Its on OBC test #7, so far my temps when driving are-
108-110C or 226.4-230F High
105C or 221F Low
Is this normal? When its just being idle it will drop to a Low of 93c or 199.4F due to the electrical 12V feed into the heating element inside the thermostat.
The vehicle service history shows the water pump was changed at 60k and the thermostat was changed at 50k now at 123k.
Yes. That is perfect for a 540i (the operating temperature). I'm not sure about the low - but I suspect that it is fine since the thermostat is DME controlled and why run hot when you're idling? If your thermostat was stuck open, it would never read 105C.
The thermostat is 105c meaning that it will open at that temp mechanically if something goes wrong. The DME can open it much sooner with an electric signal that melts the wax in the thermostat and this opens the device.
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
Your driving Temps are good. You idle is low for some reason. Maybe stat not seating fully. Not sure.
The stat uses the standard mechanical portion for 99% of normal driving. The electric heater part only kicks in to lower the temp during extended full throttle abuse and if Temps go way high. There is a nice bmw tutorial on its operation if someone has the link.
Your temps are pretty much what I was getting.... Till yesterday
I installed an 88C thermo and now it stays right at 93-95C.
For some reason, I'm not getting an error message for the missing electrical connection either. I did buy a resistor to use as a simulator, but so far I don't need it.
I'd like to see that.
Mine operates like that. (City driving, right?) It will stay between 103/108°C and occasionally drop to 92°C when MAP cooling is active.
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
Hi, I have been averaging around 108 c. in my 1997 540i Sport. Your readings are more for the inline 6 so wanted to ask running this cool was there a lack in performance and did it affect mpg. I don't like running my engines this hot so if you didn't experience any negative issues i'm thinking about doing the same thing!! Thanks Charlie
Update to an old thread, I swiotched over to the 88ºC thermostat and never had a problem again. Operates between 87ºC and 92ºC open road steady speed, and 90ºc to 94ºC around town, heavy traffic, aircon on, and summer/winter it's the same.
Diehard E39 driver.
A stock and normal operating thermostat on the 540i shouldn't exceed 110C. Mine occasionally fluctuates between 98-110. 110 in stop and go traffic when the temperature is warm - seldomly hitting 111.
E39 WhatsApp Chat Gruppe
Diehard E39 driver.
With the stock thermostat mine used to run around +/- 226 F
Now with the 85 C thermostat it runs around 194 to 196 F
1998 540A M62 Black/Black Style 37's Dynavin N6 (SOLD)
I'm using the stock 105ºC t-stat but made a PWM circuit so I can set it from 80ºC all the way back up to the stock 108ºC KTMP.
I usually have it set so the KTMP is 94-95ºC.
I like keeping the coolant system pressure lower than the stock 16+ PSI.
with 88C tstat I’m seeing 90-93C
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
Manual swap isn't going to happen and even so, I still hate the glass sunroof (Easy swap) and the BMTV/IKE high which would require to tear down the entire interior. Might as well part ways with her with a tear in our eyes, instead of gutting her and half away completion realizing I don't live in a country were I can source salvage parts that easy and ending up selling for parts or chopping her to pieces myself.
Diehard E39 driver.
I should note that at least for now I’m running without the clutch fan. GG did tweak the aux fan operation so it kicks on around 91C for me atm.
