Results 1 to 25 of 32
Thread: Fog light compatibility
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Hey guys,
    I know the 4 & 6 cyl front bumpers are interchangeable. What about fog lights? Are they the same? Or does the 6 cyl bumper have different ones?
    if they are different, are connectors the same? Or do I need adapters? I will leave my car tomorrow morning in the body shop for a front bumper and hood respray and im still undecided on putting a new 6 cyl bumper on my 4 cyl or fixing the one I currently have...Help!
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    I had read this post a while ago, but didnt remember. So looks like fogs will swap, just need new plastic covers? Thanks Vintage
    Oct 2012
    Louisville, KY
    The 4 cyl fog light has a plastic cover beside it to fill the remainder of the opening. The 6 cyl opening is smaller and is completely filled by the fog light. Here are the two bumper covers:
    As for whether the fog lights are the same, I think so. I think the fog lights for the 4 cyl, the 6 cyl, and the 5-er are the same:
    http://www.ebay.com/itm/160954262674...84.m1423.l2649
    BMW MOA 696, BMW CCA 1405
    Redding Calif
    1999 Z3 2.5L 5sp
    Quote Originally Posted by Vintage42 View Post
    There is a large interchange list for the fog lights - use the RealOEM list... mine came from a 540i.
    Though I wonder if it is I-6 vs I-4 in terms of plastic cover besides lamp housing - I have 2.5L and also the cover piece ??
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    That's not correct - both have a cover, but it's just smaller on the 6 cylinder bumper. I have both types of bumper, and they both have a cover.
    Oct 2012
    Louisville, KY
    Does your 6-cyl bumper look like the picture on the right in Post #4? It does not look like the openings in that bumper have the space and mounting holes for both a fog light and an adjacent plastic cover.
    Yet, I do see a cover (No. 12) on the RealOEM page for the 6-cyl bumper here:
    http://www.realoem.com/bmw/enUS/show...diagId=51_2328
    But since the fog light is the same, the 6-cyl cover must be a bigger than the 4-cyl, to fill the wider opening.
    Tim @ BMW of Dallas
    98 Z3 2.8
    The 6-cylinder has a cover, but it is smaller than the 4-cylinder cover.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Oct 2012
    Louisville, KY
    ... since the fog light is the same, the 6-cyl cover must be a bigger than the 4-cyl, to fill the wider opening.
    Quote Originally Posted by Tim95M3 View Post
    How can it be smaller, if the 6-cyl opening is wider and the fog light is the same?
    The center lower opening is wider on the 6's, I'm not sure either way regarding size - but if the 6cyl fog cover is smaller, I'd imagine that is why
    PRICE CUT on ALL FABRICS
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    The 6cyl opening is narrower, as per your picture (6cyl on the right)
    Oct 2012
    Louisville, KY
    Quote Originally Posted by BladeRunner919 View Post
    So it does not look like there is any space next to a fog light for a cover. Can you post a photo of your 6-cyl bumper showing a fog light with a cover in the same opening?
    Tim @ BMW of Dallas
    98 Z3 2.8
    Not mine, but here you go.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    May 2016
    Eureka Springs, AR
    2000 BMW Z3 Roadster 2.5
    My 2000 is a 2.5L 6 cyl. and it has the covers next to the fog lights. As a matter of fact, I have to order one for the right side as it was missing when I bought the car.
    2000 Atlanta Blue Z3 2.5L 5 speed manual with factory hartop.
    RealOEM lists everything the cars came with, why not just look there?
    6 cylinder bumper uses trim piece 51118399333 and 51118399334
    Pre-facelift use fog lights 63178360575 and 63178360576
    Post-facelift ists fog lights 63178381977 and 63178381978 or 63178377941 and 63178377942 (but # also exchanges with pre-facelift fog part #'s)
    Trim piece:
    4 cylinder bumper uses trim piece 51118398011 and 51118398012
    Uses foglights same as pre-facelift 6cyl 63178360575 and 63178360576
    Trim piece:
    Redding Calif
    1999 Z3 2.5L 5sp
    Quote Originally Posted by ArkansasTed View Post
    I had the same situation, but both were missing... actually it wasn't until I came here and started seeing pictures of other Zs where the foglight area looked different, and then got pointed to RealOEM to find the part numbers etc..
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Pretty informative thread. Realoem only gives you part of the story if you ask me, the other is the member's actual experience in swapping stuff...thanks to all!
    Oct 2012
    Louisville, KY
    Interesting that only the 4-cyl trim piece has a hole in it. That is for the tip of the OBC's temperature sensor in the piece by the driver fog light.
    http://www.ebay.com/itm/BMW-E30-E31-...ZRdrh7&vxp=mtr
    San Diego, CA
    325ci Cabrio
    I have both a 4cyl and a 6cyl Z3. Both 100% have caps but of different sizes/shapes. The temp sensor for the 6cyl OBC is located ib the grill opening, while the 4cyl is located alongside the fog light.
    -Dusty
    05' BMW 325ci, Sapphire Black
    14' Porsche 981, Guards Red
    17' Tesla Model-X, Deep Blue
    81' DeLorean, Stainless Steel
    Oct 2012
    Louisville, KY
    Quote Originally Posted by E36ic4Me View Post
    ... The temp sensor for the 6cyl OBC is located ib the grill opening, while the 4cyl is located alongside the fog light.
    My 1997 (10/96) has two sensors. A probe by the foglight senses temperature for the OBC computer display. And a button by the grill senses temperature for the heated windshield washers and mirrors, which was an option. Later, when the 4cyls were gone, the OBC probe was moved to the grill location. Perhaps there was no room for it next to the foglight in the 6cyl bumper.
    This shows the two different temperature sensors.
    http://www.bimmerfest.com/forums/sho...83&postcount=8
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    vintage I think we have almost identical cars... Same year, color, engine and production month. Interior?
    however, mod-wise you are leagues ahead! Here are the specs of mine..image.jpg
    Oct 2012
    Louisville, KY
    Quote Originally Posted by RedZeddy View Post
    Both are 4-cyls, Hellrot red with Beige interior.
    Mine was built on 1996-10-04 with last seven of the VIN being LB77787.
    Yours was built on 1996-10-14 with last seven of the VIN being LB78415.
    In those ten days, 628 Z3s were built.
    Apparently all 4-cyls, as RealOEM does not show a 6-cyl until Jan 1998.
    Mar 2003
    somers,ny
    Quote Originally Posted by BimmerBreaker View Post
    Trim piece:
    Trim piece:
    old post.....
    but when was the face lift?
    Sep 2016
    Yulee, FL
    2000 Z3
    Mine '00 doesn't have fog lights. Do the factory fog lights work well? I have been considering a retrofit vs aftermarket.
    Stubbornness is a virtue....
    Mar 2003
    somers,ny
    I feel they are decent yes.....nice width.....
    if u want something to fit in your oe bumper, they are good enough....but mine are not wired to be used along w/ brights at same time...Id guess as per oem wiring
  1. fog light compatability
    By richpngu in forum 1996 - 2003 (E39)
    Last Post: 02-09-2012, 12:34 AM
  2. Fog Light Questions
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2007, 05:00 PM
  3. Fog Lights Compatible...
    By 2MCHM4U in forum 2001 - 2006 M3 (E46)
    Last Post: 02-07-2003, 02:19 PM
  4. my fog light is cracked
    By Atticka in forum 1991 - 1999 (E36)
    Last Post: 03-30-2001, 06:19 PM
  5. f/s fog light passenger side
    By kosta in forum BMW Parts For Sale
    Last Post: 03-02-2001, 03:41 PM
