Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: EML Switch in 850i
  1. #26
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Arrow
    Quote Originally Posted by E31 850i View Post
    My 04/92 euro M70 auto has:
    EGS "CR"
    EML 0 205 000 015; 1733600
    DME 0 261 200 352; 1738703
    I have the BINs here. I think you have an other EGS. Check the Code. (CR at mine)
    Thanks!... my numbers are very close.
    These are spare modules from a mid 91 850i auto.
    EML 0 205 000 015; 1733599
    DME 0 261 200 352; 1736635 (inpa style readout shows I have 1736370 in my car now)
    Looking up the part numbers in RealOEM it shows your and my part numbers are exchangeable retrospectively! So appears there is no difference between EURO/US EML/DME modules. Which leaves just the EGS as Wuffer suggested. I'll see if i can find a pic of mine. Do you have your part number for EGS?
    Do you have any schematics for the euro 850i (wiring for E-M-S switch)? All I have are US schematics. I can't imagine the difference amounts to much and easily modified.
  2. #27
    Nov 2015
    Ger
    E31 850iA 1992
    .. your DME and EML are the same as EURO. Only older/newer versions. (the VIN tells, the DME are from a 06/91 E31)
    Wiring: http://www.armchair.mb.ca/~dave/BMW/e31/
    I think this is for EURO and US.
    If you has an EPROM burner an 32KB EPROM, you can burn my EURO "CR" BIN. Maybe first easyer then changing wiring. I have only C27512 EPROM - but these are also working with BinStacker. (funktion in TunerPRO)
  3. #28
    Nov 2015
    Ger
    E31 850iA 1992
    here are my backup computers. For the future :-)The CH EGS is from a E32 750i M70 - works also fine in the E31.
  4. #29
    Del Mar, CA
    Unfortunately, these schematics show only the US A/M switch (page 2460.0-03 in the 91 manual).
    Is your E-M-S switch a momentary switch (US A/M switch is momentary) or is it more like a toggle switch (holding its position in selected mode)?
    Thanks for pics. I'll dig out my spare EGS and take a pic. Its from the same car as my other spare modules.
    I do have an EPROM burner somewhere and maybe some usable eproms.
    On further research it does look like the EGS are different. Need schematics to determine how easy to do a swap...
    US 0260002125; 1218495 CW
    EU 0260002096; 1218317 CH
    Anyone know what the CH / CW mean (large bold letters on label)?
  5. #30
    Nov 2015
    Ger
    E31 850iA 1992
    My E-M-S is momentary.
    I think CW an CH is comparible.
    My car has stock a CR - it runs fine with the CH from the E32.
    EU 0260002096; 1218317 CH (750i)
    EU 0260002113; 1218414 CR (850i)
    See the pictures, my 850i CR and a CR Alpina.
    CH/CW/CR an in my opinion "Alpa Codes".
    I know this from Opel cars. Many car componants has this 2 letter codes. With this code you can better dicide the parts.
    For example: there are many variants of dash instruments - for every engine an special insturment.
    In the produktion and later in ordering after a defekt, the two letters make it easier to find out the right part.
    At Opel cars, the Bosch Motronic ECU/DME have also Alpha Codes.
    I have seen, that the first letter tells the version of the motronic. For example: Motronic ML4.1 has Fx ans Motronic M1.5 has Gx. These Gx and Fx ECUs are compatible.
    But in these logic are not all ECU. For example: Motronic 1.5.2 has GM - and not compatible wirh the the other Gx.
    In the Bosch ecat you can see:
    CH - GS1.21
    CR - GS1.22
    I think GS is "Getriebesteuerung" (transmissioncontrol). Maybe 1.21 and 1.22 is a version. At my car CH and CR works.
  6. #31
    Nov 2015
    Ger
    E31 850iA 1992
    I have read in the 5/90 E31 US user manual, that the converter lockup in "A" mode in in the 3rd and 4th gear aktiv.
    On my car the lockup is only in the 4th gear. The car shifts above 80kmh in the 4th gear. Above 96kmh, the lockup is on.
    The lockup turns off, when the speed is below 90kmh.
    How works the lockup in the US car? I am intrested to test the CW EGS bin in my car. Can somebody copy the chip to bin file for me?
    See the picture, german VIII/90 auto transmission user manual.
    I think the US Auto 850i has an other rear axle ratio. I think the US Version is shorter. Right?
  7. #32
    Nov 2015
    Ger
    E31 850iA 1992
    I have check my E-M-S switch.
    The connector have 10 pins. 6 are in use.
    2 for illumination. Brown ans gray/red. Pins 1 and 2.
    There is an second brown for the E-M-S signal. Pin 8.
    Pin 7 is M
    Pin 4 is S
    Pins 10 is E
    I dont check the colors for E-M-S. In the cable are yellow/blue yellow/green und yellow/white.
    I think the yellow/white is for S. Check your US connector - maybe there is the yellow/white?
  8. #33
    Del Mar, CA
    Pin 7 is M
    Pin 4 is S
    Pins 10 is E
    After studying the electrical trouble shooting guide I believe these are the wiring changes in the EU 850 to accommodate an E-M-S switch (vs. 91 US 850i). I also came across a schematic for an erly 5-series that is wired exactly this way too! There is some confusion/error regarding where the E and M switch wires go, the troubleshooting guide indicates to the instrument cluster as they do in the early 5-series but in my 91 850 they go to the EKM and I doubt it is different in the EU model 850 (I think this is an error in the documentation). Schematic below shows these going to the EKM. These 2 connections indicate 'M' and 'E' in the instrument cluster, S is commanded by some other means.
    I picked up an inexpensive E-M-S switch from an E32 which I'll adapt to fit and plan to pursue this further, just not clear where I'll end up or when since I'm knee deep into my 760i right now. First job is to determine if my existing EGS will support S4 by simply grounding EGS pin 4.
    Same colors are shown in this schematic except I think
    E = Yellow/Blue
    S = Yellow/Green
    M = Yellow/white
    Ground = Brown
    illum power = Grey/Red
  9. #34
    Nov 2015
    Ger
    E31 850iA 1992
    Hallo BMSman,
    works your "S" mode?
    Can you send me the US EGS CW bin file?
    Here are my EU EGS files:
    https://wsi.li/tH5DXDpvqRnx1D
  10. #35
    Del Mar, CA
    Hallo BMSman,
    No, I'm afraid not. Grounding Pin 4 didn't do anything in my car.
    My thinking now is to modify the transmission lever position switch (when in D) to fool the car to think it is in S3 and automatically switch back to economy (4th gear) once I've reached cruising speed. This looks easy to implement and would basically automate what can be done manually... moving the gear lever between 3 and D at 50mph (or there abouts).
    Sorry I don't have any EGS bin files. I've got so many other projects this one is dragging...
  1. Air In 850i Petrol Tank
    By albahar in forum 8 Series (E31)
    Last Post: 12-21-2004, 10:11 AM
  2. kicktown switch in auto 325
    By Loud_TIGER in forum 1991 - 1999 (E36)
    Last Post: 06-28-2004, 04:16 PM
  3. Reverse Light Switch in Transmission Question
    By themadhatter in forum 1991 - 1999 (E36)
    Last Post: 10-23-2003, 02:24 AM
  4. Auxilary switches in E46???
    By topazbimma in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-02-2002, 07:56 AM
  5. Switches in the ash tray???
    Last Post: 09-23-2002, 02:10 AM
