Page 6 of 8 FirstFirst 12345678 LastLast
Results 126 to 150 of 178
Thread: Hillclimb Racecar turbo E36 M3 Build
  1. #126
    Mar 2013
    Upstate NY
    M3
    Wow, that's a good one. I literally wrecked my M3 the SAME exact way! Less damage on the front but the rear end is identical and the front passenger fender too. I just did exactly what you're doing, swap and repeat. Salvage what you can, keep on going. Nice chassis, looks clean. E36 will stay cheap for awhile. Nobody wants them and they make cheap racecarrrrrs. I think there's a saying Race, Reck, Repeat? Haha.
  2. #127
    Geigertown, PA
    95 M blk/blk
    Quote Originally Posted by Mklock View Post
    Yeah man! I just checked out your thread too, you went waayy deeper with the whole rotisserie and engine bay painting, hats off to you sir. Did you wreck the car in the thread, or before that?
    Quote Originally Posted by chippyb13 View Post
    Great thread! I’m new to the forums but have been building a car to do similar events with. I’m fairly local too! Was wondering if you had some insight on manifold choices as I’m using an efr turbo myself.
    As far as I knew, the steed was the only one that fit the efr for bottom mount but just recently I though I read someone was trying it with a SPA? I strongly suggest a bottom mount for any type of racing so when you crash the car the turbo and manifold is protected. This was my number one concern when deciding between top and bottom mount and unfortunately I got to prove myself right, lol.
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  3. #128
    Mar 2013
    Upstate NY
    M3
    I wrecked mine mid thread just like your car. In October is when I hit a guardrail. Really sucked but in the end, I got an easier to pass emmisions car and it's 100% right from bumper to bumper.
  4. #129
    Geigertown, PA
    95 M blk/blk
    Finally back into it! Interior is gutted and i cleaned up all the cage attachment points to make the job easier for the cage builder.
    I was able to cut out the entire cage from the wrecked car and bought it along to the cage builder so they can hopefully save some time using it as a template and save me money in the long run
    While the car is gone i am going to tear down a spare S52 and drop the block at the machine shop to see I need to order 86.5 or 87. Pistons.
    I picked up a ram cummins as my daily so i am trying to sell my 150k mile 535xi and have no interest at $4500!! I heard the headlights are worth like $500 each, and a healthy n54 maybe 1800....might have to a part out a good perfectly running car to get some money out of it, lol?!
    96 328i ITR Racecar
    2002 325XiT - daily
  5. #130
    Geigertown, PA
    95 M blk/blk
    CAR BACK FROM CAGE SHOP!
    There is so much to do now, I dont know where to start, lol.
    I have a motor torn down and ready to send to machine shop. I was initially going to have the shop assemble the bottom end but I dont see any reason I cant do it, right? I just need to buy or borrow a ring filing machine thingy. So someone correct me if I am wrong, but is this a good recipe for a modest build?
    1. send block to machine shop so they can see if boring to 86.5mm will be sufficient or go all the way for 87mm
    2. buy JE 9:1 pistons and eagle rods
    3. machine shop bores after they get the pistons
    4. crank journals look good (to my untrained eye) so I can just buy Glyco standard size crank bearings for $100 (white or yellow??)
    5. buy new crank main bolts
    6. buy standard size rod bearings for $60
    7. Install crank bearings, crank, bearings and caps
    8. File rings to ?????
    9. Install wrist pins (the machine shop said this clearance needs to be check and possibly adjusted, is this true?)
    10. Install pistons with ring compressor
    11. install and torque rod bolts (possibly check with plasti-gauge at this time?)
    12. New oil pump chain and crank sprocket and tack weld nut (I heard this is good to help oil pump prevent failures)
    96 328i ITR Racecar
    2002 325XiT - daily
  6. #131
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by bimmerbumm193 View Post
    4. crank journals look good (to my untrained eye) so I can just buy Glyco standard size crank bearings for $100 (white or yellow??) Have machine shop check the crank, maybe polish journals if not too expensive.
    5. buy new crank main and rod bolts
    7. Install crank bearings, crank, bearings and caps and confirm bearing clearance with plastigauge using old bolts
    8. File rings to ????? Pistons should come with specs for ring gap
    9. Install wrist pins (the machine shop said this clearance needs to be check and possibly adjusted, is this true?) I've never done it or had it suggested to me to have it done. I've built probably 10 engines over the years. Never had an issue.
    10. Install pistons with ring compressor Buy the right size ARP or Wiseco piston ring compressor sleeve. It is SOOOO much easier to work with than the regular ring compressors.
    11. install and torque rod bolts (possibly check with plasti-gauge at this time?) and confirm bearing clearance with plastigauge using old bolts
    12. New oil pump chain and crank sprocket and tack weld nut (I heard this is good to help oil pump prevent failures) I did safety wired oil pump nut. Less likelihood of altering the metallurgy of the oil pump shaft with the heat from welding.
    My suggestions in red!
  7. #132
    Geigertown, PA
    95 M blk/blk
    Someone on here said as long as your main bearings still had the tin coating you can reuse them. How do these look?
    96 328i ITR Racecar
    2002 325XiT - daily
  8. #133
    Vancouver, BC Ca
    1993 325is
    New bearings are sooo cheap. Why would you bother? Especially since it'll be boosted. You should keep all the protection you can muster/afford.
  9. #134
    Geigertown, PA
    95 M blk/blk
    Quote Originally Posted by jakermac View Post
    jakermac, thanks! I was only looking at the tapatalk app and couldnt understand what you meant by answer in red because the text was all in the same color and I didnt look closely enough. Thanks, I will add checking the crank to the list of stuff the machine shop needs to do.
    96 328i ITR Racecar
    2002 325XiT - daily
  10. #135
    Apr 2006
    Minnesota eh?
    86 325es
    run em
  11. #136
    Mar 2012
    Renton, Wa
    98 m3
    I’d replace them.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  12. #137
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    I'd replace the bearings - you're through the first coating in some areas so they've already seen significant scuffing and will spin that much easier since things get harder as you go down in a bearing.
    Plus they're really REALLY cheap compared to all the other stuff and labor you put into building an engine.
  13. #138
    Apr 2006
    Minnesota eh?
    86 325es
  14. #139
    Mar 2013
    Upstate NY
    M3
    Looking good man! Keep up the progress. I'm finishing mine up this spring. I'm working on cosmetics now, seems so strange. I'm not sure what this world is...
  15. #140
    Geigertown, PA
    95 M blk/blk
    Thanks! Im jealous that you I are doing cosmetics, such a far way off, lol!
    96 328i ITR Racecar
    2002 325XiT - daily
  16. #141
    Geigertown, PA
    95 M blk/blk
    Do i need to upgrade from a walbro 255 if i am shooting for 550-600rwp? I was using the 255 when i was at 500 and it seemed fine.
    Dropped the old rear subframe, welded in the reinforcements, and installed my good already rebuilt subframe/trailing arms from crashed car. The most satisfying part is just tossing the entire old rear end into the scrap dumpster
    96 328i ITR Racecar
    2002 325XiT - daily
  17. #142
    Vancouver, BC Ca
    1993 325is
    Zack from 22RPD.com (Vollosso on here) taught me this:
    Do the math on your injectors. If you're running 60lb injectors, that's roughly 600cc/min x 60 minutes x 6 injectors = roughly 215LPH.
  18. #143
    Toronto, Canada
    E36 Turbo
    255 will do about 550 hp running beefy wiring.... but really that's about it and you shouldn't trust it for much past 500.
    And calculations like that are ok, but you should always add in some loss of the fuel system (lines, filters, elbows/connections, etc) for pressure drop.
  19. #144
    Mar 2012
    Renton, Wa
    98 m3
    Yeah realistically on a bypass system you need ~30% overhead. It’s all basic math to get you in the ballpark.
    1989 535i - sold
  20. #145
    Apr 2006
    Minnesota eh?
    86 325es
    If you actually test a pump in a car they never flow anywhere near what they are supposed to. The voltage loss to the pump and pushing through lines and filters takes a pretty big cut on their real world flow.
  21. #146
    Mar 2013
    Upstate NY
    M3
    No voltage loss off direct wires to battery.
  22. #147
    Vancouver, B.C., Canada
    '97 M3
    You should make an effort to tie the cage into the rear subframe mounting points, especially the front two points. the reenforcement plated you welded in do very little for curing a very weak structural mounting point.
  23. #148
    Geigertown, PA
    95 M blk/blk
    Quote Originally Posted by chikinhed View Post
    Uggg, I know....maybe next time, Ill probably crash it before it tears anyway. But seriously I probably should.
    Chikinhed, it was you that was having the boost creep problems with the steed right? Did i remember you switched from a turbosmart 44mm external gate to a tial 45? Something about the tials just worked better than the turbosmart?
    Ok, so an aermotive 340 would be good for 600hp? same fit and form as the walbro so I can just drop it in? I was running a relay directly from the battery like some have mentioned, seemed to work well.
    96 328i ITR Racecar
    2002 325XiT - daily
  24. #149
    Nov 2013
    VA
    E36
    Currently running the 340lph and it should be plenty for your setup. I had to run an aftermarket fpr since stock 3/2 valve couldn't keep up.
  25. #150
    Nov 2016
    34.8855° N, 32.3348° E
    EuroE36M3, X6, E93, E46,
    Mad stuff
  1. E36 FS: 450rwhp Turbo E36 M3
    By southpaw in forum 3 series & Z Series
    Last Post: 10-04-2011, 02:28 PM
  2. More Boosts! Tim's turbo E36 M3 build and fab thread!
    By A4RingedONE8T in forum Forced Induction
    Last Post: 08-04-2011, 08:30 PM
  3. E36 FS: 1997 AVUS Turbo e36 M3 511whp AEM
    By Mike185 in forum 3 series & Z Series
    Last Post: 05-29-2011, 06:31 AM
  4. E36 Wtt 07 si for turbo e36 m3
    By aj906115 in forum 3 series & Z Series
    Last Post: 10-15-2010, 05:53 PM
  5. Replies: 162
    Last Post: 07-26-2009, 04:08 PM
