Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 178
Thread: Hillclimb Racecar turbo E36 M3 Build
  1. #101
    Geigertown, PA
    95 M blk/blk
    Quote Originally Posted by vaderTT76 View Post
    Just saw your car in the Hoonigans drivers wanted special at Mt. Washington.
    @13:16
    https://www.youtube.com/watch?v=2ftRUY1M-yw
    Hey thanks for pointing that out! Too bad i did such a lame launch on that one, lol.
    Speaking of launches i just got back from another local PA hillclimb and i am struggling on the launches. Most of the problem is my stock 200k mile diff. I want to throw in some fresh clutches at least but dont really feel like spending any more money on this pit this year.
    I have a used thayer three clutch kit laying around that i used for a year or so before upgrading to a four clutch kit. The only problem is that the car understeered badly with that kit because the preload was too high. I need to measure the dog ear plates again, but I believe they were all 2.0 mm. So maybe i can just buy one 1.65mm plate to lower the preload.
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  2. #102
    Apr 2013
    dfw Texas
    e36m3/4/5, e46330i
    I saw it and since I have been following this build, I had to post it!
    Good stuff regardless.
  3. #103
    Geigertown, PA
    95 M blk/blk
    When you guys snap axle stubs in the medium case diffs, can the broken stub be extracted from the diff while its in the car or does the whole diff need to come apart to get it out? Also, has anybody ever used Technica's launch control? I am going to try it out this weekend at the Duryea Hillclimb. If you are in southeast Pa come check out the hillclimb!
    96 328i ITR Racecar
    2002 325XiT - daily
  4. #104
    Apr 2006
    Manchvegas
    Boosted M3’s
    Quote Originally Posted by bimmerbumm193 View Post
    Yea I clean snapped a custom hardened chrome stub and pulled it out with a magnet.
    I've been told some need other methods of extraction depending on destruction of the stub.
    Can be done.
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
  5. #105
    Geigertown, PA
    95 M blk/blk
    Well the Duryea Hillclimb is in the books. Car ran awesome and I got 5th place out of 110 cars! I got the second fastest time across the finish line at 148MPH. The only person who beat my top speed was Kerry Hitt in a 800hp CTSV GT1 trans am car. Its hard to describe the feeling of going nearly 150 MPH on bumpy windy public road...and its perfectly legal! The other E36 that got 4th is a LS swapped car with a little less HP than me but a better driver.
    96 328i ITR Racecar
    2002 325XiT - daily
  6. #106
    Aug 2011
    philadelphia PA
    1993 325is
    Congrats! That's awesome
  7. #107
    Geigertown, PA
    95 M blk/blk
    Thanks!
    Here is one of the only videos i have found of my car. Most of the instagram love was going to my buddies ls e36, hopefully some more footage of my car will pop up eventually.
    https://youtu.be/wg5rE0cC5zc
    96 328i ITR Racecar
    2002 325XiT - daily
  8. #108
    Bellingham, WA
    e30
    Awesome. Congrats!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  9. #109
    Vancouver, B.C., Canada
    '97 M3
    Did you notice a difference when you put the rear wing on?
  10. #110
    Geigertown, PA
    95 M blk/blk
    Well after 9 years of hillclimbing I finally crashed. I committed a rookie mistake by going too fast on a track I wasnt familiar with and caught air on a crest, landed in the grass and slide into a jersey barrier. I crashed on the most visible part of the track in front of all my friends and family. I could hear our son crying as I got out of the wrecked car from 500 yards away, it was no fun. I always knew I would crash this car, but I was hoping for at least 1-2 complete seasons!
    I guess this thread will have a version 2.0 as I build another shell and swap over the good parts. I haven't spent much time carefully looking at the damage, but Im hoping the whole drive train is still good. I hit kind of like Earnhart did, sliding sideways while hitting the wall perpendicularly which sheared off the whole front clip, then spinning and smashing the rear also. The passenger compartment and cage appears nearly untouched with both doors working perfectly. The only visible damage to the motor is the tensioner bosses on the oil filter housing are broken. The motor mounts and trans mounts broke, except for my 15lb steel turbo mount, lol. The turbo and manifold appear ok at first glance. When I was deciding to go top mount or bottom mount one of my main concerns was how protected the turbo would be...well Im glad I had that concern now!
    I need you guys to convince me that my 220k mile stockish 1995 M3 is not worth keeping as a street car and that it will never be worth more than $5K so I should start hacking it up to turn into a racecar.
    To top off the misery I went from owning 2 racecars to 0 in one week. A few days before crashing, I sold my road racing car and it shipped out yesterday The important thing is I was fine in the wreck and I will rebuild, but gosh darnit I just dont feel like it right now so soon after that last build. I was really looking forward to cruising around on the street this fall...oh well.
    96 328i ITR Racecar
    2002 325XiT - daily
  11. #111
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Ouch... that sucks man, but glad you're ok.
    If you shut it off soon after impact, I'd say the engine is likely ok if the block doesn't have any cracks. Inspect the trans for stress cracks around the mounts as well.
    You're right on with the '95 M3 with really high miles never being worth anything. E36 prices really haven't gone up much above the $10k mark unless it is a REALLY nice one from what I've seen, so a higher mileage one - nah, not going to be worth anything, ever. It's probably worth more if you parted it out and swapped racecar stuff over to it, so if you're willing to put in the work, it won't really be a financial "hit" of removing value from it, you'll actually get more $$$ freed up from the part-out and still have the chassis to turn into a new racecar.
    I wouldn't let the wreck get you down, it happens when pushing it. That's one of the reasons I decided a long time ago to just keep doing DEs. Not that the thought of a wreck "scares" me or anything, I just knew racing in any form makes it that much more likely, and I didn't personally feel the urge to step down that path since there are some negatives vs. a more casual "arrive at the track in a street car, drive home" type deal. So if you do the racing thing, you've just got to accept it's much more likely you're going to have a smash sooner or later.
  12. #112
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Damn, dude.
    that sucks.
    but you're right. The important part is that you're ok.
    and I agree, the m3 should be v2.0
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  13. #113
    Apr 2013
    Alabama
    1995 M3 Coupe
    Oh man! Hate to see that. Glad to hear you got out and walked away.
    Yea, turn the 95 into the new hill climb car for sure. Good luck on the new build.
    1995 M3...Screwed
  14. #114
    '97 M3
    Nah, it'll buff out.
  15. #115
    Geigertown, PA
    95 M blk/blk
    Thanks for the encouragement about the 95 M3 as the new donor, it will get torn apart soon! What is involved in running OBD2 engine/harness/tune in a 95 car? Does the harness just plug in to the car and its ready to go?
    Since I have to rebuild almost everything I was thinking about my stock S52 bottom end. The power worked great for the hills but the car was a complete dog exiting slow super tight and steep second gear turns before I got into boost. I think this was due to the low compression setup with the spacer. I was getting full boost by 3500 but waiting for that to kick in feels like an eternity (actually only fractions of seconds but my competition with LS1s are kicking my ass in the corners). I think my options are either:
    a. keep everything the same and just learn to left foot brake so I can get on the gas earlier and build boost
    b. change from 3.23 to a 3.38 or 3.46 ratio. The power band is great now with the 3.23 so Im not sure how the turbo will like a 3.38 or 3.46?
    c. build a higher compression motor - I dont want to run E85 so is this even an option?
    d. go full standalone so I can run anit-lag (not really an option, too expensive)
    96 328i ITR Racecar
    2002 325XiT - daily
  16. #116
    Marietta, GA
    95 M3, 87 535is
    Oooh man Shenandoah's crest bites again. Gl with the rebuild, the drivetrain should be ok.
    From past experience, an oxy torch will be a big help getting the drivetrain out from the smushed chassis.
  17. #117
    Mar 2012
    Renton, Wa
    98 m3
    Here is a diagram to adapt obd2 engine harness to obd1 chassis harness.
    http://22rpd.com/img/obd2.pdf
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  18. #118
    Geigertown, PA
    95 M blk/blk
    Thank you for the diagram.
    Is it possible to slightly bend the rods and it still run ok? Im just wondering because the few runs before I crashed it the engine sounded a little different. It is hard to describe but it sounded "looser" and had more of an intakey "waaahhhhh" sound at WOT. It seemed to run fine though. It also had some lifter tick noise that it didnt have before, although I didnt change the oil since I built it.
    If you want to put rods and pistons in is the only option boring the block or can you just get stock bore pistons if your bores are ok? I saw 86.5mm Wiseco pistons, but isnt the stock bore 86.4mm? It seems that it would be the difference in spending the price to bore the block plus everything associated with stripping it, cleaning it and reassemble vs just possibly the $800 for the piston and $600 for the rods (plus new head gasket, decking head, new seals, ETC). So $2500 vs $4500?
    96 328i ITR Racecar
    2002 325XiT - daily
  19. #119
    '97 M3
    Back when I was supercharged I had a bent rod and didn't know it until the engine came apart to get built
  20. #120
    Mar 2012
    Renton, Wa
    98 m3
    I would bore it. After a casted part heat cycles it changes shape. The bores change shape. Take the block and get a bore/hone and the cylinders will be perfectly round and square.
    It's a small thing that makes a big difference and while it's apart it will cost next to nothing to get a bore and hone done. 250$ maybe.
    1989 535i - sold
  21. #121
    Geigertown, PA
    95 M blk/blk
    After a crapload of home improvement projects, Im ready to start version 2.0!
    Since last posting nearly 8 months ago, I have decided it doesn't make sense to gut, cage and hack up my 95 M3 because its more valuable as a high mileage M3 where all I need for a racecar is a rust free E36 shell. So after months of looking I found my ideal candidate, a 1998 323is with a blown motor. It was only 30 minutes from my house, one owner, nearly perfect body, and best of all it is Avus Blue which is the color I always wanted. And it was only $1200!!!
    I started ripping the wrecked car apart and Im thinking about dropping the whole engine/trans out the bottom with the subframe and struts attached. Any tricks to doing this? Do you put some junk tires under the engine to hold it from tipping as you lift the car up?
    96 328i ITR Racecar
    2002 325XiT - daily
  22. #122
    Norristown PA
    mostly bmw
    Just build a cart like this! I suppose tires could work as well. Or Jack stands?
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  23. #123
    Vancouver, BC Ca
    1993 325is
    If the engine is bolted to the subframe, it won't tip over.
  24. #124
    Nov 2013
    VA
    E36
    Quote Originally Posted by jakermac View Post
    ^this. Makes me wish I had a lift.
  25. #125
    Feb 2017
    west chester PA
    95 325is
    Great thread! I’m new to the forums but have been building a car to do similar events with. I’m fairly local too! Was wondering if you had some insight on manifold choices as I’m using an efr turbo myself.
  1. E36 FS: 450rwhp Turbo E36 M3
    By southpaw in forum 3 series & Z Series
    Last Post: 10-04-2011, 02:28 PM
  2. More Boosts! Tim's turbo E36 M3 build and fab thread!
    By A4RingedONE8T in forum Forced Induction
    Last Post: 08-04-2011, 08:30 PM
  3. E36 FS: 1997 AVUS Turbo e36 M3 511whp AEM
    By Mike185 in forum 3 series & Z Series
    Last Post: 05-29-2011, 06:31 AM
  4. E36 Wtt 07 si for turbo e36 m3
    By aj906115 in forum 3 series & Z Series
    Last Post: 10-15-2010, 05:53 PM
  5. Replies: 162
    Last Post: 07-26-2009, 04:08 PM
