LG Long Tube Headers/X/Borla Atak/Ported IM/TB/ATI UDP/Meth Tune/MGW STS/Z06 Diff and Torque Tube/Mantic 9000 Twin Disk Clutch, Tial Q (loud) blow off, Carbon Fiber ZR1 Front Splitter/CF ZR1 Side Skirts/CF Rear Valance/CF ZR1 Spoiler/Handles/CF A-pillar Trim, XO Verona 19/20" Matte Black Wheels/315's in rear with spacers/Z06 CF rear splash guards ("pseudo wide booty"), Carbon Fiber Interior Red-Stitching/Centennial Alcantra Steering Whl/Shifter, Custom Audio/Navi, Powdered Red Calipers, Built in V1, LED Halo Tails/6K Fogs,++
    -15' Mercedes Benz S550 4-matic, Lunar Blue/ Deep Sea Blue Designo, Premium, 20", Warm/Comfort, Exclusive, 360 Camera, Park/Distronic, + (DD)
  17. #42
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    It was a fun night. His car is lighter than mine..3150 + 2 people..he was by himself. I would rather give it another pound of boost than start removing stuff.
    Sent from my iPad using Tapatalk
  18. #43
    Jan 2015
    RR NM
    93 325is /07 530
    Nice work man... Nothing wrong with 2jz swap, but that coming from a Sbc V8 swapper ... lmao
    I Tip my hat cuz I respect the work it took to do he swap GOOD RUNS!
    My old school Iron Block is heavy But I tip scales at 3160 with 195 Driver. Rear seats, Door Panels, stock gas tank removed and no heater no Ac ect .
  19. #44
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Thanks! Yeah this is a full weight car in every sense of the term. I still have my heated vaders, ac, full size spare, etc..
  20. #45
    Quote Originally Posted by callmedoc View Post
    Full weight turbo e30s range 2900lbs full weight down to 2500lbs if gutted. e36s from 3250lbs down to 2800lbs if gutted...and boy does that power/weight ratio get SWEEET. im full weight with AC and leather interior sedan and im ~3050lbs. after sunroof delete and some sport seats i should be about 2900lbs with AC with room for 4 = )
  21. #46
    Jan 2017
    Abingdon, MD
    2003 BMW Z4 3.0i
    You guys are insane. I don't think I've ever even been in a car with 300+hp.
  22. #47
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Quote Originally Posted by BMWFanatic View Post
    That's awesome. I did weigh my car with a full tank and a spare (DS1 w/ tire) in the trunk..so I am probably closer to 3100 with a full tank. The R154 is also heavier than the 420g, and the new flywheel is much lighter than the stock 1jz unit, so I would expect I am under 3100lbs come spring, with a full tank and no spare/driver.
    Quote Originally Posted by 4jacks View Post
    I am not that experienced with this type of power under my foot either..thus I had no issue spending most of the season on pump gas and low boost. 465+whp still felt really fast.
  23. #48
    Jan 2017
    Abingdon, MD
    2003 BMW Z4 3.0i
    You obviously put a lot of labor and love to get it there so enjoy it.
  24. #49
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    It's a lot of fun and worth the wait.
  25. #50
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Nice runs!
    When you get over the 700whp mark everything becomes a blur.
  1. Turbo M3 -vs.- E46 M3
    By ///MCubed in forum Kill Stories
    Last Post: 12-17-2004, 01:26 AM
  2. AA Turbo M3 vs Corvette Z06 ... Part 2
    By Kevlar in forum Kill Stories
    Last Post: 09-29-2001, 01:14 PM
  3. Turbo M3 -vs.- Viper GTS (+ other "kills")
    Last Post: 09-25-2001, 10:19 AM
  4. AA Turbo M3 vs Corvette Z06
    Last Post: 09-09-2001, 04:25 PM
  5. I wonder about AA Turbo M3 vs F40/F50 Ferraris
    By PM3 in forum Kill Stories
    Last Post: 06-14-2001, 11:14 PM
