Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 108
Thread: MK60 ABS Standalone info
  1. #76
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by Simeon Petkov View Post
    Hi guys, I am planing on doing a MK60 swap on my E36, so I am sourcing parts now. I found a 2002 E46 M3 that has this part number on the pump motor, and it is different than the 3 on the first post. I cant find info in this forum or google if it's any good. The ATE number is 10.0206-0079.4. Thanks !
    PS: Am I looking on the right place?
    That's not the part number you're concerned with ... either the BMW part number, or the number on the module is what you want, and I think you need a 2003+, the earlier ones are MK20 and useless for a swap ... but someone can confirm probably.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
  2. #77
    Sep 2017
    Plovdiv, Bulgaria
    E36 S50B32 swap
    Quote Originally Posted by ScotcH View Post
    Thanks, I was looking at the motor number. The ECU is an 813. Thanks!
  3. #78
    Jun 2003
    San Jose, CA
    '02 M Coupe, '12 C4 GTS
    (apologies for carpetbombing threads, but...)
    Is there a recipe for coding the MK60 standalone (i.e. not in an E46) using NCS Expert?
    '02 M Coupe
  4. #79
    Vancouver, BC Ca
    1993 325is
    I don’t believe any coding is necessary for the ABS to function correctly in a standalone installation.
  5. #80
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    Quote Originally Posted by DrZiplok View Post
    Nope. Wire it up, bleed the system , turn on car and drive.
  6. #81
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    I am planning to retrofit MK60 in my E30, and I dont like that the rear sensors from e46 are shorter than the E30 ones. In other words I will have to grind the trailing arm in order to get the correct spacing.
    Does anyone know if I can install front ABS sensors as rear ones (I can just do a spacer to get the proper spacing).
    Or can I use Z3m abs sensors (P/N: 34521164474) they are with grey connectors (not sure if they are compatible)
  7. #82
    Vancouver, BC Ca
    1993 325is
    I'm pretty sure someone took the grey connectors, and easily modded them to fit.
  8. #83
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    Use the late Z3 non M ABS sensors in rear that had the mk60- blue connectors. You’ll need to grind the sensor mount tab not the trailing arm.
    It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
    Turning Benjamins into noise since 1997
    I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
  9. #84
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by gobuffs View Post
    Is that a sensor that will plug into the E36 coupe chassis harness?
  10. #85
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    What about the Yaw sensor install locatio? Does it have to be under the driver's seat or it can be located somewhere in the engine bay as well?
  11. #86
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by zoomer40 View Post
    It needs to oriented a certain way, but other than that, probably does not matter much. I'd put it on the tranny tunnel. And it's only used for stability control anyway, not ABS
  12. #87
    Vancouver, BC Ca
    1993 325is
    Will the ABS report a fault without it?
  13. #88
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    Quote Originally Posted by jakermac View Post
    No. It will not report a fault (at least mine does not).
  14. #89
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    Isnt the yaw sensor necessary for some of the ABS features (besides DSC) like the function to reduce the braking power of the rear inner wheel when cornering, also disabling the ABS when the car spins?
  15. #90
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    that's part of stability control. ABS is exactly that … if a wheel locks up, ABS pulses to reduce braking pressure. It does not care if you are turning or spinning. Works great without it in our touring car.
  16. #91
    Jun 2004
    West Palm Beach, FL
    2003 M3
    Abs
    Question. Just finished a LS3 swap. Engine harness and ecu are out. All the remaining harness and brakes and sensors are still present. Will my ABS still function? 2002 M3
  17. #92
    Aug 2009
    houston
    e39, e30
    Quote Originally Posted by razormy View Post
    If it has the mk60 abs I don't see why not
  18. #93
    Jun 2004
    West Palm Beach, FL
    2003 M3
    Quote Originally Posted by howelll View Post
    Yes, I tested by trying to lock the brakes up on a dirt road and yes the ABS still works.
    Thanks for your response. Now I'm trying to figure out an alternative way to get traction control.
  19. #94
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Traction control will need the DME I think … since it uses the computer to control throttle and spark. I don't think it'll ever work with the LS DME. Standalone, for sure, but not with the stock GM ECU.
  20. #95
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    Ok, I got it running in my e30 with M54 swap. Now I am struggling with recoding the MK60 module (its 818 version if it matters). I can connect fine with INPA howerver I am not able to read it with NCS-Expert. It is throwing "VIN is Faulty" and lots of COAPI-2020 errors. I assume they are because the NCS Expert is trying to read all modules for E46 and I dont have them in my E30. Can anyone advise how to handle this?
    P.S. in case someone is interested, e46 330i rear abs sensors (blue connectors) fit e30 trailing arms perfectly with just 2mm spacers
  21. #96
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    what are you trying to recode? Don't need to do anything. INPA can read codes and values on the MK60, and that's all you need to do. Ignore the VIN error. As long as you're seeing wheel speeds, it should be good to go.
  22. #97
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    ABS itself is working fine, but speed signal output is quite off due to different size of tyres. Also wanted to try to get the dsc working (still thinking on a way to install the steering angle sensor) and also just to look at the possible settings
  23. #98
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Yeah, I don't think you can program anything in that version. Only the 813 is programmable I think, and I don't think it's done with NCS expert (I'd love tp be proven wrong, but seems this is a black art that only like 3 people know how to do … lol)
  24. #99
    Nov 2009
    Gretna, NE
    2x E46M & 3x E36M
    I have been going through all of the MK60 E36 threads and I can't find a definitive answer. I recently scored an 817 unit and want to get it in my current E36M seat-time chassis.
    Z3 3.0i booster + E46 M3 master cylinder ; does this combo work and match best for the stock E36M master cylinder?
    OR what is the shimming option for running an E46M master on the E36M booster? Ultimately looking for easiest/cheapest way to run the pressure sensors, keeping them in the master cylinder seems to be the most KISS solution.
    S54 Z3M parts are in close to Tilton pedalbox budget.. thinking if the above combination 'works' as a decent budget setup I won't have to go full Tilton..
    check out my eBay store
    E30 - E36 - E39 - E46 - E60 - E92
  25. #100
    Geigertown, PA
    95 M blk/blk
    So there is conflicting info on the brake light signal to the MK60 unit. Some guides say to ground the signal when brakes applied, one says ground when brakes NOT applied and someone else said they applied 12V when brakes applied. Which one is it?
    Also I just installed a Z3 booster from a car that had DSC and it seems to fit properly into the E36.
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  1. E46 FS: Teves MK60 ABS Swap Kit from E46 M3
    By Asmod3us in forum Engines, Performance Parts & Software
    Last Post: 08-12-2022, 06:55 PM
  2. Connecting to MK60 ABS unit - IFH-0009 - Help please?
    By jimmypet in forum Diagnostic Software
    Last Post: 04-30-2012, 10:30 AM
  3. E46 M3 (MK60) ABS pump hydraulic connections
    By jimmypet in forum 2001 - 2006 M3 (E46)
    Last Post: 02-17-2012, 05:13 PM
  4. ABS light info needed ASAP
    By DmcL in forum 1983 - 1991 (E30)
    Last Post: 01-08-2010, 01:16 PM
  5. e30 abs hydroblock info question
    By demomano in forum 1983 - 1991 (E30)
    Last Post: 04-17-2008, 01:34 AM
