Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 11 of 11
Thread: Bmw e39 wheels to fit bmw e34
    Jul 2016
    Australia, noosa
    BMW E34 535I S SCHNITZER
    I have a 1989 bmw 535i s ac schnitzer and am debating whether to keep them on or put on a 3 piece genuine bbs wheels of my e39.. if i get the right spacers, would the offsets be ok?
    Salem, MA
    03 zhp, 97 e36m3, 04 zhp
    You should be fine. Don't forget the hub centering rings because e39 CB is 74.1mm.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    You don't need a spacer just the centering rings. If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Mar 2018
    California
    1994 BMW 525i
    Hello Jim,
    I have a 1994 e34,(525i) and I'm planning to pick up some factory wheels off an e39. They are 16 inch wheels.
    Would you be able to assist when I am ready to order the center rings?
    Also, ball park, how much should I expect to spend on the center rings?
    Please let me know when you have a chance.
    Thank you
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Quote Originally Posted by 1994e34 View Post
    Hello Jim,
    Thank you
    The rings are available for 5.00 each. If I can help let me know.
    Mar 2018
    California
    1994 BMW 525i
    Quote Originally Posted by Jim@tirerack View Post
    Jim,
    If possible, I'd like to ask for your assistance.
    I'm planning to get the 10 spoke oem wheels from a Z4 (E85), they are 16 inches by 7 inches.
    Are there hub centering rings that will accommodate this wheel when mounted onto a 1994 e34?
    I have a link with for the wheel information if you need that for more information.
    Thank you for your time.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Jim,
    Those wheels are already hub centric. You would only need rings for wheels that were OE on an E39.
    NW suburban Chicago
    hiss by my window
    E39s (& X5s?) are the odd duck hub size of the BMW world, 74.1 mm vs. 72.5mm for the others.
    Mar 2018
    California
    1994 BMW 525i
    Thank you for the response Jim. Do you know if I will need spacers?
    I believe the stock wheels on my car have a positive off set of 20 while the wheels I am looking at (stock wheels from a 2004 Z4) have a positive offset of 47.
    If I need spacers, is that something you can assist with as well?
    Mar 2018
    California
    1994 BMW 525i
    Hello Jim,
    I was finally able to buy some wheels for my 1994 e34. I got 16 inch bbs (oem bmw stamped) style 5 wheels that were on the e39.
    Would you be able to help me purchase the appropriate hub centric rings to fit the wheels to my car?
    Thank You
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Hello Jim,
    Thank You
    I have them in stock for 1.50 each. Just give me a call and I can get them on the way.
    800-428-8355 ext 4364
  1. Replies: 5
    Last Post: 04-24-2015, 02:30 PM
  2. E34 Wanted: Centering Rings to fit E39 Wheels to E34 Hub
    By SteveMD in forum Wheels and Tires
    Last Post: 07-03-2013, 02:31 PM
  3. How to get BMW Style 42 to fit E34?
    By t.wak in forum 1988 - 1996 (E34)
    Last Post: 05-16-2007, 08:39 AM
  4. Replies: 4
    Last Post: 11-25-2005, 12:14 PM
  5. Wheel spacers for E39's to fit non E39 BMW wheels!
    By GriMpY in forum Wheels and Tires
    Last Post: 06-28-2005, 11:16 PM
