I'm looking into buying a 1992 325is and the owner says he was told all it needs is subframe bushings, the rear wheels are super cambered and he says it's because of this, is that true or is it something else thanks
I have a picture but I'm new here and not sure how or if I can post it
those have almost nothing to do with each other.
0 relation...its camber is from the eccentric bolt located at the lca and/or there is an adjustable lca arm. Tell him to shoot a picture of the bottom rear of the car and send to you
Is the car at normal ride height or lowered? Something other than the subframe is suspect. Unless it's bent.
