Results 1 to 6 of 6
Thread: Power Steering Pump Purchase Options
    May 2016
    Tampa Bay Area, Florida
    2004 BMW 325i base model
    2004 235i base model. Automatic Transmission) 107K mile
    LUK LF-20 just broke it's shaft and shafted me so, now I am searching options for purchase. I've read that in the past few years the LF-20 is more durable than previous years. Also, I'm not too interested in the LF-30 as from what I've read steering is not as tight comparitively.
    I can't drop $400 to $500 for new OEM so, I am seeking input in the following optons for LF-20 replacement:
    1) Used. I have one lined up that's already pulled $75 with 30 day warranty.
    2) Cardone brand: $125 used. $100 remanufactured.
    3) Ebay: Various chinese made ranging from $50 to $100 1-year warranty
    4) This one: http://www.1aauto.com/bmw-power-stee...=514664&y=2004
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Used for $75 unless the Cardone is a reman genuine LUK. Careful with the pulley, it's plastic.
    May 2016
    Quote Originally Posted by dhurley34 View Post
    Okay. I am going used and can pull one from a local salvage yard for $20 if, I can find a car that still has one. Thanks.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Try fcpeuro for an OEM pump. A pump fails because of the owner failed to perform maintenance such as a fluid flush.
    Also, you should replace the reservoir as the filter in the bottom gets gunked up. Buy a genuine ZF reservoir. The hoses that attach to the reservoir need to be replaced, too.
    Mar 2011
    NorCal
    90 E30, 00 E39, 01 E46
    i would go either used if on limited funds if the condition of the pump itself is in good working order and everything is tidy. nothing wrong w/ going used depending on the situation. otherwise you could get a new oem pump from fcpeuro for about 250. they also sell the cardone manufactured one as well for 125. shipping should be free but the plus buying from fcpeuro is the parts come w/ a lifetime guarantee. they are pretty good folks to work with. definitely would consider getting a new reservoir if you are already doing this as the screen filter usually gets pretty dirty and not worth removing to clean. that will run you about 20 new. they do price matching as well. i just placed an order today w/ them. good luck.
    cheers,
    larry
    Quote Originally Posted by edjack View Post
    "The fact that you can afford to buy a BMW does not mean that you can afford to own one."
    May 2016
    I ended up finding a used pump fro $50 pulled with 100k miles on it. I purchased a new oem ZF reservoir and both hoses that attach to the reservoir. Also, purchased this tool: https://www.fcpeuro.com/products/bmw...-tool-cta-3466 which works great.. disconnected it in less than a minute and without removing headlight assembly. The person I purchased the PS pump from gave me a 3 month warranty and is a local Ebay seller. He said even if it's out of warranty he'll replace it either free or half the price.
  1. Power Steering Pump Options
    By rajicase in forum 1991 - 1999 (E36)
    Last Post: 12-02-2014, 04:41 PM
  2. Power Steering Pump going bad - options?
    By turnerNCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2008, 10:55 PM
  3. signs of a bad power steering pump?
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2002, 02:05 AM
  4. Best place to get power steering pump?
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 06-10-2002, 05:53 PM
  5. Power steering pump
    By mytran in forum 1991 - 1999 (E36)
    Last Post: 02-28-2001, 12:31 AM
