Page 17 of 17 FirstFirst ... 7891011121314151617
Results 401 to 424 of 424
Thread: S54 ---> Hellrot E36 328I
  1. #401
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Headers on the car
  2. #402
    Mar 2017
    Oahu / Los Angeles
    S54 E36
  3. #403
    May 2009
    Pittsburgh, PA
    Small documentation updates.
    At the point of “cleaning” things up! Tossed the car on stands for the winter. of a long list, highlights will be SSV1s going in, free-er sec 1/2/3 will be built, *hopefully* a custom air box made as well.
    Most recently, gauges hav been removed and all wiring under the dash made pretty. Added a vacuum gauge and innovate wide band will be going in.
    5B81E33B-2D18-4B55-AF16-62F38DBA8EBE.jpg3BF09342-0049-48FE-AE44-E65730F0C234.jpgBB27DA48-71A9-4B0A-A78B-DB443CC7B0FC.jpgFA7144EA-6E7E-489D-8116-5311FC67A123.jpg40E1A20E-6FA6-4342-88C9-5DD0EA1E0E73.jpg
  4. #404
    May 2009
    Pittsburgh, PA
    Update.
    Custom headers I made are now off the car and sold! I grabbed SSV1 and began a full dual 2.5” build.
  5. #405
    May 2009
    Pittsburgh, PA
    Few more
  6. #406
    May 2009
    Pittsburgh, PA
  7. #407
    Aug 2015
    NYC
    a bunch of broken ones
    you will have to make the cross over a smaller diameter than the bank piping for it to function as it should.
  8. #408
    May 2009
    Pittsburgh, PA
    That’s for the heads up, there’s a 1/4 “lip” I left in there for material to weld to!
  9. #409
    Aug 2015
    NYC
    No worries. I also fabbed one up, made the cross the diameter of the bank piping, then went to a supersprint CSL section 2, full 2.5 inch.
  10. #410
    May 2020
    Eugene,OR,USA
    1995 BMW M3
    Hi guys I'm new to this group. I need help with some wiring doing the same swap in to my 1995 M3 going s54, do you guys have more pictures of the wiring?
  11. #411
    May 2009
    Pittsburgh, PA
    I don’t have anymore photos and everything’s wrapped up / secured away. That being said using all the build threads you should be covered 100% as far as what to do and how to do it! If you have specific questions I can try to help
  12. #412
    Oct 2005
    Daly City, CA
    '99 540i/6, '00 VFR800FI
    I am eyeball deep in wiring myself. The loss of M3forum has definitely provided me with a few dead ends. With that said, read read read. Pictures will only get you so far. There are ETMs available for the E36 and E36/7 chassis, and NewTIS is painful but does contain the necessary info for the E46 cars. PITT's thread here has a lot of good DIY info. M52 POWER!'s thread here has a lot of good info using Andrew's harness: https://www.bimmerforums.com/forum/s...tic-Dream-Swap. There are a lot of threads to read, on this forum and others. You can do it!
  13. #413
    May 2009
    Pittsburgh, PA
    Documentation of AC install.
    -competed the wiring detailed a few years ago in this thread.
    -replaced all the orings in the system
    -vacuum checked and passed
    -added 3oz of PAG46 for a top off
    -36oz of Autozone R134A
    Did this by renting the AC manifold gauges, a vac pump and buying a can tap (old style) and an adapter for new style cans. No issues once it was all squared away. 42° air 👌🏽
  14. #414
    Jun 2021
    Uk
    E36 s54
    Hi mate, great info here.. I’m about to remove the SMG wiring from my S54 loom.. do you mind if I ask you some questions? I’m not sure how to DM people on here though!
  15. #415
    May 2009
    Pittsburgh, PA
    Yea man, sure…basically remove all the gray plugs
  16. #416
    Nov 2011
    Connecticut
    1999 BMW M3 Coupe
    hey man, great build. ive been following for a while. in the middle of my s54 swap now. at the wiring and just have a question for you maybe you can help. finished up the wiring with a z3 can cluster. right now im trying to get a tune done but can scan my vehicle. not getting kl15 signal. ive double checked everything and cant figure it out. the car will crank but not start. currently dont have the dme coded so i know the immobiizer is preventing engine start but will it also prevent kl15? need to scan the engine to pull the tine so i can send it out but wont connect without kl15 on. any help would be much appreciated!
    99' Titanium Silver/Black E36 ///M3 Coupe
  17. #417
    Aug 2014
    Redwood Shores, CA
    1999 BMW M3 Coupe
    Quote Originally Posted by mldyanks213 View Post
    Is your cable correct and software properly setup? Are you able to connect to the car but not actually pull the tune? Or not able to connect at all?
  18. #418
    Nov 2011
    Connecticut
    1999 BMW M3 Coupe
    Thanks for the reply. I realized I didn't have the round diagnostic plug wired in. In the process of doing that now. Found it might not send kl15 for diagnostic programming. Almost done wiring it. But yeah I need to pull the info from dme onto a file to send out and they send the new tune back
  19. #419
    May 2009
    Pittsburgh, PA
    Yea wire the diagnostic plug but at the same time if you’re not seeing a signal now, you need to figure out why. Did you run can +/-?
  20. #420
    Nov 2011
    Connecticut
    1999 BMW M3 Coupe
    Yes ran can high and low from dme to cluster. Do I need to run further can wires? Just don't have kl15 I'm hoping it's from the round diag plug not being wired in. Will have an update soon. Again thanks for the reply!
  21. #421
    Aug 2014
    Redwood Shores, CA
    1999 BMW M3 Coupe
    You don’t have an obd2 port?
  22. #422
    May 2009
    Pittsburgh, PA
    Removed LTW wing
    New wheels - MRR GF6
    19x9.5 et 35 front 235/35/19
    19x9.5 et 25 rear 235/35/19
    Dinan stage 1 SC bought and boxed for later.
    random maintenance too, new FCAs, oil changes etc.
  23. #423
    Feb 2001
    NYC
    e36 M3 DD/ E46 M3
    updates on the amazing build?
  24. #424
    May 2009
    Pittsburgh, PA
    Just driving it, added usb to the console for a modern update and a multimedia pioneer deck. No supercharger yet. Building an E30 at the moment.
    everything gets updated @rgaredgarage on IG
  1. E36 Hellrot e36 328is (NJ)
    By Pufftrees in forum 3 series & Z Series
    Last Post: 11-19-2012, 01:35 PM
  2. E36 E36 m3 widebody s54 gts-3 race car
    By dbbmwm3 in forum Race Cars & Track Parts
    Last Post: 10-08-2012, 09:54 AM
  3. OK Fo Sale 1996 Hellrot E36 328i 4dr
    By SWISS in forum Southwestern - US
    Last Post: 06-21-2010, 03:05 PM
  4. modded e36 328I vs modded E46 325I vs 97 mustang gt
    By stang65 in forum Kill Stories
    Last Post: 01-25-2007, 09:41 PM
  5. e36 328is vs. mustang GT convertable
    By Maxpowrbmw in forum Kill Stories
    Last Post: 08-17-2006, 08:37 PM
