Hi guys,
For my frankenstein engine (M50B25 block and rods with M52B28 crank) I'm looking for 86mm pistons with an CR of about (8.5 - 8.8) :1.
I contact VAC a few days ago, but doesn't receive an answer till now. (Maybe they can't deliver this bore diameter)
Maybe somebody have an idea where I can buy such pistons else?
Torsten
I know that TRM is offering 86.5mm 8,5:1 CR, but 86mm, huh... I presume that you will need to make a special order on pistons if you want to go 86mm route...
i've bought mine from importperformanceparts.net S50B30 std 86mm bore, but ratio is 10:1
thank guys... I'm going to buy these pistons from bavariansolutions.com
He offered me Ross pistons - I never heard that brand before, so I hope they will work well as CP Pistons.
pretty sure the m60, or an S52 has this diameter.. I wrote down the dimension so i know its a bmw oe part.. but ill have to look.
call these people. Not sure if you'll find the compression you want, 9 to 1 maybe
https://www.cnc-motorsports.com/ke12...mm-10-0-1.html
96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
I Have made a few designs for m52, easy enough for that bore diameter. Je and Diamond produce our piston designs. here: https://22rpd.com/shop/product/95
1989 535i - sold
1999 M3 Tiag/Dove - sold
