Page 7 of 47 FirstFirst 123456789101112131415161732 ... LastLast
Results 151 to 175 of 1164
Thread: Looking into making an MSPNP Pro for the M50 and M52 engines
  1. #151
    Ship, Pa
    Red Sled, RC51
    Sent
    "Believe nothing you hear, half of what you read"
  2. #152
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    OK, I spoke with the boss and our engineering team on this one, and here's what we came up with. There's currently a number of high priority projects that the boss did not want put on hold, and we are in the process of getting ready to move to a different building as well. So we've penciled this one in for fourth quarter this year, barring any unexpected disasters. My BMW will likely be sold by then (and I couldn't persuade the boss to buy it from me), so we'll need to line up a test car - we've got a local racer we are reaching out to, but it may help to have a back up test car available. We'll open up the deposits when we are ready to start actually laying out the board. There is going to be a bit of work going on in the meantime, as we will be testing out an OBD2 cam sensor to see what it will take to support them or if we're better off packaging these with an OBD1 cam sensor conversion. The good news is that the cam sensor looks like it is going to be the only real potential hurdle. Our goal is to determine exactly what we'll do for the cam sensor and other question marks before we take deposits.
    One other thing - it looks unlikely we will be able to support automatic transmissions, at least on the first release. I figure that won't bother most people here, but if that's a deal breaker, let me know.
    That Q4 estimate is with 11 people on the group buy. I've already been impressed with how quickly people have been signing up for this one; he said that if we can get 20 or 25 people signed up and we see the market is even bigger than we expected, that'll give this a massive bump in priority.
    Quote Originally Posted by Fender13Bender View Post
    Will you be doing OBD1 as well even though there aren't 10 in the group?
    Possibly - if the OBD1 doesn't manage to get 10 sign-ups, we might get it launched anyway if the OBD2 version sells well. We'll have to see.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
  3. #153
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    All I'm hearing is more hype = more sooner. haha
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  4. #154
    Sep 2009
    Lawrenceville, GA
    Quote Originally Posted by somebody5788 View Post
    Yep. Or more money = more sooner. We're now at 5 OBD1 sign ups and 11 OBD2 sign ups, so right now it looks like we'll get to work on the OBD2 unit once a couple other projects are complete, and then once they're out, we'll see if their sales justify launching an OBD1 model without a group buy.
    Matt Cramer
  5. #155
    Aug 2012
    CT
    Twin turbo LS E36 M3
    If you guys end up needing to switch over to the obd1 cam sensor for the obd2 unit, then the only other thing that changes is the actual pin locations
    might make releasing both make more sense if you make that a requirement.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  6. #156
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Glad to see you guys putting all of this together Matt!
    Fwiw, we just did all of the open loop boost control yesterday on my ms3x e36 using the diy solenoid and it was very easy to setup and get boost dialed in. We hold 18psi steady through 3rd and 4th, over boost setup at 19.5 psi. So anyone curious about setting up basic boost control..it is very simple.
    ..now we get to setup launch control, traction control, anti-lag, and ethanol control!
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
  7. #157
    Phoenix,AZ
    99' 323is, 99' 328is
    Best if the obd2 guys would not need to mess with the cam sensor at all. Not because its difficult to make the modification but switching back to oem ecu without any changes is important to me.
    She's built like a steakhouse but handles like a bistro
  8. #158
    South Carolina
    2004 330 vert 2004 X5
    I bought this one years ago. https://www.amazon.com/Engine-Manage.../dp/1932494421 It has some good info in it but honestly you would be better off just reading the tuning manuals in the megasquirt documentation. http://www.msextra.com/doc/pdf/html/...ual_1.4.1.html I promise you know more about tuning than you think you do. Once all the basic configuration is set up the only thing you really need to tune to make the car run is; The VE table, Acceleration enrichments, (takes a few minutes of street tuning) timing table (just steal one from someone else till you can go to the dyno) cranking pulse widths (just play with them till the car starts reliably at different temps) idle valve settings (defaults will probably work fine) warmup enrichment (defaults will probably work fine) Once you are satisfied with how everything is working you can start to add the extra stuff like boost control, flex fuel ect...
    I have that Greg Banish book. It answered a lot of questions for me. Money well spent in my case.
  9. #159
    South Carolina
    Matt couple questions
    Are all the inputs analog or digital or both? What is the process and basic time frame once you start things on your end?
  10. #160
    Sep 2009
    Lawrenceville, GA
    Quote Originally Posted by flyfishvt View Post
    There are three extra analog inputs. We'll use one for an onboard barometric pressure sensor, which is going to be hardwired in, and one for the MAF - you can remove the MAF and wire other analog inputs to that channel.
    The remaining extra inputs are on/off (digital).
    If you run out of analog inputs, you can bring in more analog data over CAN.
    We'll rig up a prototype device that's basically an MS3-Pro Module wired to a DIYBOB and check it on the car to make sure all inputs and outputs work as expected. Once that checks out, we use the wiring from that to lay out a circuit board and order the circuit boards. Then we assemble a prototype using that circuit board, put it through additional checks, and dyno tune the test car to create a base map. If no problems show up on the test car, we build out enough MSPNPs to fill the group buy plus some additional units, and put them up on the website for sale.
    We expect it to take about 3 months from the start of the process to the ECUs being ready to ship.
    Matt Cramer
  11. #161
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    I've been following and reading this thread and I would like to be put on the OBD2 list please.
    THE TIME DRAWS NEAR!
  12. #162
    Mar 2013
    THE DIRTY THIRD
    '95 M3
    Damnit! Where are all the OBD1 guys at?!
    Turbo E36 M3 with all the things..
  13. #163
    Mar 2010
    Long Island
    E36
    Quote Originally Posted by SyCK View Post
    Seriously. It seems like this project is heading for pipe dreams
  14. #164
    Jun 2013
    A Beach in Fl, US
    Z3 Turbo Ferrari 328gts
    Please put me on the OBD2 list.
    2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro​ Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
  15. #165
    Sep 2009
    Lawrenceville, GA
    OK, we are now at 5 OBD1 and 13 OBD2 sign ups. I'm a bit surprised we don't have more OBD1 sign ups myself. But we don't really have a time limit on sign ups, and if an MSPNP for one set of years for a particular model sells well, we often find it will do a lot to shake loose demand for the rest of the year range.
    Matt Cramer
  16. #166
    Joliet, IL
    Out of Service
    I'm not too surprised by the OBD2 demand. There was a big kick for a while for OBDI folks to upgrade to OBDII for better stock ECU tuning. I will have a 95 M3, which is stock OBDI, but it's converted to OBDII
    Sent from my SM-T707V using Tapatalk
  17. #167
    Sep 2009
    Lawrenceville, GA
    I've had people asking, "What about the S50 and S52?" Here's what I have been able to find on the M3 wiring.
    S50s will be easy. They seem to have used the same ECU pinout as the other M50 VANOS motors, with only a change to the tune file. So if you have an S50, you can sign up for the OBD1 group buy no problem.
    S52s are a bit more complicated. They're similar to the OBD1 M50 ECU, but not quite identical - they seem to have more in common with a couple other ECUs, including the ones used on the M44, M62, 1996-1998 Porsche 911 non turbo, and 1997-1999 Porsche Boxster. So if you want a plug and play for anything in that family, let me know. (Note - see subsequent posts. I was on the wrong info.)
    Matt Cramer
  18. #168
    Apr 2008
    Bay Area, California
    01M5, 99M3 Supercharged
    I didn't realize that S52s would be a potential issue. Are the M3 motors being factored into the development? Would really like this to work on my 99 M3.
  19. #169
    Aug 2012
    CT
    Quote Originally Posted by Matt Cramer View Post
    Maybe you know this, or know something i dont but
    m50/s50 are OBD1 and share the same ECU pinout
    m52/s52 are OBD2 and share the same pin out
  20. #170
    Sep 2009
    Lawrenceville, GA
    I've confirmed that the OBD2 M52 ECU has a completely different internal pinout from the OBD2 S52 unit. Let me know if I need to change anyone's sign up category. (note - see subsequent posts; looks like this was a mistake.)
    An S50 or S52 motor running M52 electronics should not have any problem with the OBD2 MSPNP. We can put together an alternate startup map for this by rescaling it for the different injector and engine size easily enough.[
    Matt Cramer
  21. #171
    Manchester, N.H.
    96 332IS 6466 turbo
    M52 aka 328i and 328is is 100% the same pin out as the S52 in the M3 from 96-99. I'm not sure where that info you got came from. But they are the same.
    OBD2 M52/S52 are the same.
    I will be highly surprised if I'm wrong.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  22. #172
    Aug 2012
    CT
    yea im a little confused my self.
  23. #173
    Nov 2008
    Indiana
    May need to check the source. I believe the S52 and M52 are the same computer other then some coding. I think you can even reflash an M52 ECU to S52 software if you know what you're doing. M50/S50 vs M52/S52 are pinned differently though.
  24. #174
    Jun 2012
    South fla
    97 332i, 90 535i
    Put me down for an obd2 setup but I have a couple questions. My car is an automatic with a powerglide (manually shifted) so I don't any problem there but will I be able to use the solenoid and 4.9 lsu wideband sensor from my current boost controler/wideband setup and will a racepak dash work with the ms3pro?
    Sent from my SM-N920P using Tapatalk
  25. #175
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Bke36Is View Post
    Whoa, a glide!! Sorry for the off-topic, but please make a thread about this if you haven't! If you have, where is it?
  1. Replies: 32
    Last Post: 11-11-2012, 08:19 AM
  2. HELP please..Are the sumps the same on a E36 M50 and M52 engine??
    By E36kjc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2010, 04:47 AM
  3. Looking into buying an e36 in the future
    By Shadow86325e in forum 1991 - 1999 (E36)
    Last Post: 10-10-2007, 10:07 AM
  4. Replies: 1
    Last Post: 07-22-2007, 01:36 PM
