Page 2 of 47 FirstFirst 12345678910111227 ... LastLast
Results 26 to 50 of 1164
Thread: Looking into making an MSPNP Pro for the M50 and M52 engines
  1. #26
    Sep 2008
    Toronto, ON
    6465 328ti
    They should. As this will be PnP. I think I want to add a second IAT sensor and blend them if I can.
    You're right, they should have them if you go with OBD2...
    What is your reasoning behind blending? There are extra inputs for a 2nd IAT for sure.
  2. #27
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by e30kid89 View Post
    Don't know. I've spoken with this dude that tunes lots of high end cars. Ferrari's and such. He mentioned this practice to me briefly. This was way way in the beginning of me thinking I want to try to play with a standalone. So, I could be completely off. He travels and tunes for a bunch of race teams.
    I'll have to speak to him again when he shows up at my shop.
    I've seen his work, quite impressive. These cars he is playing with are worth 5-10x my house is. Anyway, he has a house in NH and I take care of his inspections for him. Basically lick and stick. High end Mercedes and brand new dulley. His wifes got some crazy caddy. Anyway, he mentioned on turbo cars to blend pre and post throttle body IAT sensors in boost. Something to the effect of OEM sensor reaction time and meth spraying and timing .
    Again, I could have this ass backwards. I'll have to ask I guess. Probably best to disregard all of that unless it somewhat makes sense.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #28
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    Current firmware only uses one IAT sensor for air density corrections. If you wanted to get really fancy, you could use an extra sensor to blend between two separate VE tables.
    The OBD2 IAT sensor is in a pretty good location for most forced induction applications - it's in the intake manifold, but the composite manifold is a lot less prone to give false high readings than on a metal manifold.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
  4. #29
    South Carolina
    2004 330 vert 2004 X5
    How many do we have?
  5. #30
    Sep 2009
    Lawrenceville, GA
    Right now we have two for OBD1 and four for OBD2.
    Matt Cramer
  6. #31
    Aug 2012
    CT
    Twin turbo LS E36 M3
    ill be in for a couple when we get closer, but its too early to commit for me.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  7. #32
    Sep 2002
    USA
    BMWs
    I'd pick one up except nothing on my car is stock enough to make use of it. Though, I could put it on my daily... hrm. Has me thinking. I do miss MS.
  8. #33
    Manchester, N.H.
    96 332IS 6466 turbo
    Here's exactly what's going to happen. 6-8 months from now, these things will be on our door steps. Then 5nails/SG2800/and E30kid will decide "this seems like a good time to all take a break from the forums."
    They will all be MIA at least long enough for us to run 35° timing with 200°+ intake temps and blow our sh&% up.
    Thanks a lot guys, you guys cut me, you really cut me.
    1996 332IS
    Built 3.2
  9. #34
    Apr 2006
    Minnesota eh?
    86 325es
    lol, just send me an email. I am planning on posting up all my maps and settings once I get them finalized.
  10. #35
    Sep 2009
    Lawrenceville, GA
    And you can always contact us directly for tech support on them.
    Matt Cramer
  11. #36
    Aug 2012
    CT
    I just got done with this install last night. MS3x, full sequential, COP, closed loop idle, open loop boost control for now, lean protection, ect.
    car runs amazing. Such a pleasure to drive
  12. #37
    Oct 2012
    ottawa
    97 328is 02 e46 330xi
    Naw. I got e30 on speed dial as "msking". And he's only a few hours away.
  13. #38
    Apr 2006
    Minnesota eh?
    86 325es
    On a serious note, the old style "solder yourself" megasquirts like I still run are a bit finicky to get setup. Especially if your doing a lot of board mods like mine to add extra features. In almost every case it takes some trial an error to get all the wiring right and get all the sensors calibrated and reading right, get all the outputs working the way they should, get a reliable connection on the laptop, ect... ect... ect... That's where people have a hard time and many people get overwhelmed and back out of it because its just over there head to troubleshoot the hardware. They they sell it cheap and tell everyone megasquirt doesn't work.
    BUT... once you have the hardware setup right and everything is coming in and going out the way it should, it is so easy to tune a car that you honestly just won't believe it. There is absolutely nothing to it at all. If all your hardware is working properly it takes literally an hour for a person to tune the fuel, idle, and accel enrichments to have the car running properly and safe. Even for a first timer it is very intuitive. Thats why this is going to be a great thing because the MS3 pro module will have everything you need built in and you won't need to build a harness, so you bypass all the painful hardware setup and get to jump straight to tuning.
    And of course the best part is that you won't be limited to the basemap that will come preloaded. Once someone gets one set up for a few days and gets it running smooth and everything working nice they can share there tune file on here and anyone can load it and use it. It doesn't have to be a secret anymore. My tune file won't be compatable with an ms3 pro but I would be more than happy to share any of my maps or settings.
  14. #39
    Sep 2002
    USA
    BMWs
    LOL - I wouldn't worry about that. My original MSnS-E M50 base map still lives on. I will get PMs or email asking for input on some MS build and notice it's already running my settings lol. It floats around somehow. Organic.
  15. #40
    Bellingham, WA
    e30
    Butters, there are lots of people on here who can and will help. No need to be scared
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  16. #41
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by wazzu70 View Post
    I'm not. I'm just messing around.
    1996 332IS
    Built 3.2
  17. #42
    Feb 2010
    Texas
    01 530i
    I would like to be put on the list for an OBD2 box.
    PM sent.
  18. #43
    Bellingham, WA
    e30
    I know. I am just trying to egg you on
    -Nick
    91 E30 M42 on VEMS
  19. #44
    Manchester, N.H.
    96 332IS 6466 turbo
    Actually super excited about this.
    1996 332IS
    Built 3.2
  20. #45
    Aug 2011
    philadelphia PA
    1993 325is
    Megasquirt is awesome. Been running a turbo m52 on it for 3 years.
    PNP is a great idea. If I build another e36 I will pick one up
  21. #46
    Nov 2015
    Melbourne FL
    96' 328is
    Planned on putting ms3x on my obd2 m52 using your BOB anyway but if a pnp comes up id probably do that instead. However I'm a dealer so i wonder if i can still be on the list.
    Sent from my SM-G930P using Tapatalk
  22. #47
    Feb 2009
    Arizona
    1998 e36
    will cost between $1199 and $1399
    Lets look at the bottom line here.
    People who are old BMW owners are cheap and thrifty. Five year ago even at $500 the M20 PNP did not take off. Miller war chip stalled also, he said half of the technical support calls are: "my laptop battery is dead, what do I do?"
    Even if product was cheap, the user still has to know basic engine management tuning and concept. There is always some software bug plaguing the MS because software is always BETA.
    People want cheap and easy.
  23. #48
    Aug 2012
    CT
    Quote Originally Posted by hakentt View Post
    Literally the furthest thing from the truth, and once again, literally the most counter productive post. The m20 pnp did very well and almost every modified m20 has one and it works great.
  24. #49
    Mar 2010
    Long Island
    E36
    Pls, let's not forget this. Everyone sign up!
  25. #50
    Feb 2010
    Texas
    01 530i
    Yes, can we get an update to the list? Let's make it to ten!
  1. Replies: 32
    Last Post: 11-11-2012, 08:19 AM
  2. HELP please..Are the sumps the same on a E36 M50 and M52 engine??
    By E36kjc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2010, 04:47 AM
  3. Looking into buying an e36 in the future
    By Shadow86325e in forum 1991 - 1999 (E36)
    Last Post: 10-10-2007, 10:07 AM
  4. Replies: 1
    Last Post: 07-22-2007, 01:36 PM
