Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 108
Thread: MK60 ABS Standalone info
  1. #26
    Sep 2010
    Pacific Northwest
    95 BMW M3 | 03 330i ZHP
    Let's try to keep on topic here.
    Not all of these cars are going to be strictly race cars and yes we all have our opinions, but the OP has done - along with others - a good job of collecting information.
    2003 E46 330i ZHP - Daily Driver | Bike Hauler
    1995 E36 M3 - Autocross | Fun
  2. #27
    Mar 2006
    Menlo Park, CA
    95 M3 & Legacy Manwagon
    Quote Originally Posted by dmw16 View Post
    Do you need to adapt the fastener pattern? The E30 masters have a horizontal bolt pattern for the MC and I thought the E36 did as well, but I could be mistaken. I know that the E46 M3 booster has the clocked bolts on the MC.
    Z3M and E46 have the same orientation on the master. I don't think I tried fitting the E36 booster to the E46 master. Google images imply the E36 also has clocked bolts? I'll verify this weekend, I have a spare E36 booster and E46 master.
    "Fear disturbs your concentration" -Sabine Schmit
    1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
    1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
    2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
  3. #28
    Sep 2010
    Pacific Northwest
    Quote Originally Posted by Bimmerman535i View Post
    Pictures of the boosters side by side - for reference.
  4. #29
    Northern CA
    1998 M3/4/5
    Hmm, maybe the E36 booster is fine. I had read something about shimming the E46 MC, anyone know about that?
  5. #30
    Vancouver, BC Ca
    1993 325is
    I'm with Scotch, who needs a frikin' booster!!
  6. #31
    Sep 2010
    Pacific Northwest
    Moving this to the top.
    I'm currently working on running and bending new rear brake lines for my MK60 system since mounting is complete - taking longer than expected.
    Once I've verified all of the brake line fittings I'll post the information.
  7. #32
    Vancouver, BC Ca
    1993 325is
    Would it not have been easier to acquire the 96-up brake lines?
  8. #33
    Sep 2010
    Pacific Northwest
    Quote Originally Posted by jakermac View Post
    Maybe, but now I can make them the way I want to and I don't have to remove the fuel tank.
  9. #34
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by BMW Mdrei View Post
    Makes it look like you could keep the E36 booster and leave the pedal travel switch in place to hold vacuum. Anyone tried that yet?
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  10. #35
    Sep 2010
    Pacific Northwest
    Quote Originally Posted by gpeterson View Post
    I'll get some measurements before I plumb the MC...
  11. #36
    Sep 2010
    Pacific Northwest
    I took some measurements of both master cylinders last night.
    Master cylinders that were measured were:
    - E46 M3
    - E36 M3
    O-ring groove surface to end of master cylinder body E46 M3 37.65 mm
    E36 M3 44.11 mm
    Overall diameter of master cylinder body E46 M3 43.80 mm
    E36 M3 43.65 mm
    Master cylinder bore seal plate to end of plunger E46 M3 36.34 mm
    E36 M3 35.97 mm
    Push rod bore depth in plunger E46 M3 36.33 mm
    E36 M3 40.12 mm
  12. #37
    Northern CA
    1998 M3/4/5
    Thanks for the measurements. Looks like I may be ordering the Z3M booster.
  13. #38
    Sep 2010
    Pacific Northwest
    Sorry it took soo long!
    Another point of interest for people working on this project: pipe diameter.
    I don't know how many people have paid attention to the various diameters of the hard lines, but the wheel lines are different than the master cylinder.
    Master cylinder to ABS pump are: 6 mm
    ABS pump to wheels are: 4.75 mm (3/16")
  14. #39
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    Sorry for any potential OT, but does anyone have the electrical pinouts for the MK60 and related sensor connectors? I'm building a harness from scratch for an 813.3 unit out of an '03 M3 and have found a few spreadsheets, but they all seem to conflict each other in some way.
    Also, I notice there are two different yaw sensors available: a 6 pin (aluminum body) and a 3 pin (black body). The latter of the two seems to supercede all previous part numbers, which are NLA save for buying used. Which is the appropriate sensor to use, or can either be used? If so, what's the correct pinout? I bought connector and pins for the 6 pin so would prefer to use that.
    6 pin
    3 pin
    Finally, in realoem there used to be a designation for the lateral acceleration sensor, but it no longer has a part number listed and/or is NLA. Is this part needed for either ABS or DSC operation? Part I'm talking about is shown here: https://www.ecstuning.com/Search/37146781405/ES242427/. It is mounted perpendicular to the longitudinal axis of the car.
    Any help is appreciated.
  15. #40
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by ckpitt55 View Post
    6 pin
    3 pin
    I used the 1st one ... $30 on ebay. It's called a DSC sensor and has a yaw and accel in one unit. Some others have 2 separate units. As to whether it's actually required for ABS, no idea ... but for $30, why not?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
  16. #41
    san jose
    E36 S54 M3, CAAD10,
    you will be using the first one. I believe the 2nd one is for mk20 units
  17. #42
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    Thanks gents. Any help on pinouts or a wiring diagram? Having trouble finding consistent data. As mentioned I found a couple spreadsheets but none of the info matches and am not sure which is correct.
  18. #43
    san jose
    E36 S54 M3, CAAD10,
    I'm using this one currently
  19. #44
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    Awesome thread. I have Teves MK60 ABS transplanted into my E39 M5.
    --Peter
  20. #45
    Northern CA
    1998 M3/4/5
    Is there any other known booster/MC combo? The E46 MC definitely won't work with the E36 booster and it looks like the z3m booster isn't in stock in the US. Was hoping to get my car back together this week.
  21. #46
    Sep 2010
    Pacific Northwest
    I haven't tried it, but the non M Z3 MK60 booster should work. It might be worth looking into as they're cheaper and more readily available.
  22. #47
    Northern CA
    1998 M3/4/5
    Hmm.. didn't the Z3 3.0i have MK60? realoem shows it uses the same booster as many E36 models.
  23. #48
    Sep 2010
    Pacific Northwest
    The late Z3 had MK60, but you'd still need to verify the dimensions of the M/C since they look very similar. If you were to take the complete assembly it should work. The only problem I can think of is the M/C bias.
  24. #49
    Northern CA
    1998 M3/4/5
    I just ordered the z3m S54 booster, has to come from Germany as none are currently available in the US.
    Does anyone know of a brake reservoir that will fit well on an OBD2 E36? The E46 M3 reservoir's clutch nipple hits the X6031 connector.
  25. #50
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Worst case you could go with a remote reservoir.
  1. E46 FS: Teves MK60 ABS Swap Kit from E46 M3
    By Asmod3us in forum Engines, Performance Parts & Software
    Last Post: 08-12-2022, 06:55 PM
  2. Connecting to MK60 ABS unit - IFH-0009 - Help please?
    By jimmypet in forum Diagnostic Software
    Last Post: 04-30-2012, 10:30 AM
  3. E46 M3 (MK60) ABS pump hydraulic connections
    By jimmypet in forum 2001 - 2006 M3 (E46)
    Last Post: 02-17-2012, 05:13 PM
  4. ABS light info needed ASAP
    By DmcL in forum 1983 - 1991 (E30)
    Last Post: 01-08-2010, 01:16 PM
  5. e30 abs hydroblock info question
    By demomano in forum 1983 - 1991 (E30)
    Last Post: 04-17-2008, 01:34 AM
