Results 1 to 14 of 14
Thread: My Refinishing Progress Style 5's (bbs rc090) PIC HEAVY
    Aug 2011
    Charlotte, NC
    Not enough
    I know there are plenty of threads out there about refinishing Style 5's... but I figured I would add to the community and show pictures (I really like seeing others put TLC into old wheels and bring them back to life... so figured ya'll would too) I really enjoy doing this, I am certain I am borderline OCD... this type stuff really I feel is pleasurable to do especially bringing old items back and giving them a new lease on life.
    Plans:
    -Typical tear-down/Strip/wet-sand/polish barrels
    -Gold centers
    -Either black or gold hardware... I am unsure right now
    I caught these on CL for super super cheap... they were bent up and then someone had spray painted the entire/whole wheels silver... -_- they need some love....
    Let the progress begin
    Tear down... I used 1/4" dewalt impact and WD-40 to remove all the nuts, then used blocks of wood and a 5# sledge to motivate the centers out
    Cleaning before starting to strip paint...
    Where I am at now... all wheels are cleaned, torn down, and then two are stripped ready for sanding and polish
    The two that I have removed paint and clear, ready for the sanding to begin ... woohoo
    Here is a quick video of how I removed the studs... a 16oz hammer and drift just wasn't working. I decided to go with 5# sledge and large drift, made very quick work of stud removal.
    https://www.youtube.com/watch?v=Dle9Vc2Mi78
    They call me Spaz
    -1990 535i/5 with some stuff ----->M30 Turbo Build
    -1996 328i sedan (S-52'd) 5-speed ----------> Refurbish Project (Wife's new DD) ---> (S52-swap)
    CT
    '94 530iT LSx/T56
    Nice! Certainly satisfying refinishing a set of wheels. Getting the studs back in the barrel without marring them took some thinking. I used a nut larger than the major OD of the stud and tightened its nut, to pull it back into the barrel. Then the center got dropped in. I think the center flange may have been too thick to to use it to do the same. Make sure to line up the splines well. You'll know when they are seated. A dab a grease really helps too, especially if there is any sort of powder or paint on the spline area.
    On one of the ones i did, the center was corroded/stuck to the barrel. No matter of sledge and wood would budge the think. Took nearly maxing out a 2000lb press to get that sucker to pop. Made quite the noise when it did.
    -Alex
    Jul 2012
    Madrid (Spain)
    750i E38 & 540i E34
    Best wheels for any old Bimmer ever. Good job.
    There's no replacement for displacement.
    Aug 2011
    Charlotte, NC
    Not enough
    Quote Originally Posted by BMWM5E34 View Post
    I love them! They look 'proper' on an e34 I think
    Quote Originally Posted by AHenry014 View Post
    I can only imagine, two of mine fell out after one tap.... the other two had the typical aluminum corrosion on the back side all the way around the centers, I kept them soaked with WD-40 for 3 days (front of wheel facing down) and then removed as much corrosion from the inside of barrel that I could manage and then took many many whacks with the sledge and multiple blocks of wood. I had almost given up hope, but they finally started moving.
    Great idea on pulling the splined studs back through tightening them on to a larger nut... I will have to borrow that idea! I bought a large jar of anti-seize to use on splines and then blue loc-tite for the nuts.
    They call me Spaz
    Aug 2011
    Charlotte, NC
    Not enough
    I got a little side tracked... I realized I didn't care to spend 10 hours on a single wheel wet sanding and polishing (I am anal/particular) lol
    Sooo... I decided to make a little wheel polishing jig on the cheap (emphasis ON THE CHEAP)...
    I am utilizing freebie stuff from work and laying around and an old drill.... here is the down and dirty concept:
    -old hub horizontally mounted with ~13" tire/wheel combo that the barrel of wheel sets in (to rotate freely)
    -80-20 Mount/arm to suspend drill to drive wheel (freebie from work)
    -1" birch ply base (stuff I had laying around)
    Quick little sketch up on SolidWorks to get rough dimensions....
    Spent a little time on the Bridgeport, made a chucking mount for the drill out of some left over nylon and conduit u-bolt I found laying around...
    Roughed up the contact surface to help hold drill, mounted to 2" al angle I found laying in the shop scrap bin at work
    Found a spare composite wheel, and turned an M12 bolt down to make a spindle for wheel
    This "polising/sanding jig" is definitely not going to be pretty.... but I don't really care. I just want something to rotate the wheel and give me access to the lip to sand and polish... to be continued when I have more time to spend in the shop!
    Cheers
    They call me Spaz
    Jul 2002
    Baltimore, MD
    '92 535i/5
    Definitely interested to see how you pull this off because I want to refinish my wheels but don't wanna do it by hand. I've been thinking belt sander which may be a little too rough.
    '97 318i (Sold) - '96 M3/5 Lux (Sold) - '03 X5 3.0i Sport (Sold) - '03 SV650 (Sold) - '92 535i/5
    Great White North
    various
    Did you us aircraft stripper to remove the clear?
    Aug 2011
    Charlotte, NC
    Not enough
    Quote Originally Posted by zubbie View Post
    Yes sir...took about two good coats to work its way through the silver paint(previous owner) and then factory clear.... I don't have a picture of all 4 stripped, but the two on the left in this picture are stripped (I work on these in ~2hour segments) in between honey-do list items hahaha
    IMG_0359 by Caleb Henley, on Flickr
    They call me Spaz
    Sep 2012
    El Paso Del Norte, TX, US
    ‘15 F31d Msport
    Looking good so far!
    If I were to give my Touring a first name, I'd probably name it "Alan".
    Mostly because I like puns.
    Mutual Admiration Society #5
    Aug 2011
    Charlotte, NC
    Not enough
    Some progress... I ended up using an old washing machine motor haha but I made a polishing jig. I also had to TIG some of the barrel lips they were curbed so bad... pics to follow....
    IMG_6115 by
    IMG_6092 by
    IMG_6109 by
    Hopefully I will have centers in within a couple weeks!!!!
    They call me Spaz
    ATX
    Sundry old Grrrrmans
    Nice save on those lips! Awesome work.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
    Jun 2016
    Washington DC
    1995 540i/6
    Awesome! I want to a find a set on craigslist and do a full strip and rebuild!
    Mar 2005
    Long Beach, CA
    93BMW 525i/95 BMW 540i/6
    When I did one set, I used a Vibratory Tumbler to polish all of the nuts and bolts. Did you send out the centers and/or inserts to be powder coated?
    USC Ralph - Long Beach, CA USA
    1989 E34 White 525i (M20) 310,000m (Sold)
    1993 E34 Black 525i (M50) 308,955m
    1995 E34 Calypso Red 540i/6 (M60) 201,254m
    1993 E34 Black 525iT (M50) 138,500m
    Aug 2011
    Charlotte, NC
    Not enough
    Quote Originally Posted by uscharalph View Post
    Yes I did, to be powder coated gold oldskool
    They call me Spaz
  1. FS: 2 17" BMW Style 5's (BBS RC090)
    By 86 325e in forum Wheels and Tires
    Last Post: 01-15-2013, 06:57 PM
  2. FS: Full Set of 17" Style 5's (BBS RC090)
    Last Post: 09-03-2012, 04:20 AM
  3. WTB: 1 center cap for Style 5's (BBS RC090)
    By CubbyChowder in forum Wheels and Tires
    Last Post: 07-04-2012, 03:56 PM
  4. Nice original Style 5's/BBS RC090 17x8 ET20
    By Jcbe34 in forum Wheels and Tires
    Last Post: 07-20-2011, 11:09 PM
  5. FS: 4 style 5's (BBS RC090) Cheap!
    By hon2bmw in forum Wheels and Tires
    Last Post: 11-04-2008, 10:36 AM
