1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
Very nice! Welcome aboard sir! What trans are you using?
Sent from my SM-N920P using Tapatalk
Stock motor
build thread:
Stock motor
build thread:
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
Hey man you don't know how helpful that was lol. With the harness, Windows net, cage, and neck brace I could barely move, it's crazy....
Getting in and getting situated is a massive P.I.T.A
Thanks to you and Mazen for the help otherwise I would of passed out from exhaustion.
Also a big thanks to Butters, Phil, Tyler, Travis, CES, Technique Tuning, Dynamic Racing Transmissions, DSS, R&L engines and Shafts and Stuff.
Without these guys I would have never accomplished anything close to a 9 second car.
Stock motor
build thread:
It'll really come to life with the 3.64! I swapped a set of 3.62s (e46 m3) into my car and I love it! I cross the stripe at 7300ish rpm with the shift light just turning on.
Excited to be on the list at all! This is my best pass from last Wednesday. S52, 6262 .63 AR, cutring, spacer, arp studs combo, 17-18 psi, 3360 lbs, pump 93, Hoosier 275 drag radials. Car still has ac and heat!! Thank you Greg and butters for giving me pointers and butters for helping me daily and answering my dumb questions and teaching me everything.
https://youtu.be/KSRCVs1VLVc
Stock motor
build thread:
1996 332IS
Built 3.2
You'll want the best contact patch possible. It helps if you know the ppl doing your alignment and won't mind dicking around on the rack for a couple hours. I used ratchet straps on the rear of the car while it was on the alignment rack to fully compress the rear suspension then zero'd the camber. Also best if you're in the car when you do this
When I did my alignment, -0.5 became 0 on the hit. 3 of us hung on the rear to squat the car.
1996 332IS
Built 3.2
Running -0.5 out back on mine. Hooks 700+wtq from 50 on my baby 255/40-17 rs3 tires. I noticed a big improvement in traction after the new alignment..
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
Update gtw3884 23 psi
