Originally Posted by
blackknight530i
Once again, people are confused with the e38 and e39 diff case sizes. The 96+ e38 and pretty much all e39s other than the M5 have 215k diffs (V8s that is), while the M5 has the 210 diff case, much like the old e32 and 95 e38. The 215 gears and 210 gears are not interchangeable and neither are the cases.
The first question for the OP is whether or not the e39 4.10 diff he has is from a 540i, or one of the I6 cars. If it's from an I6 car (528i, 525i, 530i), you can go ahead and scrap the idea, because they have a 188k case, which is not interchangeable at all.
So, what options do you have if the 4.10 gearset is a 210? Well, this has been said many times in many threads, but you can get a 95 e38 differential (has 210 gears, but open diff and is already a 3.15 ratio) and swap the gears to the 4.10 and if you want at that point, stick a 210 LSD unit in it from either an e32 (88-89 750il), e39 M5, or e46 M3. There might be others with this case size, but those are the most common. Put it all together and you can install basically plug and play into your e38. I think 4.10 in an e38 might be a bit too short of a ratio, but that's up to you to decide. Most e39 M5 guys stick with about 3.62/3.64 or so, but some have gone shorter. The point is, you still need to buy two more differentials to make your 4.10 gearset work in your car, which will end up being very pricey, though not as bad as a built-to-spec diff I guess.
I think another option you might want to consider is to get a 95 e38 differential and swap the internals from an e46 M3 into it, making a 3.62 LSD. Again, still requires buying 2 differentials, but you can sell your 4.10 to help fund it and the e46 M3 differentials are easier to find and not terribly expensive.
Oh, and you'll need specific output flanges to work with the LSD and your current axles as well. The easiest option there is to get the e39 M5 flanges and use the pre-2001 (I think) 102mm axles.
If you don't mind modifying the rear subframe a bit, you can also just buy an e39 M5 LSD differential and install it in the e38 by cutting and rewelding the rear diff mounts closer to the center of the subframe. Ask 007008 about that.
