Found this at the local junkyard. Seems to have been a wall hanger or something like that . Left fender is in bad shape.
From what I can see, that's an MTech I wheel. Get it!
Glacier blue metallic 1991 BMW 325ic
meh...i hate that steeringwheel myself....have it on my e30 is...
It's still worth $100. And the cow catcher and assorted hangers is $200. Still some good pieces.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
