Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 62
Thread: E34 550iT. The Gristle Hammer.
  1. #26
    540, USA
    1994 E34T...etc
    Quote Originally Posted by ross1 View Post
    Your symptoms indicate the oil is past the valve guides, so new seals maybe not enough.
    Cool project, you'll get it sorted.
    Was kinda hoping that would be the case. Heads are easy to swap on these. I have a spare set I can rebuild...maybe even look into cams or whatever. I know there's not much out there, and it can be spendy....but I've got a year before Vintage 2017....
    1994 550iT/6 : 2003 330i/5
  2. #27
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    Quote Originally Posted by 5mall5nail5 View Post
    Sort of - M70 sounds like a smoother M20, not like italian V12s due to firing order and RPM. Still cool though.
    I heard some m7x that sound like Italian cars etc. Maybe those were all vanos motors or there's a secret in materials used to get it.
    The guy with the light blue E38 750il sounds like it to.
    Oh the guys name is Dima I think
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
  3. #28
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Quote Originally Posted by slammin e28
    That's a sexy photo!
    My favorite sticker was one I saw on a Testarossa, IIRC - "Just another crappy import"
    Can we have more details about the transmission adapter? I imagine it was custom, and easier/cheaper than sourcing a 560G?
    Given that both banks of an M70 follow the normal 1-5-3-6-2-4 straight-six pattern, I wonder what it'd sound like with fully independent dual exhausts? (Sidepipes?)
  4. #29
    540, USA
    1994 E34T...etc
    Quote Originally Posted by moroza View Post
    Adapter was sourced from a place in Poland. My friend has the info. He did a M70 into an e28 528e. We drove down to Vintage together. He had to make a flywheel spacer to make up for the adapter thickness.
    They sound very nice with independent pipes. I'll dig up the clip of the e28 with dual 2.5" pipes, no X to H.....just independent pipes all the way back.
  5. #30
    540, USA
    1994 E34T...etc
    So, just for reference....the M70 air mass meter plug, harness side, and the boot are part #s: 12 52 1 737 668 (housing) and 12 52 1 737 944 (boot). I had a helluva time finding these. Between number supersessions and what not....a good friend at the dealer took time on a Saturday (his day off) to help me find them. One of my plugs disintegrated, so it likes to fall out and drop that bank from time to time.
    Getting a set of 99k mile M70 heads to redo. Figure for the cost of valve guides, these will be cheaper....and they have wayyy less miles than my 265k engine. So I'll just swap them onto my engine. Was thinking of looking at getting the cams ground, etc....but for the $$ it hardly seems worth it.
    Trying to get this thing back to the reliability I had with the M30 in the car, where I feel comfortable driving it on a daily basis...but I've got my RX7 and Land Rover projects to do too....may park this car and get into those just to break things up a little. I'm getting burned out on BMWs.
  6. #31
    ATX
    Sundry old Grrrrmans
    Quote Originally Posted by slammin e28 View Post
    reliability ... RX7 ....Land Rover projects
    You are the most interesting man in the world, a gentleman most in his element dancing on the edge of a knife suspended over a precipice filled with flat-beds and fiscal failure. And I salute you.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
  7. #32
    540, USA
    1994 E34T...etc
    A friend of mine detailed the thing...
    Quote Originally Posted by Walter View Post
    Because I had this car in my garage for a detailing to pay back Jeff for his help with my E28, I took some pictures and video of this thing.
    First: Exhaust video
    https://youtu.be/C3LyP92QzoM
    So, got the shifter all fixed, now I have access to all 6 gears.
    Before it was flat and about 3/4 an inch shorter. When shifted into 5 or 6 it was rubbing on the guibo. Also lowered the trans another 3-4mm.....long story. Also re-bled the clutch, it's a lot better now. Must have had a minuscule amount of air in it.
    Then I decided to put the spare tire back in. The car had gotten REALLY smelly, like BAD. I couldn't figure out where....but I found out...
    8 or so dead baby mice in the spare tire well.....removed them and cleaned the well. Smell is gone now.
    Decided to take the car to C&C on Sat morning. Started up just fine and drove 40 miles to C&C. Went to leave and the injectors wouldn't pulse, also the fuel pump would cut off when cranking. Tried jumping it, but still nothing. So had to tow it to the shop and properly diag.
    Turned out the 3 year old battery was marginal, and the power junction for the aux relay box (which houses the fuel pump/injector relays) was bad. Corrected that and started driving it home.
    THEN I was like 5 miles from home and decided to show off to the panhandler at the interstate exit....
    I launched the car and immediatly there was a pop and the engine reved....but car would barely move. So got it out of the road and had dad call AAA.
    Tow driver was super cool, and talented with that roll back.
    Got the car home and on the lift and diaged.
    https://www.youtube.com/watch?v=2BwgKKDMzYY
    Did that with a used, stock, e39 528i clutch...
    Then....since there was a drive down Skyline Drive the next day (Sunday)....I went to the shop (40 miles each way) to grab a replacement axle. This is where I learned that 535i axle are larger than the 525i ones....so I had to crawl under a parts car and harvest the axle.
    Done and done...did the drive and it was awesome.
    I think after getting the car cleaned up, I'm more into it now. It's a blast since I got the shifter BS and clutch bled all proper.
    Now I've got some fueling issue going on, I think. I'm going to swap in the brand new dual fuel pump setup from the 750 and all that jazz. The stock 525i pump seems to not be able to keep up when the tank gets low, so I get all kindsa misfiring etc....plus it's loud, and has been loud since I bought the car.
    Also going to swap in the rear trailing arms from the 750 and larger axles from the 535.
    Then I'm gearing up to swap in the other M70, since this one uses a ton of oil and smoked on decel, and install the new M5 clutch and have VAC put a new gall plate on the flywheel.
  8. #33
    Portland, Oregon
    E34 M5, E91 328i, FZJ80
    Cool build dude! Keep us updated.
    Instagram @Restoration_Motorsport
    www.RestorationMotorsport.com
    -Nick
  9. #34
    Mar 2008
    NE Ohio
    '87 325is, '91 525i,
    This thing is just so..... wonderful. It's like what every Touring should aspire to be when it grows up. Like a manual swap is its Sweet 16 lol.... and then.... V12.
    -Geno
    '87 325is s52 swapped
    '95 525iT Das Wagen
    '02 Range Rover 4.6 HSE
    '98 Discovery LSE Mud Rat
  10. #35
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Yeah very nice build! Congrats and enjoy it!
  11. #36
    540, USA
    1994 E34T...etc
    Got some pretty huge updates. I'll post some teasers, but the entire thing is pretty much spelled out in the link at the bottom.
    I got tired of the v12 burning oil and running like crap. It had around 270k on it or so. I bought another 750iL ($350) and all it needed to start was the fuel pumps. So I took that engine and rebuilt it. Raceware headstuds, Calico coated bearings, basically everything replaced and or/cleaned. New TRE 255lph fuel pump and I converter the fuel rails to M73 rails, BUT I deleted the return and have a e46 330i fuel filter w/integrated regulator at the back of the car. So I have only one fuel line going into the engine bay.
    Quick random pic summary:
    And a quick vid a friend did for me:
    Thing is fantastic now. Drives so much better. It's amazing.
    I'll be driving it down to Vintage Friday.
    http://www.r3vlimited.com/board/showthread.php?t=386577
  12. #37
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Looks a great combination. Thanks for sharing
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  13. #38
    Cornelius, NC
    09 535ix
    Would you please build me one? That is awesome...
    RIP Jess or the idea of Jess or... what OT was.. or whatever...
  14. #39
    May 2009
    Orange County, CA
    2000 Dinan S2 M5T
    Awesome work!
  15. #40
    Apr 2016
    Mass
    2016 340i XDrive M-Sport
    Great Video! More Please!
  16. #41
    540, USA
    1994 E34T...etc
    Man, it's been a little bit. New engine is still going strong. Went to a dyno day and put down some solid numbers.
    I was a little disappointed it didn't hit 300whp, but what it did put down it right on par with the crank HP when new, so I'm happy. Also the consistency is insane.
    So, I guess it's done? I donno. I'm not a huge aesthetics guy, but I may delve into the interior to make it a nicer place to be. I donno.
  17. #42
    Wadsworth, Ohio
    BMW
    Every time your thread resurfaces I'm reminded of how much I want to build a v12 wagon! Love it!
    -James
  18. #43
    moroza's Avatar
    BFE
    E34T
    Quote Originally Posted by BleedsBlue View Post
    ... dancing on the edge of a knife suspended over a precipice filled with flat-beds and fiscal failure.
    Quoted for gold.
  19. #44
    Cornelius, NC
    09 535ix
    Quote Originally Posted by KingDavidsCourt View Post
    No seriously... I wish I could do stuff like this on my own. I'm half tempted to buy a wagon with a overheating issue (I wish e34 sellers just went ahead and said it instead of 'runs but needs coolant system attention') start twisting bolts until I losen enough to get the engine out and just figure it out myself.
  20. #45
    540, USA
    1994 E34T...etc
    Haha, you don't wanna know what it's cost. I've got hundreds of man-hours into this engine. Parts generally at cost (I manage a shop), except the headstuds ($660 for the set IIRC) and getting the bearings re-coated ($120 for them all), were around $2k or so.
    Protip: Get a touring with a V8.....swapping the I6 cars to anything wider than an I6 is a pain.
  21. #46
    Jul 2006
    Lake Lanier
    E34 540i6 M Sport
    This makes me want to build a V12 wagon.
    95 540i6 M Sport - 95 525it S52/OBD2 - 433k E36 328i5 - X5D that hit a pothole - IG: @justinmurray95
  22. #47
    Denver, CO
    V12 wagon anyone???
    ...but yes. So cool!
  23. #48
    Cornelius, NC
    09 535ix
    I wish I could find a nice one for a decent price. The only ones I see anywhere are 525it's...
  24. #49
    moroza's Avatar
    BFE
    E34T
    265/295? I know dynos vary, but that's +1hp and -1ft-lb from my M62 (264/296). The noise is quite a bit nicer, though.
    Hey wait... is this thing a hardtop?
  25. #50
    540, USA
    1994 E34T...etc
    Yeah, M70 never was a bit time powerhouse. It's more the ohhs and ahhhs and the sound, lol.
    Yup, slicktop. Wouldn't have it any other way.
  1. Replies: 10
    Last Post: 10-29-2004, 08:07 PM
  2. My SC'ed E34 in the classifieds:
    By Cacatfish in forum 1996 - 2003 (E39)
    Last Post: 04-11-2004, 01:09 PM
  3. Replies: 12
    Last Post: 04-10-2003, 05:47 PM
  4. Are all e34 shocks the same!!!
    By Thorack in forum 1988 - 1996 (E34)
    Last Post: 04-09-2003, 06:49 PM
