Page 3 of 40 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 990
Thread: Looking into making an MSPNP Pro for the M50 and M52 engines
  1. #51
    Oct 2012
    ottawa
    97 328is 02 e46 330xi
    When will a final price be set? Hopefully this doesn't take all summer to get enough people together.
    Quote Originally Posted by hakentt View Post
    People want cheap and easy.
    Sounds like an add in the paper advertising your mom's rub and tug
  2. #52
    Sep 2009
    Lawrenceville, GA
    328i vert and Dodge Dart
    Quote Originally Posted by Brycer View Post
    Planned on putting ms3x on my obd2 m52 using your BOB anyway but if a pnp comes up id probably do that instead. However I'm a dealer so i wonder if i can still be on the list.
    Sent from my SM-G930P using Tapatalk
    Sure, dealers can get in on the group buy too. I'm adding you to the list now.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
  3. #53
    NY/FL
    '99 Acura CL, '98 M3/4/5
    Sounds interesting, but last time I signed up for a group buy caused me much sorrow. I'd like to see a finished product first.
    Acura 2.3 CL BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
  4. #54
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by autowa View Post
    LOL!
    Sent from my GTX3582R
  5. #55
    '97 M3
    Quote Originally Posted by 5mall5nail5 View Post
    I'd pick one up except nothing on my car is stock enough to make use of it. Though, I could put it on my daily... hrm. Has me thinking. I do miss MS.
    Did you have good luck with MS? How does it compare to the DTA?
  6. #56
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Da Infammus 1 View Post
    There is absolutely no cause for doubt with DIYAutotune/Matt Cramer. They are completely squared away and trustworthy, sign up with confidence.
  7. #57
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by tptrsn View Post
    I think he means having to wait 18 years for a manifold lol...
  8. #58
    DeWitt, Michigan
    Well, I didn't know exactly what he was talking about, but I figured it was something like that. Haha
    I just wanted to throw out a vote of confidence for DIYAUTOTUNE and for Matt personally. If they are going to do a project like this, you can count on straight shooting from them. And for what it's worth, Matt is one of the guys who consistently pipes up on the megasquirt forums to give people assistance with their projects. Good dude!
  9. #59
    Aug 2012
    CT
    Twin turbo LS E36 M3
    I can agree with that. DIYAUTOTUNE is as legit as it gets.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  10. #60
    Feb 2012
    1995 BMW M3
    I'd be interested if I knew anything about tuning. Sadly I know zero ...
  11. #61
    Aug 2012
    CT
    Quote Originally Posted by rajicase View Post
    learn. its worth it. and its not that hard
  12. #62
    Jun 2006
    lombard,il
    93 325is
    How difficult would it be to go from a m50 to m52?
    The delimma is my 95 m3 s50 is boosted so I would need the obd1.
    But I just recently picked up a 99 M coupe s52 and if I like it more then ill boost that instead and get rid of the m3.
  13. #63
    DeWitt, Michigan
    rajicase,
    While you are learning about tuning, TunerStudio (the fantastic software you use to tune megasquirt setups) actually has a really great autotune feature that can get your VE table setup pretty darn well. All you need is a wideband in the system, and then setup your table of AFR targets, and go drive around. Eventually you will probably want to make a few fine tweaks, but with the kickass logging and log viewing capability in MegaLogViewer (MLV), that is really easy too. MLV can actually analyze your log compared to your AFR targets table and make changes to your VE table based on that, also. It's very powerful stuff.
    Dialing in your spark table is a little bit more difficult, but you can always just stay a little bit over to the safe side. Usually you won't even give up too much power until you can get to the dyno or track to really dial it in.
  14. #64
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by dburt86 View Post
    +1, I have bought many many MS V3.0 kits and parts from DIY and they have always been good to deal with. They have been selling these PNP setups for a long time and they know what they are doing.
    Thats the easy part. Honestly its no big deal at all. Like playing a video game.
    Quote Originally Posted by abq View Post
    One or the other will need to be converted. Your S50 will be missing the hole in the side of the block for the OBD2 crank sensor. The S52 in the M coupe can easily be converted to obd1, but I don't know how easy it is to get an obd1 harness into an M coupe.
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  15. #65
    Sep 2009
    Lawrenceville, GA
    To answer one concern raised - our M20 MSPNP managed to catch on pretty quickly. There's a lot of good potential targets for future MSPNPs, though, and not quite enough time to make all the MSPNPs we want to try, so we came up with the group buy process to let enthusiasts put an MSPNP for their cars on the front burner. We've also used it to launch MSPNPs where we were unsure if there was a market, but I'm pretty sure an E36 MSPNP will sell better than the one we make for the Ford Probe (which was the first MSPNP launched with a group buy).
    I understand, as not all our group buys have managed to get enough people signed up and one did run into a technical snag that has kept it from launching (that would be the one for the ZR1 Corvette). We'll wait to collect money until we have enough people interested to get the ball rolling. But if you don't sign up, once the group buy is over, they'll become a regular production item and you'll be able to pick them up at normal pricing.
    The circuit boards and pinouts will be completely different - although as it is there's a fair amount of OBD2 to OBD1 wiring swaps going on to use other tuning solutions.
    Matt Cramer
  16. #66
    Manchester, N.H.
    96 332IS 6466 turbo
    Can't wait, blow the pos up, press reset, and your all good.
    Wait, video games now a days you can't die. I hope its like Assassins Creed.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  17. #67
    Jun 2013
    Sydney
    1992 E36 320i
    Yeah I'm keen for this. Is this a full standalone ECU, or some type of piggyback system? (sorry, i haven't really spent much time looking in mega squirts at all)
    Also what kind of price are we looking at here?
    Problem is I'm in aus, not the states, but I'm sure we could work something out.
  18. #68
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by Kurtisja View Post
    This is as stand-alone as they come!!!
  19. #69
    Sep 2008
    Toronto, ON
    6465 328ti
    Just to echo with others have said diyautotune is as good as it gets for customer support. I've been dealing with them since I bought my first kit in 2008 and service has always been A1. Even when I emailed Matt back and forth regarding building a pnp ms3-pro in 2013 he ALWAYS got back to me the same day, every time! For a man who is on almost every car/ms forum I can think of I give him mad props for answering emails, helping on forums & running diyautotune.
  20. #70
    Aug 2012
    CT
    ive emailed Matt no less then 100 times per year.
    for the last 3 years
    and he always responds
    No body should have to talk to me that much.
  21. #71
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I bought an $80 soldering iron and built the entire kit from scratch with 0 experience on standalones. Granted it hasn't started yet but that's part of my learning experience and is still a hardware issue in the configuration of the M52 Hall Effect/ Gear Tooth crank sensor (something that a PNP kit would not have!) Dburt gave me a starting point for a base map and I used the VE calculator to get a starting point for a base VE table. The Autotune will hopefully get the rest of the fuel trims right for me. If I can do all that, you can figure out how to use a PNP kit lol.
    Also anyone that does go for this should install a double din Android head unit like I did and MSDroid / Shadow Dash. Technically don't need any gauges in the car with that and you can tune from the dash! I can share what modifications I had to do to the unit if anyone in here needs help.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  22. #72
    Ship, Pa
    Red Sled, RC51
    I may get in on this.
    What do you do for boost control? Have to buy solenoids or can I have megasquirt control the AMS500?
    "Believe nothing you hear, half of what you read"
  23. #73
    Nov 2008
    Indiana
    Quote Originally Posted by Fender13Bender View Post
    The solenoids it uses look identical to the one they sell for the megasquirt so I'd delete the controller and let the ECM do it. It allows you to use the fail safes a lot easier.
  24. #74
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by somebody5788 View Post
    Yup.
  25. #75
    Ship, Pa
    Red Sled, RC51
    What injectors are required? Can I re use my 100 lb injectors provided from my Miller performance tuning package?
  1. Replies: 32
    Last Post: 11-11-2012, 09:19 AM
  2. HELP please..Are the sumps the same on a E36 M50 and M52 engine??
    By E36kjc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2010, 05:47 AM
  3. Looking into buying an e36 in the future
    By Shadow86325e in forum 1991 - 1999 (E36)
    Last Post: 10-10-2007, 11:07 AM
  4. Replies: 1
    Last Post: 07-22-2007, 02:36 PM
  5. Replies: 1
