Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 102
Thread: Crankcase Vents - Catch Cans
  1. #26
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by NY98M3 View Post
    What are you guys using for crankcase vents? Are you dumping to atmosphere? Using a catch can? Im dumping to atmosphere under the car though the stock vent on the OBDII cover. Im finding I need to use a catch can but not too crazy about it. Choosing the right can in key.
    Up for suggestions!
    I have loose rings for FI
    and three CC hoses/vents.
    This can has one (1) 3/4 NPT breather port on top,
    six (6) 1/2 NPT ports around the top cap
    and size (6) around the bottom as well
    allowing for many CC vents to attach.
    http://www.jegs.com/i/Vibrant-Perfor...12689/10002/-1
  2. #27
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    I have each vc modded on mine and run to a vented catch can. From there I am going to change to dump the vent under the car instead of under hood.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  3. #28
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Anyone use this can before? Vibrant makes some killer shit, It looks to vent right out of the can though
    https://www.summitracing.com/parts/vpe-12695/overview/
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  4. #29
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    God damn $145 for a can....
  5. #30
    Toronto, Canada
    E36 Turbo
    It's a really nice part... really solid.
    They also make a version with 4x AN fittings so you can vent elsewhere or recirculate, etc.
  6. #31
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    I just took mine with two ports and a vent port and added a fitting to the vent port so I could hook up a line and dump it under the car.
  7. #32
    Apr 2009
    CA
    E30 325is turbo.
    Quote Originally Posted by busterhax View Post
    I run mine though a cheap unbaffled ebay catch can then straight to the exhaust (JEGS crankcase evacuation kit). Catch can definitely fills up and no smoking from the exhaust.
    Be sure to weld the bung in properly. No instructions are included and I believe 100% of the people who say this method doesn't work just welded the bung in incorrectly.
    Up above 1.5k RPM, the exhaust evac sucks hard. I wouldn't run my ccv any other way.
    Do you have a filter on the can itself or is it a straight shot from the VC to the exhaust with the can in-line?
    http://www.abelvalenzuelastore.com Home interiors; Upholstery, floor covering, window covering, & all kinds of repair.
  8. #33
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Quote Originally Posted by twirknolove View Post
    The latter. The expansion in the open can is enough to keep oil out of the exhaust.
  9. #34
    minneapolis
    tite
    just throw your oil cap away. replace it with panty hose
  10. #35
    Jul 2002
    Long Island, NY
    Quote Originally Posted by NOTORIOUS VR View Post
    I may end up going with the Vibrant closed can, its a big can which makes it hard to place. Only place I can fit anything is right in front of the alternator/PS pump. I tried to fit a 4" piece of pipe in there, just fits.
  11. #36
    Jul 2002
    Long Island, NY
    There are certain parameters when to use an open and closed can, seems the open can is for a MAP based tune. Closed loop for a MAF based tune. Since we are MAF, I don't see where I could return it to since there is no pre turbo piping.
    Im reaching out to Jordan to see if I can dump to atmosphere or use the evac port on the exhaust.
    Attached Files Attached Files
  12. #37
    Toronto, Canada
    E36 Turbo
    Doesn't matter to the MAF if you're running blow through. It's why you're able to run a BOV instead of a DV.
    In draw through yes you would want to keep the PCV system closed and obviously not run a BOV.
  13. #38
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    On a low boost M52 setup, about 8psi, would it be fine to run a long line with a breather filter from the CCV to the back of the car? I assume I'd need to stick with using a similar ID hose, so about 26mm?
  14. #39
    Apr 2009
    CA
    E30 325is turbo.
    Quote Originally Posted by MrMuddle View Post
    I'd literally use the biggest ID hose possible if you're going to be running one that long. Maybe even run a Y-split into two hoses. It's something I'm thinking of doing soon since I'm really starting to get over the oil/gas smells in the cabin.
  15. #40
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    What about something like a one-way check valve and then route the CCV hose into the inlet mani? Or could it perhaps be routed pre-turbo intake(filter side) so it's re-used. I know that would effect the AFR's but on a standalone ecu(no MAF) that wouldn't be an issue, but would it be too much drawing on the vapours? I guess it would also depend on how much oil/sludge build up there'd be over time!
    Personally I'd like to get the fumes either back into the engine(without clogging things up) or as far away from the cabin as possible if I can.
  16. #41
    Apr 2009
    CA
    E30 325is turbo.
    I'm on standalone system and as soon as I took off the pre-turbo intake plumbing of my catch can, my octane rating went up, fuel tables had to be adjusted, and I was given much more room to make more power, so yeah the oil vapors were hurting my performance. My catch can is baffled, but it doesn't have a sponge or anything strong filtering like the $200+ name brand stuff so that could of been a huge factor - though I still don't want any vapors in there.
    The idea of a check valve into the mani is a good idea to test. Have a check valve into the intake mani and maybe T-off the same line into a can or atmosphere under the car?
  17. #42
    Jul 2002
    Long Island, NY
    Installing today....
    Before I had a 3/4" hose coming from the stock connector at the valve cover which went down and dumped right next to the tranny
    Now, Im trying to utilize the OE connector at the valve cover to keep it fresh looking, but I need to go down to 5/8" hose and utilize -10AN fittings on the can. Seems that the 3/4" hose would have less resistance but then get bottle necked at the can....
    Anyone venting the lower crankcase? If so, from where? I have another -10AN fitting on the can I need to use.
  18. #43
    Manchester, N.H.
    96 332IS 6466 turbo
    I run a 1/2 hose from obd2 dip stick.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  19. #44
    Feb 2012
    1995 BMW M3
    To your catch can?
  20. #45
    Vancouver, B.C., Canada
    '97 M3
    Do you have an OBD1 or 2 valve cover?
    I use to have a -10 bulkhead in the VC vent hole
    Sent from my GTX3582R
  21. #46
    Jul 2002
    Long Island, NY
    I think Id have to drill out the hole bigger on the stick that sits inside the oil pan.
    Quote Originally Posted by chikinhed View Post
    OBDII, this can has provisions for additional lines, for now I just capped the in/out for the next set of lines.
    The out on the can is going to a Moroso check valve to a Vibrant scavenger on the exhaust.
  22. #47
    Manchester, N.H.
    96 332IS 6466 turbo
    FU and your beautiful clean car.
    1996 332IS
    Built 3.2
  23. #48
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    1/4 inch right through the shaft inside the pan.
  24. #49
    Jul 2002
    Long Island, NY
    Sorry, I wont post anymore pictures lol
    Whoops!
    Ill try opening it up more.
  25. #50
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Looks great, I love my catch can as well...
    Clean vs cleaner!!
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  1. Exhaust Crankcase Vent with Catch Can or Not?
    By pbonsalb in forum Forced Induction
    Last Post: 07-06-2013, 12:45 PM
  2. crankcase vent to air and oil catch can for m60 feasible?
    By toyotahachiroku in forum 1988 - 1996 (E34)
    Last Post: 05-30-2011, 04:31 AM
  3. Where's your tranny vent catch can?
    By kolo1racer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-11-2008, 11:11 AM
  4. Turbo & Blow By Catch Can
    By M3TurboCa in forum Forced Induction
    Last Post: 05-30-2002, 08:08 PM
  5. Crankcase Vent Hose
    By pescadito in forum 1991 - 1999 (E36)
    Last Post: 09-28-2001, 10:02 PM
