I tried searching for the steps, but seems like the threads I found were of people having problems pulling codes.
My INPA seems to be working fine, but my menus are all in German. Since it is already installed, so I just need to go into the inpa.ini file and change the language to English?
I just don't want to mess up the application by doing something stupid.
Thank you in advance!
'07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
'02 e46|M54 - Orient Blue|Beige|'Vert|GONE
'00 e39|M52 - Anthrazit Metallic|Grey|GONE
'01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
'91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
'13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
'05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
'07 335i Auto - Montego Blue|Grey|GONE
'05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
'97 528i Auto - GONE
Any help here?
You are correct, the language setting is in INPA.ini - make sure you set it up to use the correct files - English or English.metric and depending on the version of INPA you are running, the language may be spelled as Englisch.
I have checked all the .ini files for both versions of INPA. The main menus are all in English. But submenus (like when I go into engine diagnostics and the menu is all in German. I just don't get it because all the ini files show englisch.
Sorry to revive this guys but did anyone have a solution to this?
Sent from my SM-G960U using Tapatalk
You can set the language in inpa.ini.
Check if the folders contain .ENG files. If there are only .GER files, changing the language won’t work.
I set the .ini file with English and I do have .eng files but for some reason only the inpa home screen is in English. As soon as I select e46, all the selection icons on the bottom turn to german
You need to reinstall EDIBIAS.
When installing it, choose properly the configuration :
(took the image randomly on Google)
Choose BMW Group rectification programs USA or UK and you'll have INPA in full english.
I was leaning towards trying the install again. I selected UK last time, I'll try USA this evening after work. Thanks for all the advice, truly appreciated!
All a reinstall does is change the inpa ini, iirc.
Partially true. It also adds any available English .prg files into C:\ediabas\ecu\ folder. These files are responsible for error memory being in English or German.
I have put together as many English .prg into this pack as possible for whoever wants to snoop.
https://www.bimmerforums.com/forum/s...xperimentation
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Did a full reinstall, tried the USA selection, still only getting the initial screen in English. Any suggestions anyone?
Learn German.
Ja lol
But on a serious note I did figure it out this morning. For anyone else that may have this issue in the future, on the disk there was a folder EC-APPS that you copy onto the C drive, this is not the correct one. Inside the folder marked Step 1 there is another folder labeled EC-APPS... this is the one to copy to the C drive! I am not a tech guy so unfortunately I dont know the differences between the files, however I can tell you that by saving the one in the Step 1 folder it worked for me. Hope maybe one day this helps someone else out. And to everyone that helped me, thank you very much!
