Very hard to measure accurately. It's definitely the least clearance dead center. I came up with 28.5mm by centering a large diameter bolt in the hole and then measuring which thread was flush. My sensor flange to end depth is 27.64mm so it seems correct to me. It sounds like spec clearance is around 1mm. You can't really fit a digital caliper in there at the right angle without pulling the oil filter housing.
96 M3, 09 335i
Thank you, I'll pass this on. We're testing the sensor with a trigger wheel chucked in a lathe.
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
sorry to butt in
is the problem trying to use the obd2 sensors? does that mean ppl have to convert to obd1 to use megsquirt?
Matt Cramer
Have you guys dealt with the crank sensor yet? I have a fidanza flywheel so I could stick a scope on that sensor to make sure it behaves the way a stock one does. I'm thinking the easiest way is to crack the dme open and hook onto the pins that go to the pcb. This of course would require me to figure out my USB scope that I haven't touched in 10 years.
96 M3, 09 335i
We patiently waiting 4yrs 1mth 2dys now.
and we still excited. No we don’t want VEMS, RKTUNES, TRM, 22RPD or any other stand alone....... We want MEGASQUIRT! We love MEGAQUIRTERS!!!!
Please get this done so we can PlugnPlay and get MegaSquirted!
Thanks Matt Kramer, we appreciate the time and effort and we still patiently waiting on OBD2 MegaSquirt while OBD1 MegaSquirting all over the highways.
THE TIME DRAWS NEAR!
does this mean nobody has gotten the ob2 sensors to work with MS?
or is this just a super low priority for them?
Capital Driving Club Car # 102
How to turbo your car:
Step one. Install ecu and learn to tune and or have it tuned.
Step two. Install injectors and retune.
Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
Step four. Retune car
Step five enjoy
I hadn't posted an update because right now the cam circuit prototype looks like this.
Oops, wrong photo.
Still needs a few component values fine-tuned, but it's getting there. I had been waiting until we had either a call for beta testers or a picture of a complete prototype to post up as I figured this might not be the most interesting picture on its own.
Matt Cramer
haha.
same here. i have a 10 year old ms2 adapted to an e30 harness.
don't even want to have time to fk with it to work on obd2. :P
Matt Cramer
I heard or read something about a front burner getting turned on and us getting slid over to said burner...
Yes, it's in active development and one of our top priorities now. Right now everything is still a bit behind the scenes and not exactly camera ready (see above picture) but I will let you guys know when there's anything useful to report, such as we're opening the group buy or need a test car. We've worked out a good way to check a cam sensor in a lathe right now.
Matt Cramer
Q4 2020 updates?
A lot of the circuits we've tried proved too finicky. We ended up buying a junkyard ECU and putting it on an oscilloscope, and found that much of the service information we have about the cam sensor was incorrect - it operated at a lower frequency than what Alddata's copies of BMW's information gave us. We've been using what we've learned on the junkyard ECU to improve our circuit design.
Sorry, no actionable items for you guys yet, just a behind the scenes update. It's not forgotten.
Matt Cramer
For everyone waiting, might as well move across to speeduino:
https://github.com/pazi88/Speeduino-...ster/m52%20PnP
