Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
Thread: Please help me get ISTA/D to work!!!
  1. #51
    Jul 2014
    Louisiana
    1995 M3
    Quote Originally Posted by deadremix View Post
    is this possible to do?
    keep the ediabas from stand alone installer 7.0.3 and the one from bmw standard tools installed but rename the folders in c drive, and change C:\Rheingold\Ediabas\Bin to OLD_BIN and install bmw standard tools again and set installation path to C:\Rheingold\Ediabas or do i have to completely uninstall both ediabas.
    also this is my k+dcan cable. you guys see anything wrong with it?
    Attachment 577691
    Attachment 577692
    Read several above posts...there absolutely no reason to changing or renaming anything. If your Windows system hasn't protested when you plug the cable in...then, it's okay or if it does, you can try FTDI drivers 2.10.00 or 2.12.00 for 32bits system...they won't work for 64bits.
  2. #52
    Jan 2016
    OC - Garden Grove
    E90
    Ok here is an update.
    i updated the ftdi drivers to 2.10.00 and my K+Dcan cable still doesn't work. so iono if having the latest drivers messed it up or something. However i tried my vagcom kkl 409.1 cable and i was able to do the vehicle identification process so i can conclude that the k+Dcan cable could be a faulty one or somehow i messed it up. now my next question is what is the difference between the two cables? are there limits to what the vagcom kkl 409.1 can do vs the k+dcan cable? do i have to do anything differently?
    tested on an 06 bmw 325i.
  3. #53
    Jul 2014
    Louisiana
    1995 M3
    Be sure when you removed the previous driver to install the 2.10.00 you had checked this box with the green arrow in the middle below...see pic. You can check 328 Power 04 on the cable differences.
  4. #54
    Jul 2004
    Houston, TX
    36 Cylinders
    Odd to see some cables work with the newest FTDI drivers (2.12.16) and some do not, and a downgrade fixes it. How annoying.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  5. #55
    Jan 2016
    OC - Garden Grove
    E90
    Quote Originally Posted by NolliM3 View Post
    yup i did that haha
  6. #56
    Jul 2014
    Louisiana
    1995 M3
    I had to used FTDI driver 2.12.16 because of Windows 7 64bits which I have to manually upgrade; however, I am not sure my FTDI-K+DCAN cable totally working as I don't get the voltage info for KL 15 and KL 30.
  7. #57
    Brønnøysund, Norway
    92' E36 325i Coupe
    Nice to see more ppl having problems with this:p I'll have to test out some of the stuff written here
  8. #58
    Jun 2013
    United States
    2002 E39 M5
    I always tell people to solder a bridge between pins 7 & 8 and that usually solves the cable issue(s). Not sure why it isn't suggested more.
    '02 TiAg/Blk E39 ///M5
    '08
    JZB/FR E92 ///M3
  9. #59
    Oct 2016
    Ontario, Canada
    E90,E83
    Hi Just had the same problem reading out VIN on 2010 E83 with ISTA+ and K+DCAN cable bought from ebay. Weirdly enough, it did work on an 06 E90 (reading out VIN)
    I have no idea what is going on with either cable or ISTA, just assuming the cable is not faulty simple because it works on an E90. So does ISTA
    COuld anyone shred light on this? Thanks in advance
  10. #60
    Dec 2016
    https://t.me/pump_upp
    2014 BMW 328xi
    I got same error “The vehicle could not be identified. Please check the access to the vehicle and check wheher testing-analysis-diagnosis has been activated”. I installed ISTA-D v4.02.30 and I'm trying to connect to f30 (2014) using ENET cable. I have no problem with ESYS or Dr.GINI with this ENET cable.
    Do you have any idea ?
  11. #61
    Dec 2008
    Bucharest, Romania
    BMW X3 3.0 SD, Mercedes ML 420 CDI
    Same problems here.
    Win10, X64
    K+DCan cable
    BMW X3 E83 2007 (facelift)
    Cable driver CDM v2.12.26 WHQL Certified (latest)
    I get the same error: the vehicle cannot be identified.
    INPA is "working" - it detects the battery and engine, but no communication is possible.
    Another problem is that I use a Macbook, with USB-C and adapter from USB-C to USB.
    I hate this...
  12. #62
    Jul 2004
    Houston, TX
    36 Cylinders
    What month and year is your X3?
    -Abel
  13. #63
    Dec 2008
    Bucharest, Romania
    11.2007
  14. #64
    Apr 2017
    Fayetteville, Arkansas
    2013 BMW X5 xDrive35i
    Does it have to be COM9? I thought it was determined by the computer. If the computer has only one USB port, it is supposed to be COM1, right?
    Make sure it's set up as "Interface = STD:OBD"
    It doesn't really matter on the IP addresses or remote host, since you will be configuring your ISTA / D to run Ediabas directly through OBD profile (unless you are running in Virtual Machine?). Just make sure your cable is COM9 in Device Manager now.
  15. #65
    Jul 2004
    Houston, TX
    36 Cylinders
    COM number has nothing to do with how many USB ports your computer has. COM number is a virtual number for USB devices.
    I was saying *for that specific user* that it needs to be COM9 because his setting is at COM9.
    The COM number setting in C:\EDIABAS\BIN\OBD.ini MUST match the COM port number from Device Manager. Doesn't really matter which COM number, but as long as either one is changed to match, then it will work. Personally I wouldn't set it over COM9, because some programs use a single digit number.
    -Abel
  16. #66
    May 2017
    South Carolina
    2011 335d, 2003 Cobra
    Sorry to bump this one. Having the same issue and wondering if anyone figured out their issue.
  17. #67
    Nov 2011
    Las Vegas
    Quote Originally Posted by GodStang View Post
    What exactly running ISTA+?
    PROFESSIONALLY CREATED BMW DIAGNOSTIC SOFTWARE
  18. #68
    Aug 2017
    NYC
    2008 550I / 2006 M5
    328 Power 04
    Your info is great, thank you for all your help.
    I am almost there installing this program, the issue I have is I cannot locate the OBD.ini file. I located the Edbias.ini but NOT the OBD.ini file.
    ANyway you can help.
    I am trying to reset ELV have the car stuck in my backyard with no way to fix or move
    overtizjr@gmail.com
  19. #69
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by OVERTIZJR View Post
    328 Power 04
    overtizjr@gmail.com
    It will probably be better if you install BMW Standard Tools 2.12 (easily found on google) to make sure all your ediabas files are present and correct..
    But here's my OBD.ini
    obd.ini.txt
    **You must rename it back to OBD.ini from "OBD.ini.txt" I had to add '.txt' extension to be able to post it here.**
    -Abel
  20. #70
    Aug 2017
    NYC
    2008 550I / 2006 M5
    please help
    obd.ini.txt
    Almost giving up on this task 2 days non stop and still system not able to pick up car information, system unable to identify vehicle. not sure if the usb port set up.
    any chance you would be interested in skype session you can take control of computer to install it remotely? can pay for the session.
    Just stuck with no car =( overtizjr@gmail.com
    endless articles and intructions but no luck fixing this
  21. #71
    Aug 2017
    NYC
    2008 550I / 2006 M5
    Hello 328 power
    obd.ini.txt
    I think I m getting closer, I found the SQlitedbs folder empty?? getting error message when I start the program.Please check DSS #00046632EN
  22. #72
    Jul 2004
    Houston, TX
    36 Cylinders
    Sorry I missed your messages, been quite busy here.
    The ISTA-D download should include sqlite db files. They are roughly 9gb, that unpack to about double that. The ENGB and OTHER are minimally necessary.
    -Abel
  23. #73
    Sep 2018
    USA
    BMW M6
    Lightbulb Are YOU aware that Rheingold USA was the first ones who build the ISTA software?
    Are YOU aware that Rheingold USA are the ones who build DSS then Rheingold from the beginning and currently owns the copyrights for it?
    It's 2018 right now and they just released their 2018 late model edition, still won't believe it ? go visit them on site at their physical office at 3450 Triumph Blvd , Lehi UT 84043, USA.
    I know this is pretty old thread, I am writing this reply to show some appreciation for the the Rheingold USA folks who helped me with an authentic high quality licensed software after I bricked my M6, they helped me to get it back ON after 20 minutes of using their certified ISTAD then ISTAP, when you spread a word , spread it with knowledge and evidence please.
  24. #74
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Tom.G View Post
    What are you on about? Rheingold USA built nothing and own nothing. They are simply reselling the same pirated versions that can be found online.
    This is the only place for authentic ISTA D&P in the USA: https://www.bmwtechinfo.com/
    -Abel
  1. Please help me get my ECU re-installed
    By 97 MPWR in forum 1992 - 1999 M3 (E36)
    Last Post: 10-17-2003, 03:15 PM
  2. PLEASE help me get my M3...
    By AvusBluR in forum Off-Topic
    Last Post: 12-20-2002, 01:16 PM
  3. Help, cant get boost guage to work
    By 3deep in forum Forced Induction
    Last Post: 09-23-2002, 08:12 PM
  4. DAMMIT! Someone please help me get rid of this noise!!!
    By M325M in forum 1991 - 1999 (E36)
    Last Post: 09-20-2002, 10:32 PM
  5. Car Buying Experts.....Please Help me get a good deal on a 02' 330Ci............
    By LiLCeeS in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-09-2002, 01:26 AM
