Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 102
Thread: Crankcase Vents - Catch Cans
  1. #51
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Matutino View Post
    Looks great, I love my catch can as well...
    Clean vs cleaner!!
    F U too.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #52
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    is that a Burger Tuning catch can?
    i really like how cleanly/simply it's installed.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  3. #53
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Yes it is.
    Looks clean, works great and uses 16mm inlet/outlet... Very happy with it.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  4. #54
    Toronto, Canada
    E36 Turbo
    Yes it is.
    You have two exhaust evacs though? Do they Y together at some point from the catch can?
  5. #55
    May 2003
    Irvine
    Yes, catch can to a pump then they split
  6. #56
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Vacuum canister?
    That thing must suck with two bungs.
  7. #57
    May 2003
    Irvine
    Is the OBDII pump, works great
  8. #58
    Dec 2008
    wilmington De
    vinyl wrapped 97 328is
    hows the vacuum feel while engine running? Using hobbs switch for it to turn on only under boost?
    I have two -12an fittings on top of my valve cover right above the cam cover so oil can't escape, but they're only going to atmosphere since I have hood clearance issues with this setup, also the stock CCV port has been modified for a -10 an fitting that also goes to atmosphere and dumps to the ground. I would like to add the SAP to this location since it seems to be the best option for Ccv.
  9. #59
    May 2003
    Irvine
    That's correct, I have a Hobbs switch set up at 3psi with a led inside the car to let me know when the system is running
  10. #60
    Dec 2008
    wilmington De
    Nice touch with The led light.
  11. #61
    Toronto, Canada
    E36 Turbo
    Interesting...
    I would expect the pump to become a restriction eventually though.
  12. #62
    May 2003
    Irvine
    Quote Originally Posted by NOTORIOUS VR View Post
    Interesting...
    After much testing the pump really makes a difference, I drove the car for almost a years with it and had no issues, no oil sipping out, while w/o the pump going to the exhaust I had valve cover leaks. Dumping to the exhaust w/o the pump did not work out for me, the way is set up now works flawlessly
  13. #63
    Dec 2008
    wilmington De
    When I first got my m52 boosted I had ran a line from my Ccv to Oneway valve to exhaust with the vacuum fitting. This did not work for me. CC Pressure was at a all time high with this setup I guess my exhaust was too restrictive. The pump idea is def the best setup, also have other Ccv ports vent to atmosphere incase pump failure.
  14. #64
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by whoshaunq View Post
    Was the "bung" welded in at the proper angle?
  15. #65
    May 2003
    Irvine
    Mine was and w/o then pump dos not work correctly
  16. #66
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    No idea how many years this has worked without a hiccup for me. Probably 4 or 5.
  17. #67
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    It's more than just having the bung at 45*. It needs to be clocked at the right angle also so that the exhaust pulls.
  18. #68
    May 2003
    Irvine
    Trust me when I say I tried all angles and facing all possible ways and w/o the pump did not work
  19. #69
    Austin, TX
    S13, Turbo M3
    I forgot which thread this idea was mentioned, but here is my solution going back together with mine. $12 and extremely easy. MK4 Jetta 2.0 breather screws right onto the valve cover, and the stock cap screws onto that. Much larger than -10 AN. I'd have to go measure it.
    On my old setup near 600whp, I had the stock vent going under the car and never had any blow by to speak of at all. Now with the EFR9180 at 25psi, I sprung a small leak on the intake manifold side of the valve cover gasket, just behind where the stock breather port is. I'm speculating that can only be excess crankcase pressure given how the engine is tilted in a way that oil would not easily pool/slosh on the high side up there. I'm trying this breather out and will report back. I intend to run this hose, as well as the stock breather location just to atmosphere under the car. Running to the catch can was giving me the nasty water/oil mixture from condensation, and I'd rather not deal with draining that all the time.
    Mike
    IG: @mikevanshellenbeck
  20. #70
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Kinda hurts using a VW part on a BMW hahaha
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  21. #71
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by somebody5788 View Post
    Lots of guys here have Ford and GM parts in their BMWs too, and they'll smoke the rest of us
    Mike
  22. #72
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Fits obd1 valve cover only.
  23. #73
    May 2003
    Irvine
    Fits OBDII as well yet your hood might not be happy about it
  24. #74
    Dec 2008
    wilmington De
    I mean I'm pretty sure I had it installed correctly. The only reason I found out it was the cause of my oil burning issue/smoke out the exhaust, blowing my turbo seals, etc.... I had taken the turbo off, used my stock maf, injectors, and a n/a tuned ecu, for inspection purposes while it was n/a and I was putting miles on it I started getting smoke out my exhaust and oil residue out my ccv's. The exhaust was actually pressurizing the CC. Luckily I caught it while it wasn't boosted. I probably would have parted it. I have two extra sap pumps I'm ready to hook one up!
    The ones on top of my valve cover just vent to atmosphere. I'll run the factory Ccv port to the SAP.
  25. #75
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Whats the underside of that look like? I know the inside of the valve cover is not flat...
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  1. Exhaust Crankcase Vent with Catch Can or Not?
    By pbonsalb in forum Forced Induction
    Last Post: 07-06-2013, 12:45 PM
  2. crankcase vent to air and oil catch can for m60 feasible?
    By toyotahachiroku in forum 1988 - 1996 (E34)
    Last Post: 05-30-2011, 04:31 AM
  3. Where's your tranny vent catch can?
    By kolo1racer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-11-2008, 11:11 AM
  4. Turbo & Blow By Catch Can
    By M3TurboCa in forum Forced Induction
    Last Post: 05-30-2002, 08:08 PM
  5. Crankcase Vent Hose
    By pescadito in forum 1991 - 1999 (E36)
    Last Post: 09-28-2001, 10:02 PM
