This will have 8 GB of internal data logging. For external display options, check out this link.
https://www.diyautotune.com/support/...displays-data/
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
I can see me going broke with all these add on options. I really don't want to put more money into this pos
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
Butters are you running that twin scroll ces manifold? Piecing together my turbo goodies in anticipation for this and I think you just cost me even more monies.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
1996 332IS
Built 3.2
I am assuming no news is good news.
one lap of america s52/gt35r 318ti..500whp 533wtq 19psi via rk-tunes....
follow me on instagram @whitecord1
He hit 304whp and 257ft/lbs torque corrected on a Mustang dyno (288/244 uncorr). And then there was much rejoicing!
https://www.facebook.com/19937879725...1855972676268/
that sounds sick. makes me want to go na
And that one's running a circuit board from the production batch, too. It's getting close to release.
Matt Cramer
I wish it worked with my S50B30 Euro, love my engine setup but hate the tunning platforms, main reason i am finishing my M52 stroket to 3.0 low compresion to get boosted
It was my car that received the first production version of the MS3Pro PNP for the OBD1 E36. I cannot thank DIYAUTOTUNE enough for their professionalism and thoroughness. Phil was the installer and tuner. He took his time and was very thorough with the install. During the install we found that my VANOS and water temp sensor were plugged in backwards. He went over every input from the ECU and verified things were working correctly.
We then went to the dyno and got to tuning. Phil worked every cell of every map and pulled everything he could safely pull out the car. He was able to get 20HP and 20TQ from the start of tuning until the end. He had the car on the dyno for about 4 hours total.
I then took the car to both Atlanta Motorsports Park and Barber Motorsports Park for shakedowns. The car ran great and pulled hard everywhere. Unfortunately, I had an incident at Barber in T4 and put her in the wall hard and ended my weekend early.
If you are looking at this ECU, I can't recommend it highly enough. I already had a very stout setup but this really took it over the top.
I may have acquired funds for this... Anyone want an MS3X and 2 wiring harnesses...
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
I kind of want one a MS again...
Any update on when these will ship? If we are just waiting on mounting brackets, ill take mine without them. Mine is going in an e30 (s52 obd1 turbo) anyway...so not sure they would even work for me anyway.
