Results 1 to 3 of 3
Thread: 1974 '02 rear brakes on all the time
    Jun 2016
    NH
    Hey Gang, My '74 '02 has had a problem with the rear brakes. It's as if someone is applying the brakes all the time. I have solid brake lines going to the rear cylinders, new rear cylinders, new pads, rotors and emergency brakes. If I adjust the brakes they spin fine, but as soon as I apply the brakes they lock up. The system has been flushed several times so that's not it either. Could it be the master? What do you think?
    Tavernier, Florida
    '99 2.8&Mcoupe, '03 Mini
    Have you replaced the flexible rubber lines leading to the rear control arms? If they are original, it is likely they are collapsed internally and are acting like a check-valve.
    -Donny
    Savannah GA
    '73 ///M2, '85 ///M635
    When did that start happening? Maybe the wheel cylinders are E21 units (bigger)?
    Ask at 2002faq.com also...
    Cheers,
    Ray
  1. Brake light indicator on all the time
    By Motohip in forum 1983 - 1991 (E30)
    Last Post: 09-18-2012, 07:46 AM
  2. Replies: 6
    Last Post: 10-17-2010, 07:45 PM
  3. brake lights on all the time!!!
    By jakedaniel in forum 1991 - 1999 (E36)
    Last Post: 11-12-2007, 09:39 PM
  4. sidemarkers on all the time
    By salvia.D in forum 1991 - 1999 (E36)
    Last Post: 05-25-2004, 04:58 PM
  5. Heated Mirrors ON all the time ???
    By SnowDriver in forum 1992 - 1999 M3 (E36)
    Last Post: 05-14-2003, 04:57 AM
