Hello,
I was trying to code kombi from e92 to enable Digital Speed on display, but i cant do nothing with the kombi...
Always having this error:
Code:
[23:23:10.904] [2016-05-26] [SERIE] 2060 PABD/CABD A_PL2KMB.IPS Cod 371
[23:23:10.904] [2016-05-26] [SERIE] Coding erroneous (general) KOMB87, C_C_AUFTRAG: ERROR_VERIFY
[23:23:10.908] [2016-05-26] [SERIE] 2060 Error COAPI2.CPP coapiRunCabd 6
[23:23:10.908] [2016-05-26] [SERIE] Coding erroneous (general) SG_CODIEREN
================================================================================(9)
Even with Expert Mode to try to reset (SG_CODIEREN), im getting same error...
I tried also to update kombi with winkfp but before start it returned error....
Everything is working like before, except i didnt have more the blank/empty display option (with BC button) and lost also the gear indication on display... (this feature only can be enabled on that "blank/empty" line, pressing BC button... but i dont have that blank display... so cant enable it)...
Someone can help me?
What can i do?
Everything else is working ok, tested, updaten spdaten and everything (runing with ICOM).
thanks!
Error from winkfp when try to update...
Code:
[22:43:07.773] [2016-05-26] [<WinKFP Tool] 2089 PABD/CABD BKOML2 Programmieren 3445
[22:43:07.773] [2016-05-26] [<WinKFP Tool] switching programming mode failed 31BKOML2, DIAGNOSE_MODE (ECUPM): ERROR_ECU_CONDITIONS_NOT_CORRECT_OR_REQUEST_SEQUENCE_ERROR
[22:43:15.963] [2016-05-26] [<WinKFP Tool] 2082 PABD/CABD BKOML2 LoescheFlash 2618
[22:43:15.963] [2016-05-26] [<WinKFP Tool] Clear flash failed 31BKOML2, NG_FLASH_LOESCHEN (...): NO_RESPONSE
[22:43:41.981] [2016-05-26] [<WinKFP Tool] 2082 Error COAPI2.CPP coapiRunCabd 6
[22:43:41.981] [2016-05-26] [<WinKFP Tool] Clear flash failed SG_PROGRAMMIEREN
[22:43:41.981] [2016-05-26] [<WinKFP Tool] 2082 Error COAPIKF.CPP coapiKfProgSgD2 19
NCSExpert v.4.0.1
EDIABAS v.7.3.0
