Page 32 of 47 FirstFirst ... 7222324252627282930313233343536373839404142 ... LastLast
Results 776 to 800 of 1164
Thread: Looking into making an MSPNP Pro for the M50 and M52 engines
  1. #776
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by darbyfam View Post
    I wonder who that could be??? .
    Wasn't that supposed to happen today, or is it NEXT Thursday?
  2. #777
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Quote Originally Posted by joseprietopr View Post
    Whats the best bag for buck, logger/display for the megasquirt?
    Theyve come a long way with the internal logging with the MS3. The interface is easy.
    Interested to see whats suggested for displays though
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  3. #778
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    This will have 8 GB of internal data logging. For external display options, check out this link.
    https://www.diyautotune.com/support/...displays-data/
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
  4. #779
    Manchester, N.H.
    96 332IS 6466 turbo
    I can see me going broke with all these add on options. I really don't want to put more money into this pos
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #780
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    Ha! Your car definitely ain't no POS!
    THE TIME DRAWS NEAR!
  6. #781
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by spenka View Post
    You must be popping acid tabs or smoking that spice stuff.
    1996 332IS
    Built 3.2
  7. #782
    Jul 2011
    Dell Rapids, SD
    Smoking obviously, I'm Jamaican! Ha. I'm going to text you some questions. I'm trying to put my car back together today.
  8. #783
    Apr 2014
    Slidell, LA
    Many
    Quote Originally Posted by jakermac View Post
    Next Thursday
  9. #784
    Apr 2017
    Denver, CO
    E82 & S52 E30
    Butters are you running that twin scroll ces manifold? Piecing together my turbo goodies in anticipation for this and I think you just cost me even more monies.
  10. #785
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Duchess View Post
    Yes
    1996 332IS
    Built 3.2
  11. #786
    Apr 2017
    Denver, CO
    E82 & S52 E30
    Yes
    What kind of numbers are you running hp/tq wise, and when are you getting boost? I'm working on my s52 e30 and will probably never try for over 500whp due to traction limitations.
  12. #787
    Manchester, N.H.
    96 332IS 6466 turbo
    700+whp 625-650tq is my educated guess. Considering the car traps 137-138 in the 1/4 and weighs 3650. Could be more,
    1996 332IS
    Built 3.2
  13. #788
    Apr 2017
    Denver, CO
    E82 & S52 E30
    What rpm are you seeing boost?
  14. #789
    Manchester, N.H.
    96 332IS 6466 turbo
    20#;by 3400 in 4th gear.
    1996 332IS
    Built 3.2
  15. #790
    bonita springs fl
    oloa 318ti
    I am assuming no news is good news.
    one lap of america s52/gt35r 318ti..500whp 533wtq 19psi via rk-tunes....
    follow me on instagram @whitecord1
  16. #791
    Vancouver, BC Ca
    1993 325is
    He hit 304whp and 257ft/lbs torque corrected on a Mustang dyno (288/244 uncorr). And then there was much rejoicing!
    https://www.facebook.com/19937879725...1855972676268/
  17. #792
    bonita springs fl
    oloa 318ti
    that sounds sick. makes me want to go na
  18. #793
    Sep 2009
    Lawrenceville, GA
    And that one's running a circuit board from the production batch, too. It's getting close to release.
    Matt Cramer
  19. #794
    Jul 2017
    Puerto Rico
    318ti Swap/boost
    I wish it worked with my S50B30 Euro, love my engine setup but hate the tunning platforms, main reason i am finishing my M52 stroket to 3.0 low compresion to get boosted
  20. #795
    Apr 2014
    Slidell, LA
    Many
    It was my car that received the first production version of the MS3Pro PNP for the OBD1 E36. I cannot thank DIYAUTOTUNE enough for their professionalism and thoroughness. Phil was the installer and tuner. He took his time and was very thorough with the install. During the install we found that my VANOS and water temp sensor were plugged in backwards. He went over every input from the ECU and verified things were working correctly.
    We then went to the dyno and got to tuning. Phil worked every cell of every map and pulled everything he could safely pull out the car. He was able to get 20HP and 20TQ from the start of tuning until the end. He had the car on the dyno for about 4 hours total.
    I then took the car to both Atlanta Motorsports Park and Barber Motorsports Park for shakedowns. The car ran great and pulled hard everywhere. Unfortunately, I had an incident at Barber in T4 and put her in the wall hard and ended my weekend early.
    If you are looking at this ECU, I can't recommend it highly enough. I already had a very stout setup but this really took it over the top.
  21. #796
    Toronto, Canada
    E36 Turbo
    VEMS makes a PnP for your car/motor
  22. #797
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I may have acquired funds for this... Anyone want an MS3X and 2 wiring harnesses...
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  23. #798
    Sep 2002
    USA
    BMWs
    I kind of want one a MS again...
  24. #799
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Quote Originally Posted by somebody5788 View Post
    Already soldered up?
  25. #800
    Templeton, Ma
    1988 325ic
    Any update on when these will ship? If we are just waiting on mounting brackets, ill take mine without them. Mine is going in an e30 (s52 obd1 turbo) anyway...so not sure they would even work for me anyway.
  1. Replies: 32
    Last Post: 11-11-2012, 08:19 AM
  2. HELP please..Are the sumps the same on a E36 M50 and M52 engine??
    By E36kjc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2010, 04:47 AM
  3. Looking into buying an e36 in the future
    By Shadow86325e in forum 1991 - 1999 (E36)
    Last Post: 10-10-2007, 10:07 AM
  4. Replies: 1
    Last Post: 07-22-2007, 01:36 PM
