Page 8 of 47 FirstFirst 12345678910111213141516171833 ... LastLast
Results 176 to 200 of 1164
Thread: Looking into making an MSPNP Pro for the M50 and M52 engines
  1. #176
    Jun 2012
    South fla
    97 332i, 90 535i
    Yeah I've been meaning to put together a build thread. Just need to gather all my pics and info. I'll be working on that soon. Here's a vid from a couple months back in Orlando FL (I'm in South fl) https://youtu.be/vAqB_2LwsXg
    Sent from my SM-N920P using Tapatalk
  2. #177
    Feb 2010
    Texas
    01 530i
    I have an S52 swap in my car (M52 originally). I have used both the original M52 DME and the S52 DME to run the motor with no codes and all sensors working. The wiring harness was not touched just the motor and the DME were swapped.
  3. #178
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    An obd2 m52 harness is the same as the s52 harness, and both DMEs can be used interchangeably aside from the specific tune for each. I know this for a fact, as I've got an s52 harness running my Ti with an m52 DME and an s52 tune.
  4. #179
    Phoenix,AZ
    99' 323is, 99' 328is
    How about m52 323is which only has 2 o2 sensors? Same pinout as m52 and s52?
  5. #180
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by JimsR View Post
    All 6-cyl (M52/S52) OBD2 cars seem to have the same pinouts yes
  6. #181
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    Quote Originally Posted by somebody5788 View Post
    May need to check the source. I believe the S52 and M52 are the same computer other then some coding. I think you can even reflash an M52 ECU to S52 software if you know what you're doing. M50/S50 vs M52/S52 are pinned differently though.
    OK, I took a closer look and found out where I went wrong. Someone at Alldata accidentally accidentally pasted the M44 wiring diagrams into the S52 section, and I hadn't paid close enough attention to realize that I was looking at a pinout with only four injector and four coil outputs. Thank you (and the others who chimed in) for setting the record straight there.
    The 323 M52 looks like it's the same too.
    Quote Originally Posted by Bke36Is View Post
    Put me down for an obd2 setup but I have a couple questions. My car is an automatic with a powerglide (manually shifted) so I don't any problem there but will I be able to use the solenoid and 4.9 lsu wideband sensor from my current boost controler/wideband setup and will a racepak dash work with the ms3pro?
    Yes, although the sensor will need an external controller like an Innovate LC-2.
    We support Racepak dashes no problem. The new IQ3S just needs to be wired to our CAN output; earlier versions need a CAN to V-net adapter.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
  7. #182
    Jun 2012
    South fla
    97 332i, 90 535i
    Quote Originally Posted by Matt Cramer View Post
    OK good info. I'm currently running an innovate scg-1 boost controler/wideband/ data logger. I don't mind keeping it if I need it.
  8. #183
    Aug 2015
    Boston
    1999 Bmw M3
    So bmw m3 s52 obd2 is a go?
  9. #184
    Jun 2012
    South fla
    97 332i, 90 535i
    I don't see why not!
  10. #185
    Sep 2009
    Lawrenceville, GA
    Quote Originally Posted by Mzfhartge View Post
    That's correct. If we can get both an M52 and an S52 test car, we can have a map for both.
    Matt Cramer
  11. #186
    Manchester, N.H.
    96 332IS 6466 turbo
    Focus on S52. Not many here will be playing with M52. Even tho, same difference.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  12. #187
    Sep 2008
    Toronto, ON
    6465 328ti
    Agreed. If any m52 users arise they can work with the s52 tune imo
  13. #188
    Ship, Pa
    Red Sled, RC51
    S50 instead!!!
    "Believe nothing you hear, half of what you read"
  14. #189
    Apr 2006
    Minnesota eh?
    86 325es
    I think you will be surprised how close the tunes will be between an S52 and an M52 with the usual S52 cams. Once you reset the displacement in the basic settings you will actually probably have to add a small amount of fuel to the VE map and that should be about it. That's just my prediction, could be wrong.
    And of course megasquirt is open, so you guys will be able to share timing and fuel maps, or even the whole tune file with each other.
  15. #190
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Ive got a few OBD2 cars running various FI setups down the street from you
    460whp/515wtq wifes MMW tuned 335i
  16. #191
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Yea, it's not hard at all to get a basemap on a standalone if you know some basics. I guessed at everything on my initial AEM Infinity startup and it was perfectly fine to drive around and go lightly into boost with no O2 feedback. With O2 feedback it would have been fine to start beating on it straight away (but I wouldn't do that, but it's possible).
    People need to realize on a standalone you can SEE everything the computer is doing. It's not a black box like a stock computer. If it's a little lean in an area - put more fuel in - solved. If it knocks a little, take some timing out - etc.
  17. #192
    Jun 2012
    South fla
    97 332i, 90 535i
    Where are you located?
  18. #193
    Aug 2012
    CT
    Twin turbo LS E36 M3
    almost all m52's will have s52 cams in it. I quick change to the displacemnt setting in megasquirt and the same map will be extremely close. Ive used my s52 cam m52 map on alot of s52 cars and its very very close.
    Your car will be a moster on MS. Timed launch control and all sorts of fun stuff for an auto.
    Keep your gauges. Just add the 5v out put from your wideband controller to the EGO pin of the megasquirt. Done deal.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  19. #194
    Sep 2009
    Lawrenceville, GA
    Suwanee, Georgia. By the time the group buy starts, we'll probably have moved to a new building in Gainesville (another reason we couldn't get started immediately).
    Matt Cramer
  20. #195
    Jun 2012
    South fla
    97 332i, 90 535i
    If you're moving to gainesville fl I'd be willing to bring my car for a test mule. Just need to know when and where. My car has an s52 in it
  21. #196
    Aug 2015
    Boston
    1999 Bmw M3
    Put me down please for s52 obd2, thanks.
  22. #197
    Manchester, N.H.
    96 332IS 6466 turbo
    Your going to tune the hell out of it ?
    1996 332IS
    Built 3.2
  23. #198
    Aug 2015
    Boston
    1999 Bmw M3
    E85 too, waiting on you
  24. #199
    Manchester, N.H.
    96 332IS 6466 turbo
    We are at like 15 obd2's , do we get deeper discounts if we double the minimum ?
    1996 332IS
    Built 3.2
  25. #200
    Jun 2012
    South fla
    97 332i, 90 535i
    ^This!
  1. Replies: 32
    Last Post: 11-11-2012, 08:19 AM
  2. HELP please..Are the sumps the same on a E36 M50 and M52 engine??
    By E36kjc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2010, 04:47 AM
  3. Looking into buying an e36 in the future
    By Shadow86325e in forum 1991 - 1999 (E36)
    Last Post: 10-10-2007, 10:07 AM
  4. Replies: 1
    Last Post: 07-22-2007, 01:36 PM
