Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 102
Thread: Crankcase Vents - Catch Cans
  1. #76
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Quote Originally Posted by Matutino View Post
    Fits OBDII as well yet your hood might not be happy about it
    I have the part and tried it. I drive with a hood on my car and it wont clear.
    Quote Originally Posted by NY98M3 View Post
    Whats the underside of that look like? I know the inside of the valve cover is not flat...
    Cam cover on that side. Low profile ribbing.
  2. #77
    Dec 2008
    wilmington De
    vinyl wrapped 97 328is
    The one closest to the rad is actually inside the Ccv chamber It was already broke open and I closed it back up after I put the -12an fitting in. The one closest to the firewall, I had to remove some of the ribs on the inside so I could fit the nut. They ribs break out fairly easy with pliers. The intake cam cover pretty much acts as baffle so no actual oil comes out. Littttttle but of oil residue on the under side of the hood. Still a work in process but so far so good. I think the sap pump will be a nice touch.
  3. #78
    Vancouver, BC Ca
    1993 325is
    If you leave those valve cover fittings vented to atmo, the SAP pump will do absolutely nothing for you.
  4. #79
    Dec 2008
    wilmington De
    Quote Originally Posted by jakermac View Post
    How do you figure? I'm not trying to make my Crank case full vacuum, I just don't want any CC pressure AT ALL. even with the vents open the sap would still be pulling out pressure.
    Even if the sap is pulling air thru those vents it'll still be doing its job.
  5. #80
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    The only reason I can see needing the two fittings on top is if you have blowby at idle. You might be able to minimze pressure if you do not run the SAP at idle. The sap is not really designed for continuous duty so I advize against full time sap. The SAP can evacuate everything from the original nipple. If you are working on the theory of blowby at idle then you will need to filter the air being pulled into the motor which will probably minimize the value of having them in the first place.
    Just thoughts. You might be on a different track.
  6. #81
    Dec 2008
    wilmington De
    Quote Originally Posted by bry195 View Post
    thus the reason for the hobbs switch.
  7. #82
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    Quote Originally Posted by whoshaunq View Post
    I got it and suspected you did. My turbo did leak at idle so my interest is in helping you. I resolved the problem by replacing the turbo but if you work something out I'd love to hear what you come up with and continue to explore the ideas.
  8. #83
    Mar 2010
    Long Island
    E36
    Has anyone considered using the 2 big bolts on the vanos solenoid plate? That is the crank case, and it would be as easy as getting a metric to AN adapter if it would work...I don't see why not.
  9. #84
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Quote Originally Posted by Jaze View Post
    I'd be worried about too much oil getting in there. I feel like most of these setups are overkill. There are plenty of high hp race cars with low tech solutions that work fine.
  10. #85
    Dec 2011
    Overland Park, Kansas
    1995 M3
    I am also using the SAP to pull vacuum on the crankcase with a 2psi switch. Prior to this I had turbo oil drain issues and I was getting oil in the intercooler piping.
    I have a question for the other guys using this ccv setup, when you roll into boost at night with the headlights on do they dim momentarily when the pump kicks in?
    When I had my car tuned at Technica they said they couldn't control the timing up top as well as they wanted. They recommend fresh coils and getting a higher amp alternator to keep up with the fuel pump and ignition. When it was tuned the SAP pump was unplugged but I'm worried with it plugged in that it may cause more of a problem.
    has anyone had the need to upgrade their alternator along with going turbo? I'm only on a basic stage2 TRM fuel system.
  11. #86
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    Quote Originally Posted by e36luve View Post
    I am also using the SAP to pull vacuum on the crankcase with a 2psi switch. Prior to this I had turbo oil drain issues and I was getting oil in the intercooler piping. I have a question for the other guys using this ccv setup, when you roll into boost at night with the headlights on do they dim momentarily when the pump kicks in? When I had my car tuned at Technica they said they couldn't control the timing up top as well as they wanted. They recommend fresh coils and getting a higher amp alternator to keep up with the fuel pump and ignition. When it was tuned the SAP pump was unplugged but I'm worried with it plugged in that it may cause more of a problem. has anyone had the need to upgrade their alternator along with going turbo? I'm only on a basic stage2 TRM fuel system.
    I had a 40 amp relay driving the SAP and it welded closed after running for 15 minutes straight. My point is that I believe the SAP pulls pretty close to 40 amps. You probably have an 80 amp alternator? The 140 amp works fine. I never ran it when I had the 80 amp on.
  12. #87
    Dec 2011
    1995 M3
    Sounds like I should just upgrade to the 140 amp either way
  13. #88
    Oct 2015
    San Rafael, California
    1996 bmw 328is turbo
    Very good info on here and it has helped me a lot! The question I have is, what are you guys doing with the pcv hole in your manifold? Are you still leaving the pcv attached, and just leaving the vc breather hose disconnected from it (going to a catch can) How do you plug the hole if you get rid of the pcv?
  14. #89
    Oct 2015
    Quote Originally Posted by aunlznl View Post
    I just have a hose going from the stock obd1 valve cover to a 2 inch round breather filter. I never get any oil in mine.
    Did you just block the pcv hole in the manifold?
  15. #90
    Apr 2006
    Minnesota eh?
    86 325es
    Someone on here tried it a couple years ago and there was way to much oil coming off the chains. The stock location is ideal because of the oil shield on the intake cam. Its really the only place in the motor that doesn't have oil flinging at it.
  16. #91
    May 2013
    Australia
    E30 M50B28 Turbo
    Exactly. So put your plastic shields on the intake cam peeps!
    I have previously zipped up the top of the motor and then seen the plastic shield sitting on the shelf....damn! Valve cover off again. :-/
    1989 E30 - M50B28 Turbo - ZF 8 Speed
  17. #92
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by Nutzy View Post
    Ditto!!
  18. #93
    May 2016
    Riga
    e30, e36
    On a turbocharged engine, is it better to vent crankcase before turbocharger inlet (through oil catch tank) or can it just be fitted in catch tank, with no inlet to turbocharger (vacum)?
  19. #94
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Ditto!!
    Twice........ >.>
  20. #95
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    I mean I'm pretty sure I had it installed correctly. The only reason I found out it was the cause of my oil burning issue/smoke out the exhaust, blowing my turbo seals, etc.... I had taken the turbo off, used my stock maf, injectors, and a n/a tuned ecu, for inspection purposes while it was n/a and I was putting miles on it I started getting smoke out my exhaust and oil residue out my ccv's. The exhaust was actually pressurizing the CC. Luckily I caught it while it wasn't boosted. I probably would have parted it. I have two extra sap pumps I'm ready to hook one up!
    The ones on top of my valve cover just vent to atmosphere. I'll run the factory Ccv port to the SAP.
    Im still working on this...are those o-ring'd connections on the other side or is there a nut on there?
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  21. #96
    Aug 2012
    CT
    Twin turbo LS E36 M3
    With most of the LS stuff, one valve cover will be a "fresh air intake" and the other side will be the suction side, effectively pulling across the entire motor. The setup about with SAP going to the factory CCV port would just be pulling fresh air from the AN fitting next to it.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  22. #97
    Vancouver, BC Ca
    1993 325is
    No o-rings on mine. Just teflon washers on either side of the VC and a nut on the inside. I added a bit of Permatex Ultra Grey for a slightly better seal. But I'm having a hard time keeping them tight. Gonna add a bit of Loctite this time. No boost on my setup though.
  23. #98
    Dec 2008
    wilmington De
    I thought of this actually and may cap off the one closest to the CCv. I plan on actually going to a magnesium valve cover so I might put the vents in the back of the valve cover and make my own baffle. My pump works great right now, but my valve cover keeps leaking oil.
    Quote Originally Posted by dburt86 View Post
  24. #99
    Jul 2002
    Long Island, NY
    So I have several spare valve covers around that Im using for testing. The OBDII cover seems to have more room under it for the teflon washer and the nut. I tried this style last night by working on the rear vent and was able to clear out some of the checkerboard grating on the underside of the cover. The -10AN teflon washer and nut fit securely in between the grating. I used some of my kids playdough to check the spacing from the VC to the Intake cam splash guard, there is about a 1/2" space there.
    I also tried the OBDI cover like the pic below. Even on the high point on the VC like in the pic, it didn't leave as much room as the OBDII cover. I was able to do some measuring with the playdough and it leaves about 1/8" to 3/16 of a space to the splash guard.
  25. #100
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    Quote Originally Posted by chikinhed View Post
    I had fabricated an air/oil separator type catch can for my car a few years back. Most of what ends up in the catch cans is water vapour which condenses in the catch can. Routing the liquid that is in the catch can back to the oil pan is not a good idea as it is highly acidic. I had a drain on the bottom of my catch can that I ended up having to drain on a regular basis. I eventually said screw it and pulled the catch can out and now I just run a 1" ID hose from the modified OBD2 valve cover down to the stock fuel filter location under the car. I park in the same spot everyday and have never had oil drip onto the floor from the hose. I do smell the blow by smell occasionally when stopped at a light and the wind catches it. That's my only complaint really.
    Sent from my GTX3582R
    When you say modified valve cover do you mean that you rounded the squared edges at the bottom of the CCV port to fit the 1" tube?
    Sent from my SM-G930V using Tapatalk
  1. Exhaust Crankcase Vent with Catch Can or Not?
    By pbonsalb in forum Forced Induction
    Last Post: 07-06-2013, 12:45 PM
  2. crankcase vent to air and oil catch can for m60 feasible?
    By toyotahachiroku in forum 1988 - 1996 (E34)
    Last Post: 05-30-2011, 04:31 AM
  3. Where's your tranny vent catch can?
    By kolo1racer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-11-2008, 11:11 AM
  4. Turbo & Blow By Catch Can
    By M3TurboCa in forum Forced Induction
    Last Post: 05-30-2002, 08:08 PM
  5. Crankcase Vent Hose
    By pescadito in forum 1991 - 1999 (E36)
    Last Post: 09-28-2001, 10:02 PM
