Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: e34 540i M60 brake booster replacement???
  1. #26
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Quote Originally Posted by a777fan View Post
    What happens when you perform the same experiment, but suck, instead of blow...?
    Indeed, inquiring minds want to know... because there might be more valves in the works (I'ven't taken one of these apart).
    If the leak is as big as I'm picturing and it's actually a leak, I would expect brake cleaner, carb cleaner - basically, anything volatile and flammable - sprayed onto that spot to affect idle. You might just try that. It's less reliable than a smoke test, but still doesn't give false positives.
  2. #27
    Dec 2012
    Phoenix
    e34 540i 6spd
    Sorry for the delay, it's been hard to catch a break lately, and I had to change the front brakes on my land cruiser in the interim.
    I wound up buying a MightyVac for that, and used the suction cup attachment to test if the brake booster will hold a vacuum. It won't. Not at all. I am guessing that once the boot on the back cracked, dust got in the seals around the piston. Oh well. Thanks for the help.
  3. #28
    Mar 2019
    Washington
    BMW 95 540i
    I do not have OP’s problem but trying to figure out where item no. 6 connects there is not any clear diagram or anything . Very frustrating
  4. #29
    moroza's Avatar
    BFE
    E34T
    Item 6, the hose with an elbow and a checkvalve? The elbow end plugs into the brake booster. The other end connects to a hose, whose other end is a nipple on the throttle body (below and to starboard, if memory serves). The check valve is apparently missing from this photo:
  1. E34 FS: e34 540i FRONT brakes
    By EddieDV in forum Brake Kits, Rotors & Pads
    Last Post: 02-11-2013, 06:14 PM
  2. Anyone interested in e34 540i front brake upgrade
    By E34nication in forum 1982 - 1988 (E28)
    Last Post: 01-30-2008, 04:27 PM
  3. Replies: 0
    Last Post: 05-25-2007, 07:34 AM
  4. WTB - E34 540i rear brakes
    By kendogg in forum BMW Parts Wanted
    Last Post: 08-01-2005, 11:10 AM
  5. FS E34 540i Front Brake Upgrade $400 Calipers, Discs, Pads
    By Euro_M5 in forum BMW Parts For Sale
    Last Post: 05-08-2004, 03:55 PM
