Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
Thread: M70 420g getrag swap - confirmed
  1. #26
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    Quote Originally Posted by mooseheadm5 View Post
    Look for the "Gristle Hammer". I made him a spacer ring with the bore for a pilot bearing and he used a button flywheel.
    Would you be able to make more of these flywheel spacers? I'm planning to get the adapter plate mentioned above soon (already have the 420g, pedals, slave, master cylinders, etc.)
    Also, pardon the ignorance, but what is a "button flywheel?"
    Quote Originally Posted by JDP530 View Post
    Thank you!
    Have you found a solution for the flywheel spacer? Also, how does that transmission adapter plate look, decent quality?
  2. #27
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    Quote Originally Posted by Smoky540i View Post
    I have not ordered an adapter plate at this time. I have too much other work to do on my car before I go for the conversion. Have you been in touch with the mfr of the adapter to see if they have a flywheel spacer or flywheel that will accommodate the 420g/M70 combo?
  3. #28
    Feb 2013
    Kalamazoo, MI
    JDP530
    I've emailed the manufacturer thru eBay and they indicated they are not currently making such a flywheel or spacer for the flywheel. Based on some searching on the net, they previously made a spacer that could be used with the E39 M5 240mm clutch setup, but it doesn't look like it's still available.
  4. #29
    Dec 2013
    San Antonio
    This looks like the adapter that is needed and its offered by the same company that makes the trans adapter: https://www.ebay.ie/itm/BMW-M60-M62-...item2ac112bdc8
  5. #30
    Feb 2013
    Kalamazoo, MI
    Yeah I found that too, but the link I had was from an expired listing. Maybe because I was searching in the US version of eBay...I can't quite figure out how this works though. Maybe the flywheel has to have its standard center piece pressed out and this pressed into its place?
    I was hoping I could reuse the E39 540i flywheel and clutch that came with my donor transmission, but I'm not thinking that's possible because of the need for a spacer.
  6. #31
    Dec 2013
    San Antonio
    I think the spacer bolts to the back of the flywheel so trans input shaft can fit into a pilot bearing pressed into spacer. Input shaft is not long enough with adapter to fit into pilot bearing in the back of crank.
  7. #32
    Jan 2013
    Sarasota, FL
    2x 93' E34T + 95' 750iL
    I'm gonna revive this thread once more. I plan on doing this swap with my E38. I guess I'll be the one to finally give an answer to it all. I'll try going the flywheel spacer route, as that seems to be an easier/cheaper solution than getting a new flywheel made.
  8. #33
    Dec 2013
    San Antonio
    Quote Originally Posted by Creesic View Post
    Have you made any progress on your 6-spd conversion?
  9. #34
    Jan 2013
    Sarasota, FL
    I've actually decided to go the route of M73 swapping my E31 and manual swapping that instead of my E38. That's just for now, however. I will be doing an E38 manual swap after this one, but it's pretty much the same steps no matter what.
    It's a bit involved, as I'll have to go standalone and get a bunch of other stuff done on the car, but yes, progress is being made. Still drawing up the spacer, but I've got the trans adapter.
  10. #35
    Dec 2013
    San Antonio
    PNC has a flywheel designed for the swap so spacer is not needed.
  11. #36
    Nov 2013
    Whitney, TX
    97 850CI
    What is your plan for the standalone engine control?
    Desecrator of all things Sacred
  12. #37
    Canada
    750 F01, 850i, LR3 HSE
    IMG_20190917_0952034.jpgIMG_20190917_0950041.jpgIMG_20190917_0949103.jpgIMG_20190917_0949179.jpgIMG_20190917_0949326.jpg
    I am in the process of this swap has well, I have opted to use the flywheel and clutch from the S54 (M3). You have to convert the twin mass flywheel to a single mass by drilling out the rivets and separating the two halves.
    The bolts supplied fit into the remaining holes then the flywheel sits over the recess on the adapter/spacer. They also provided an extension for the input shaft.
    Mark.
  13. #38
    Canada
  14. #39
    Dec 2013
    San Antonio
    I just found this newer video on a Chevy trans swap for an M70: https://www.youtube.com/watch?v=WhGZTwzIBsw
    https://transmissionadapters.com/col...o-manual-trans Kit is not cheap, approx $1500 which includes adapter, hub, clutch, and bell-housing.
  15. #40
    Sep 2016
    Virgina
    740i, 318is, 323i, m3
    M70 m60 420g
    Sorry to revive a semi dead thread but I can’t pm yet did you get anywhere with this mandd is it running?
  16. #41
    Dec 2013
    San Antonio
    This fella bolted up an E46 M3 6 spd to an E32 V12 using adapter kit but he didn't say which kit. The only adapter kit for the M70/ 420G I am familiar with complete with flywheel and clutch is from PMC Motorsports. https://www.youtube.com/watch?v=CPvLWcEL6ww
  17. #42
    Sep 2016
    Virgina
    Thanks for replying That I see but I believe that’s actually the m60 m62 s62 420g the photo I zoomed in on I think says m70-m60 on the transmission adapter the clutch adapter spacer he used I think uses a m52 duel mass front plate I wanted to see if it actually ended up working as a clutch combo that worked for that specific combo might be weird. Basically wanted working combo from someone with results if I can get it.
    I’m attempting to put an m70 in my e30 and basically the last part of info I need is this the ecu is sorted (putting the wiring harness together as I type)
    Engine mounts are good just have to mount the trans and make a drive shaft.
  18. #43
    Sep 2016
    Virgina
    Oh you mean in that video... my bad
  19. #44
    Mar 2016
    GER
    F31-325 E30-330 E31-850
    I am very interested in the wire-up for the needed modifications to enable cruise control.
  20. #45
    Christchurch,New Zealand
    93 fjord grey 850csi
    i'm not sure if it has been mentioned yet and im only doing this from memory but if i remember rightly the m60 and m73 bellhousing have the same bolt pattern it is different to the m70
  21. #46
    Mar 2016
    GER
    Quote Originally Posted by merlin840 View Post
    Yes I have also mounted the e46 m3 6speed gearbox to the m70via a adapterplate.
    Now I need to reflash dme as it will
    not rev higher than 5200rpm and cruise control does not work. Happy for any hints. Thanks
    This is the adapter i bought
    https://www.speedingparts.de/p/kuppl...240mm-945.html
  22. #47
    but if im correct no adapter plate would be required for the m73 also its a better motor
  23. #48
    Canada
    Quote Originally Posted by Devistator0 View Post
    Yes, completed and running for 3 years. Updated in another post. https://www.bimmerforums.com/forum/s...850-S420g-swap
  24. #49
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    You need to install a 6sp manual vesion chip into the EML.
    That will fix your cruise xontrol, assuming you have everything else wired up correctly.
    '91 850i 6sp (mint) (sold)
  1. Walk-Through M70 V-12 Swap
    By PorscheTech911 in forum 1988 - 1996 (E34)
    Last Post: 12-14-2009, 11:05 AM
  2. Transmission Swap Confirmation
    By jaylow in forum 1991 - 1999 (E36)
    Last Post: 03-23-2009, 10:18 PM
  3. Will E36 5spd Getrag swap on E30 318 M42?
    By RobertK in forum 1983 - 1991 (E30)
    Last Post: 03-21-2008, 10:13 PM
  4. E32 M70 Manual Trans Swap
    By JimmyBones in forum 1988 - 1994 (E32)
    Last Post: 09-11-2007, 12:42 PM
  5. tranny swap confirmation...
    By romeox929 in forum 1988 - 1996 (E34)
    Last Post: 05-23-2005, 03:31 AM
