Just saw the back and forth with the M52 vs S52. I'm running a lowered compression stroker M52 (3.0L), OBD2, VAC turbo cams, and obviously a turbo. Is this PNPMS3 Pro the best for me or is there a setup that might be easier/better for my build?
Let's discuss what it takes to make an obd1 car, run the obd2 ecu. Seems like that's what will need to be done if you're obd1 and want something quick.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
you can still make your own PNP obd1 ecu for under 1000$ with megasquirt. Its really not that hard at all.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Sorry, that would be Gainesville, Georgia.
Got it! We are now up to 15 who are looking for an OBD2 unit.
Doubling the minimum won't increase the discount, but it will get this done faster.
Should work with the same changes that run an OBD1 car on a stock OBD2 ECU.
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
If you haven't already, put me down for an obd2 setup!
Sent from my SM-N920P using Tapatalk
You need the sensors too
Sent from my SM-G935V using Tapatalk
I think you can use a m42 crank sensor if you want to mount it in the OBDI location, my 2 current OBD2 swap doesn't seem to even have the coolant temp sensor in the head connected, you will need knock sensors and I'm pretty sure cam position sensor too. Also, the vanos solenoid wiring length is different so you may need the adapter piece to makeup the length difference
The M44 sensor is generally used in the OBD2 location to make an OBD2 engine compatible with an OBD1 DME. I don't think there's a solution to go the other way.
However, one of these might work:
http://www.boostaddict.com/showthrea...gnals-reliably
You need euro m52 crank sensor
1996 332IS
Built 3.2
Yea sorry. Just ignore my stupid previous comment. Wasn't thinking straigh
Sent from my SM-T707V using Tapatalk
Eff it, sign me up for OBD2...IF we can have it some time soon. I am seriously considering VEMS since I just moved to Virginia where there is no e85 and my car is stock compression =(
1996 332IS
Built 3.2
Seriously, I need this bad RN.
When will the gb be closing?
Matt Cramer
Whats the total up to now?
Has manufacturing started?
