Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 148
Thread: Lukas' E46 Maintenance/Build Thread
  1. #26
    Apr 2014
    Washington
    Good thing you put down a piece of cardboard!
    Sadly with the oil filled motor mounts, they tend to give away easier than the old solid style.
    Yeah the heater hose should work for now, it will also help with the oil lose as well and should help with the vacuum leak.
    Really now? I'm contemplating between the OEM Lemforder and the solid rubber ones.
    The Febi brand motor mounts are solid rubber according to FCP Euro and they're almost half the cost of the OEM Lemforder ones.
    I just don't want a harsher ride, if solid ones would do that?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Follow my Instagram to see what I'm wrenching on: @xlukaslw
  2. #27
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Corteco mounts are also very good.
  3. #28
    Apr 2015
    Trenton, New Jersey
    2003 330Ci
    Quote Originally Posted by xLukas View Post
    I just don't want a harsher ride, if soldi ones would do that?
    I doubt it, unless you put billet aluminum mounts in there!
    ...we shouldn't forget that he changed the radio oil...
    "Stop im assuming im people in the past im giving you all the info you need and all i here is bitching ......im not stupid"
  4. #29
    Apr 2014
    Washington
    Solid rubber Febi it is.
  5. #30
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Correct the oil filled ones are just there to absorb more drivetrain vibration.
    As a plus, they will last 10-15 years and this will be the last time you will have to mess with them.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  6. #31
    Apr 2014
    Washington
    Let's hope I'm not vibrating the entire car everywhere.
  7. #32
    Aug 2014
    Lawrence Kansas
    Hydraulic mounts are by far superior to solid rubber when it comes to vibration. But they wear out faster for the same reason.
  8. #33
    Apr 2014
    Washington
    I guess I will find out if the mounts are horrendous. The only way I will really know is if I try them out myself with all of the mixed opinions of them.
    This PCV modification or delete if you would seems very interesting and tempting:
    http://www.xoutpost.com/bmw-sav-foru...-problems.html
  9. #34
    Apr 2014
    Washington
    3/8" hose on PCV/CCV to dipstick tube
    I had to take a few moments enjoying the clean tray.
    And
    Missing lower hose. Maybe that's why the Service Engine Soon light came on when my dad drove it home.
  10. #35
    Apr 2014
    Washington
    Reset the P0420.
    Drove to O'Reilly's, replaced the hose for a whopping $0.53 with some left over to do it again.
    No code has come back yet.
  11. #36
    dworthy's Avatar
    Nov 2010
    Yup that was a vacuum leak. What I would do is go thru every inch of rubber hose on the intake, and as you can see the intake boot is starting to crack. Go ahead and get the lower and upper boot, as one will fail after the other and no need to go in there twice! Also look at the other side of the motor, where the SAS is, that valve on the YM-03's and older still use a vacuum line.
    Darin
    Current:
    Past:
    M-Flight Member
  12. #37
    Apr 2014
    Washington
    I believe I've got a radiator to replace before I even think of replacing the entire intake unit boots and all vacuum hoses.
    First picture is just below the upper radiator hose neck.
    I believe it is coming from between the seams where the metal and plastic meet as well.
  13. #38
    dworthy's Avatar
    Nov 2010
    How does the bottom of the radiator look? Is it sagging like some people pants? If so, it is time for a replacement anyway, as 100k is a pretty long time for a plastic and aluminum radiator.
    Darin
    Current:
    Past:
    M-Flight Member
  14. #39
    Apr 2014
    Washington
    I looked for that when I had the fan off, it looked fine and I didn't notice any sagging.
  15. #40
    Apr 2014
    Washington
    Does my auxiliary fan switch need replacing if this happens? Video has many dislikes, possibly he's wrong?
    Mine kicks on eventually (with AC on), and I'm not overheating. It'll inch along like shown in the video though.
    https://www.youtube.com/watch?v=50PIceJUScw
  16. #41
    dworthy's Avatar
    Nov 2010
    The fan should cycle with the A/C compressor, and if it is the only time it is coming on, don't worry everything is normal. If you were down south, I would be more worried but as long as the clutch fan is working properly you won't overheat.
    Darin
    Current:
    Past:
    M-Flight Member
  17. #42
    Apr 2014
    Washington
    Sweet, thanks dworthy.
    I know my transmission requires 9.5 quarts of ATF with the torque converter. I'm only supposed to be able to get around 4 or 5 quarts without having some type of evacuator, since most of the ATF is left in the torque converter.
    Can someone confirm how many quarts I will need just to change out the fluid to change the filter and gasket? I was planning on just buying the whole 10 quarts to flush it, but I'd rather drive it for a little while then change the fluid again to get all of the old stuff out.
    If I could flush in one go like shops do it, that'd be ideal but I don't have an evacuator.
  18. #43
    Apr 2014
    Washington
    I'm getting really sick of BMWs fragile plastic components. Wish they were an aluminum.
    Was replacing my radiator, expansion tank and the hoses and the stupid transmission oil cooler thermostat broke.
    I'm not sure what the three gaskets they sent with the rad are for.
    Messed up the socket a little when removing the bottom half of it. Do you guys think the socket is still good?
    Oh, and most of the 'coolant' was see through as in likely 90% of it was plain water. Good thing I'm doing this.
  19. #44
    Apr 2014
    Washington
    Replaced all of the components. Nissens radiator, Meyle expansion tank, Rein upper and lower radiator hoses and the transmission thermostat. Finally finished and filled up and bled just a little bit ago. Brought it to temp and watched the needle. It stayed at 12 o'clock.
    I hope I'm done wth the cooling system at least for a little bit.
    Only thing I'd be worried about right now is the automatic transmission thermostat socket and air being in the system since it was my first time bleeding a cooling system.
  20. #45
    dworthy's Avatar
    Nov 2010
    You can see the brown stain from the old o-ring, but I would feel more comfortable with replacing it. When the plastic gets that brittle, it doesn't take much to finish breaking the rest of the way.
    Darin
    Current:
    Past:
    M-Flight Member
  21. #46
    Apr 2014
    Washington
    Drove it, and nothing went past 12 o'clock.
    Checked the expansion tank and I've added fluid before driving. Drove it two miles and I'm low again. And I now see this..
    This better not be a headgasket. I just replaced all of these cooling components and now this shows up?
  22. #47
    Aug 2014
    Lawrence Kansas
    Thats nothing to worry about. Its a oil vapor/condensation mix that attaches itself to the highest point in the engine. Its the result of a cold engine heating up and a warm engine cooling off. It will burn itself off the longer its driven. Completely normal. Every vehicle I have ever owned has done it and it's worse in the winter.
  23. #48
    Apr 2014
    Washington
    Quote Originally Posted by dhurley34 View Post
    I know of this and I've only driven a couple miles, though it hadn't happened before I did the cooling system replacements. What worries me is that I'm losing coolant, see no external leak except maybe a drip of residual coolant from bleeding, and saw this. It freaks me out.
  24. #49
    dworthy's Avatar
    Nov 2010
    It is called "Burping". Once the system heats-up and the thermostat opens, it pushed the rest of the air out of the engine into the surge tank. Very normal if you don't use a vacuum system filling style. You may have to top it off once more, so expect it.
    Also the little bit of condensation on the cap is normal, as any drive below 20 minutes isn't enough for the CCV system to do it's job properly.
    Darin
    Current:
    Past:
    M-Flight Member
  25. #50
    Apr 2014
    Washington
    Thanks for the reassurance. I was worried there. Topped it offer before work, went to work and checked the level afterwards, it was still the same. I believe it was "burping." Especially the first time I drove it after replacing the cooling components, I heard a hiss when I turned off the engine.
    Went to Walmart and picked up some Supertech Dexron VI for the transmission fluid, filter and gasket change. Only was able to get three quarts tonight though.
    According to the Bentley I only need 4.2 quarts to change the fluid, without the use of using a flushing system to remove the rest from the torque converter!
  1. E46 Widebody Build thread
    By jhstealth in forum BMW Rides & Events
    Last Post: 12-23-2016, 07:15 PM
  2. KhanArt's Jet Black /// Cinnamon 6spd E46 M3 Build Thread
    By KhanArt in forum 2001 - 2006 M3 (E46)
    Last Post: 09-03-2015, 09:23 AM
  3. RCSummers e46 M3 Build Thread
    By rcsummers in forum BMW Rides & Events
    Last Post: 10-01-2014, 01:49 PM
  4. Mishimoto E46 M3 Build Thread
    By Mishimoto in forum 2001 - 2006 M3 (E46)
    Last Post: 03-29-2014, 10:32 PM
  5. KhanArt's Jet Black /// Cinnamon 6 Spd E46 M3 Build Thread
    Last Post: 11-02-2013, 08:33 AM
