Hi,
Thank you for letting me join such a great forum.
Have anyone experiensed that the climatefan in your car wont work?
The car has been parked for a few months, and when I first started it, there came a message showing increased battery discharge. However, the message is now gone.
The car is a 2012 525xd which i received today:') Unfortunately, i have no warrenty on the car.
Could be the blower motor, or final stage resistor. Or possibly, the battery is too weak, and it's not allowing the fan to run.
If you follow the following video, you will be able to get to the final stage unit (Blower motor resistor) and Blower Fan. in my case i didn't need to change it. While you are in there most likely your foam on the blower motor housing is also damaged. you can use the following video to get those fixed your self. Remember to disconnect Battery before doing this work.
How to remove leaves/debri from blower motor BMW F10:
https://youtu.be/J4HcNS2kvuQ
How to fix the Blower motor housing with missing foam:
https://youtu.be/BCVUEqUItok
