Interested in OBD2, but I have no clue how to tune...
I would be interested in flex fuel sensor, wideband, and boost control capabilities. Not sure what that would cost extra.
Also, and excuse the fact I know zero about MS, but what kind of Temps and pressures can be logged (like fuel press, oil press, oil temp, coolant temps, IAT, boost, etc) and what's the limit of sensors that can be logged
Sent from my SM-G935V using Tapatalk
Matt said they would have an extra connector on the unit for extra inputs/outputs so all you will need to do is wire them to that extra connector and turn them on in the software. Megasquirt will work with any boost solenoid and all the flex fuel sensors, and of course any wideband. The GM flex fuel sensors are about $100 and just require power ground and signal. A generic boost solenoid is only $30. With both installed you can vary the amount of boost you run based on ethanol percentage.
MS logs every sensor input and also all of its internal calculated data such as injector pulse width ignition timing, 02 correction, acceleration enrichment, literally everything at the same time. If you want to also monitor an additional sensor to log you will just need to wire that sensor to one of the extra analog inputs and then turn it on in the software so it knows what it is. You can then use that sensor input to activate another feature. For example you could log oil pressure and turn on a warning light at >1500 rpm and <15 psi oil pressure.
Screw it, put me down for an OBD1.
Turbo E36 M3 with all the things..
I read all the posts after my post. Earlier he said additional sensors may be limited and a microsquirt may be needed. I have a GM sensor already and thanks for the heads up on the solenoid. I was hoping any MAC solenoid would do the trick for boost control. Just curious if I needed to add the micro to get flex fuel, wideband and boost control capabilities or if it was just more for temp/press sensor add on.
I think I'll be in for one of these. When does he need deposit?
I expanded my response above to include your data logging question. You would only need to add the micro squirt module if you run out of inputs/outputs. Matt said they would have 3 extra analog inputs and at least a few on/off inputs left open. One analog was going to be for MAF and one for atmospheric correction, but you should be able to use those for something else if you don't want to use those. So that would give you the ability to log 3 extra pressure or temp sensors. The flex fuel sensors are frequency so that would use 1 on/off input. You could use the other on/off inputs for boost table switching, launch control, water meth activation, ect...
For boosty reasons I would just do speed density.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Can you run MAF in vacuum and as soon as in boost MAP takes over ? Or run both in case one goes bad, the ECU will use higher value ?
1996 332IS
Built 3.2
Honestly I don't know why you would want to make it complicated. Map sensors are very reliable and the car runs perfectly well without the maf.
I really, really don't see the obsession of MAF sensors. They're so touchy, especially when used int he blow through config.
Yes. We currently don't have the sensor itself, but you can add it. The MS3-Pro flex fuel can blend just about all the fuel and ignition settings except injector dead time for a smooth transition between separate gasoline and E85 tunes.
No. But you could swap to the MSPNP Pro at the track and take it out for street driving.
I can't promise we'll be able to pull this off, but we will look into whether we can get data off the existing data bus.
Not much - you're looking at $189 for our entry level wideband, $53 for our boost control solenoid, and under $100 for a flex fuel sensor. And yes, if you've already got a Mac solenoid, it will do fine for boost control.
IAT, coolant temperature, and MAP sensor (boost) readings are standard, and there's two extra analog channels (the MS3-Pro has three analog channels, but the MSPNP will use one for barometric pressure) that would let you read fuel pressure, oil pressure, o oil temperature. You can add a MicroSquirt IO Box or CAN-EGT module if you need more channels. The limitations generally depend more on the sensor wired to the MS3-Pro than the ECU itself.Also, and excuse the fact I know zero about MS, but what kind of Temps and pressures can be logged (like fuel press, oil press, oil temp, coolant temps, IAT, boost, etc) and what's the limit of sensors that can be logged
Any MAF that can handle your air flow levels, as long as you can get its calibration data. Hot wire types are preferred to flapper or Karmann vortex designs as they're less restrictive. Or if you think there's no MAF like no MAF, you can go speed density and ditch the MAF altogether.
This is called table blending and is supported, but is rather complicated. I wouldn't start off this way.
Currently we don't support that, but if using just the MAP sensor, the ECU can be set up to detect MAP sensor failure and switch to using a synthesized MAP reading based on RPM and TPS. You will need to do a bit of data logging to figure out what that table should look like.Or run both in case one goes bad, the ECU will use higher value ?
OK, we have nine people signed up for OBD2. We need one more to start taking deposits, though I'd prefer to wait until we have at least 12 sign-ups to leave room if some people back out.
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
How does this compare to PNP VEMS?
The VEMS is cheaper and available now.
http://www.bimmerforums.com/forum/sh....php?t=2274298
