Page 1 of 4 1234 LastLast
Results 1 to 25 of 91
Thread: Hellrot with a GTW3684R (6262) aka might as well make a build thread
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    Back in 2010 or 11 I sold the favorite car I've ever owned. For some people that wouldn't seem like a very bold statement, I however have had something along the lines of 40ish cars in the 35 years i've been around. I used to go through a car every few months and my VF supercharged Arctic silver 95 m3 was no exception. I had it like 4 or 5 months, put some ast coilovers on, went through a couple sets of wheels, and tried to just leave it alone. At the time the car only had 85K on it and was still in amazing condition. I assumed that i'd sell and get something better just like every other car I've owned. I failed though...every day since then I thought of how much I enjoyed driving that m3.
    I held out hope of finding a 4 door technoviolet 5 speed car in mint condition. I looked for a couple years. A few came along but never at the right time for me to make a move, or I was just too slow. I finally started really looking for something this spring. I broke it down to purple, green, or an individual color and must have a sunroof and 5 speed. Hellrot was not even in my realm of thinking, I couldn't stand red cars...or so I thought.
    I saw a black car with a cloth interior in florida and it ticked almost every box, but was a slick top. A couple days later a gentlemen in Jersey posted up another cloth car this time a Hellrot with a sunroof. There was just something about it, it photographed splendidly. He had laid some ground work for a car that should be pretty nice by the time I'm done. Car is a 10/95 build Hellrot over Grey Cloth car. It has 131K on it but appears to be pretty well taken care of. Seats are in fantastic shape. The P.O. did a cooling system, belts, some KW coilovers, cleaned the interior along with a new steering wheel, shift boot, and a bunch of other stuff. Upon buying the car I replaced the gutter trim, a bunch of window seals along with some poly rtab's and tranny mounts. I went with some smoked lights and a set of BBS RC300's although I did a terrible choice picking color as they needed a refinish and now need another one.
    Before even picking the car up I had purchased a like new stromung exhaust and an AFE intake. I figured that I'd be able to tide myself over with an exhaust and intake. I however failed miserably. A week after buying the car I bought another VF charger set up, without a tune. I then started adding up what it would cost me to do what I envisioned. A VF charger with a 10 psi pulley and water/meth with 42lb injectors. By the time I added everything up it seemed I might as well go turbo and have some real actual power. So before ever receiving the charger in the mail I had made a deal with a guy to buy the charger and I started planning my turbo out.
    I found a used SPA T3 manifold and scooped it up. And so it began.
    Along the line of research I kept changing my mind on what turbo I should go with. I first figured why not just go with the tried and tested GT35. I then considered an EFR setup...then a precision...then I came across these Garrett GTW turbo's. I randomly sent a message to a man they call Butters and it all went fast forward from there...well kinda slow forward as money is always tight.
    He and I discussed turbo options and we decided on the GTW3684R which is basically a precision 6262. I initially was going to leave the engine stock and just run low boost. Upon discussing this in depth I decided to just do the copper spacer with cut ring and make sure the engine was up to the power I am hoping to make.
    So this is where I'm at and here is my planned set up
    Spa T3
    Garrett GTW3684R .82....2.5" v-band outlet, 2.5" hot side outlet and a 4" inlet
    Tial MVS
    Tial BOV
    Copper spacer
    Cut ring
    ARP studs
    Treadstone 1235
    2.5" hot side
    3" cold side
    Rally Road motor mount
    CES poly mount bushing
    3" turbo back with a dynomax VT muffler..fully v banded (changed muffler to a regular dynomax)
    aeroquip socketless for turbo water lines and turbo drain line
    -4 oil line from vanos bolt
    aeromotive 340 with a rally road mount
    some ngk 4554 plugs
    here is what has been added since I started
    clutch masters 725 twin disc
    poly bushings for shifter/short shift
    ecs poly diff mounts
    ronal sx 18x8.5 et50 front with 15mm spacer, 18x9.5 rear et27.
    federal rs-r 225/40/18 front, 245/35/18 rear
    60mm wheel studs to fit rear wheel center caps
    aem failsafe boost/wideband
    RK tunes 60lb tune
    catch can
    Breeze stainless liner worm gear clamps
    regular dynomax muffler
    vibrant resonator
    4" slant cut polished tip
    new slave cylinder
    new front spoiler
    respray front bumper
    ground control race camber plates
    front reinforcement plates
    relay for fuel pump
    along with the turbo set up i'm going to attempt to run a F1 clutch with an upgraded throw out bearing. (went with clutch master twin disc)
    Some new beisan seals for the vanos
    i also have a whole ton of replacement parts for the engine while it's apart. trying to be proactive on all the seals and such.
    I don't mention a tune as of yet...as that is the last piece of the puzzle for me. I believe I know who I am going with but I have to save up some money.
    so onto the pictures as everyone loves pictures
    Day after I picked it up
    Thanks UPS
    Manchester, N.H.
    96 332IS 6466 turbo
    Your going to a great reliable build and nail your goals dead on !!
    Can't wait for results.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Sep 2009
    Syracuse, NY
    You have been an invaluable fountain of knowledge so far. I can't thank you enough for all the questions I have inundated you with.
    We will find out soon how this GTW works out.
    LI NY
    Turbo 99' M3
    That interior...
    Love the car, good luck with the build. Looking forward to results.
    Nov 2013
    VA
    E36
    Exterior/interior color combo does it for me. My build was very similar to yours and I haven't had any problems. Should make for a very fun, reliable car.
    Jul 2001
    F150, Suburban, M3
    Stock wheels look better.
    "It's not the people who vote that count, it's the people who count the votes."
    -DNC
    Sep 2009
    Syracuse, NY
    I agree, that color I chose to coat them does nothing for the wheels. They are gonna get refinished and get bigger tires.
    Sep 2009
    Syracuse, NY
    So this has been going a little slower than I had anticipated. Got cams installed last week and it sat until today still opened up. Took the time to time it twice and install the vanos 3 or 4 times. Then got the valve cover back on as well as thermostat housing.
    In retrospect I really wish I had installed the exhaust manifold studs while head was off the car. I think it may take me a few days to get them and the spa manifold installed. I was told it's not a job you want to do twice. I now know why.
    So I skipped to installing the rally road motor mount arm and ces poly motor bushing.
    I also got a slim spal pusher installed last week and test fit the intercooler.
    The list for this this week consists of:
    finish exhaust stud install
    install spa manifold
    sort/install turbo water lines
    install vacuum fittings into intake manifold/install manifold
    finish intercooler install
    install/clock turbo
    install oil feed/drain
    start fabbing intercooler piping
    start fabbing downpipe/exhaust/wastegate routing
    also trying to decide if Clutch needs to be done before final turbo install
    not very exciting pictures
    Feb 2009
    Hackettstown, NJ
    1998 328i
    Good luck with the build!
    Jul 2012
    Tucson
    1994 BMW e36 conv.
    Update?
    Jan 2006
    Chicago, IL
    2003 330i ZHP
    Quote Originally Posted by vr6dubny View Post
    Expand on this?
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by boostd4 View Post
    Expand on this?
    ?? There is hardly any room there.
    Did you get n54 studs? Those have a etorx head and are infinitely easier to install ..
    You really ahould have installed the manifold too... putting the head on with a little extra weight is more than worth saving hours of frustration with no space..
    Sep 2009
    Syracuse, NY
    so back from the dead...7 months later. I have made virtually no progress since my last post. Winter was not kind to me and my tiny 1 car garage didn't help at all.
    So here's where we stand:
    Got in on the MS PNP Group Buy
    Ordered/got my injectors (80lb deka), catch can, fittings for intake manifold vacuum/boost, lava shield to go on the firewall/tunnel, and gauge pod for the steering column.
    also upgraded to a FX750 clutch...I only want to do it once
    I sold the RC300's and picked up a set of Ronal SX in 18x8.5 and 18x9.5
    I also ordered a quick jack 5000slx which will hopefully make everything much easier. I am over trying to finish this car on my back with the car on jack stands, the extra 8-10" should be a big help in getting this thing done
    my only purchases left to make are an AEM failsafe boost/afr and a w/m kit after the car is running.
    only reason for going with the failsafe is that it is a combo gauge which will help in keeping clutter in my interior to a minimum...I do not plan on running the "failsafe" portion of the gauge...I have looked at the other options out there and I feel I like the AEM the best.
    early this week I moved the M3 back into the driveway and did a minor clean up of the garage to give me a work space. tonight I installed the fittings in the intake manifold and installed new gaskets.
    Sep 2009
    Syracuse, NY
    also to answer previous questions that I don't think I ever saw.
    yes went with the n54 studs
    the studs are just a pain to get to especially from your back, if I had installed atleast the studs while head was off I could have made sure they were all straight and retapped the holes that gave me difficulty...more easily. Also I agree that I might try installing with the turbo manifold on as well.
    Even more so I may just pull the engine out if I do it again, that way it provides easier access to swapping clutch and running all the other lines that need to be run.
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Nice build. If you ever want to get rid of that interior or swap/deal for a black vader interior let me know.
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
    Sep 2009
    Syracuse, NY
    Quote Originally Posted by E36Mylo View Post
    Thanks and thanks for the offer...i paid a premium for the interior, I doubt i'll ever want to part ways with it.
    Sep 2009
    Syracuse, NY
    Finally got out to the garage at 11:30pm. A little progress. got my injectors in the mail today, got them installed in the manifold along with all new seals for the mani. Also got to work on my coolant lines for the turbo along with deleting the charcoal canister, whatever that valve was in the air box and the TB coolant lines.
    Going to run the coolant line for turbo along side the oil feed line, then run the return into the side of the block. If anyone sees any issues with how I have this run, please let me know.
    plan for tomorrow is to get some vacuum caps and get the intake mani as well as the wiring harness and the whole top side of the engine put back together, pull the turbo off the manifold and tap for the waste gate, get the electric slim fan mounted and make some cardboard cutouts of what I want my intercooler brackets to look like. If that all goes smoothly I'll work on teaching myself to weld...just need to practice.
    also i'm not sure what everyone uses to cut the socketless hose but I found these pex cutters work fantastic
    Sep 2009
    Syracuse, NY
    I got the slim fan mounted, intercooler brackets made just need them welded up, intake manifold complete.
    I realized I can not weld for anything...thinking I need real lessons.
    also had to drill out the spot welds for the horn. Went to remove the bolt and the entire bracket that is welded to the frame rail twisted.
    Hopefully the brackets are welded up tonight and my front bumper support is cut down as well.
    Sep 2009
    Syracuse, NY
    got the intercooler mounted, rest of the harness and cowl installed, bumper and support beam cut for intercooler, and my vacuum line partly ran.
    Sep 2009
    Syracuse, NY
    still on the list:
    tap turbo housing
    tighten all bolts on exhaust manifold
    remount turbo onto manifold
    run oil return/coolant return
    install new heat shield onto firewall
    clutch install
    fuel pump install
    intercooler piping
    exhaust piping
    install boost gauge/afr gauge
    tires for ronals. thinking 235/35/18 and 265/35/18 federal rs-rr...may need to run smaller in rear as they supposedly run wide
    get front end resprayed
    Feb 2012
    1995 BMW M3
    255 federals won't fit in the rear without extensive fender work. 265s won't eve be close.
    Those federals run real wide. If you are on stock fenders 235 federals would be more feasible.
    Sep 2009
    Syracuse, NY
    Hmm, maybe I go 215/35/18 up front 245/35/18 in the rear then. Wheels are 8.5 et35 up front 9.5 et37 out back. My fenders are rolled/pulled pretty well as those rc300's were 8.5 et15
    NY
    skateboard
    Sounds like you need a better wheel setup
    Cincinnati, Ohio
    1999 M3,1991 MR2 Turbo
    I ran 255/40-17 (square) Hankook RS3 on a 17x9 wheel with just rolled fenders and some spacers.
    Current
    -1999 M3-track toy.
    -2013 Subaru WRX- DD.
    Past
    -2003 Ford SVT Focus
    -1991 Toyota MR2 Turbo(Turbo swapped, full exhaust, intake, springs, shocks, brakes)
    Mar 2013
    Upstate NY
    M3
    17X9 is ideal with stock fenders. Then just get some sticky tires and your all set.
  1. Replies: 2
    Last Post: 06-07-2007, 11:34 AM
  2. Oh, might as well...
    By fm.illuminatus in forum Kill Stories
    Last Post: 09-09-2006, 02:43 PM
  3. HIN AC coverage **56k might as well go wait for the first snowfall**
    By tdc in forum New York / New Jersey / Connecticut
    Last Post: 05-25-2006, 04:05 AM
  4. Replies: 101
    Last Post: 10-25-2002, 10:04 AM
